i'd take the Fram anytime if the choice would be between Fram and fake fleetguard. Frams painted grip is ***y and more colorful too..hehe
As a guide to fellow tsikoteers, those who had bought Baldwin & Fleetguard oil filters here in the philippines. Can you please post where you bought them and their respective addresses and contact nos. This thread would be pointless if people like me interested in buying better oil filtration can't find it, or if found be misled into buying fakes. A recurring and updating of trusted dealers will be highly appreciated. also prices of different part nos. will be of great help to those reading this thread.
Also dvldoc i'd like to clarify this list of part number for the 4m40 engine
Fleetguard LF3918
Baldwin BD7028 & BD28
Is the design of the above filters the same as the OEM filter, which you say has a unique design ("Dual By-pass" I think you said?) But the material used in filtering is of higher standard? Correct me if I'm wrong? Thanks
Fasten your seatbelt! Or else...Driven To Thrill!
Interesting thread. We use Donaldson and fleetguard filters on our CAT generator sets. Cheaper than CAT OEM filters.
Did not know they can also be used for our rides. Anyone know the oil filter model number for Avanza 1.5?
For Toyotas I like going slightly bigger these are just a 1 inches longer. Cross with a FRAM PH3614
Fleetguard LF3335
Largest OD 76.81 mm (3.024 in)
Overall Height 88.65 mm (3.49 in)
Thread Size 3/4-16 UNF-2B
Baldwin BT223
Thread: 3/4-16
O.D.: 2 29/32 (73.8)
Length: 3 1/2 (88.9)
Donaldson 550335
Thread Size: 3/4-16
Length: 3.4" (86 mm)
Outer Diameter: 3" (76 mm)
STOCK Toyota
Crosses as FRAM PH4967
Fleetguard LF3614 is the cross but I would not use because it does not have a anti drain back valve or bypass valve.
Baldwin b33
Thread: 3/4-16
O.D.: 2 11/16 (68.3)
Length: 3 (76.2)
Donaldson 502024
Thread Size: 3/4-16
Length: 2.56" (65 mm)
Outer Diameter: 2.68" (68 mm)
I would go with the bigger filter. And it will fit with no issues.
These will fit basically all Toyota 4cly and 6cly vehicles except ones with 1kzte, TD42, Engines. 100% Will fit 1999 and UP 4cly and 6cly engines.
Be sure to share where and how much you payed for yours.
Sir edtf, san ba yung location W&L na store na yan, or maybe even the contact nos.? Thanks
Interested ako sa Fleetguard for my 4m40 and 4ja1 as I have ones experienced problems in the oil filter quality (blocked), good thing my engine didn't konk out so I'm in the hunt for a good oil filter...
4M40
Baldwin BD28
Donaldon P551343
Fleetguard LF3564
4JA1
Baldwin B1446
Fleetguard LF3786
Donaldson P502039
http://www.wnltradingcorp.com/WLT/welcome.page
W&L Trading Corporation
#33, 8th street,
New Manila
1112 Quezon, Philippines
Phone: +632 722-1880
Fax: +632 721-9356
Davao Branch
Door 1 Lex Building, R.Castillo
Agdao, Davao City
Tel No(082)222-7839 • (082)222-7894
Fax No: (082)222-7894
Email: wnlcorporation*yahoo.com
Cebu Branch
Unit 2 & 3 VMS Building,
UN Avenue Alang-alang,
Mandaue City
Tel No: (032)345-0503 • (032)345-0506
Email: wnl_cebu*yahoo.com
They Do.. Please check the following sites for the cross-reference.
Just be careful with indirect crosses as size and thread size matters, always double check and compare the width, diameter, ADBV, PSI setting of bypass valve, oil seal diameter..
The recommended
Fleetguard:
http://www.fleetguard.com/catalog/js...sreference=yes
Baldwin:
http://catalog.baldwinfilter.com/startproductguide.html
Donaldson:
https://dynamic.donaldson.com/webc/W...reference.html
ChampionLabs/ Luberfiner:
http://www.luberfiner.com/catalog/parts-catalog.aspx
Wix:
http://www.wixfilters.com/filterlookup/
Others
Mann + Hummel (Europe):
http://www.mann-hummel.com/mf_prodka...=3&ktlg_lang=1
Ryco (Australia):
http://www.rycofilters.com.au/catalogue/xref
Japanese:
JS Asakashi:
http://www.js-filter.com/catalogue
Sakura:
http://www.sakuracatalogue.com/filte...ra/filter2.php
Vic:
http://www.eiken-kk.com/vicf.html
The not so recommended:
Fram:
http://www.framcatalog.com/Application.aspx?b=F
This covers most old school turbo diesels and some of the new ones. Covers Air, fuel and oil filters. Enjoy
http://www.odms.net.au/files/organis...%20NEW_V14.pdf
http://www.fleetguard.com/pdfs/produ...s/3300964A.pdf
http://www.acdelco.com.au/PDFs/Catal...s_20-05-10.pdf
Note there are alternative filters you can run vs what is stated that fit and have the same or very close bypass valve pressure.
any model number for 1kzte(toyota) and 4jg2(isuzu) for fleetguard, baldwin etc? tia
