Page 61 of 67 FirstFirst ... 1151575859606162636465 ... LastLast
Results 1,201 to 1,220 of 3899
    Jul 2011
    I believe Top1 SDO is semi-syn like delo 400 which is around PhP300 half the price of mitasu 100% synthetic, like the price of royal purple.
    Tempted to buy mitasu because of "made in japan" tag. Almost same price you posted, but I saw that mitasu inside clark in oriental.
    Posted via Tsikot Mobile App
    Yes its Fully Synth, i was just comparing the TBN and its similar to SDO. Was not actually keen on blends since my application could both use full or semi synth. SemiSynth counterpart of SDO is Mitasu MJ-231 and it got an outstanding 14.0 TBN.
    One russian forumer at BITOG quoted..
    Some time ago (about 2-3 years or so), businessmen from the Russian Far East created new "Japanese-like" motor oil brands for the Russain market: Mitasu, Takumi, Totachi, Yokki. The oils are blended in Singapore, the trademarks were registered in Japan, have japanese-like names and marketed as "True Japanese product"
    Im not sure how accurate the info but it make sense if the market was once overwhelmed by these Jap oils.
    ^nakaprint sa packaging na "manufactured for Mitasu Japan".
    so hindi siya "made in japan"
    Just fyi guys. I worked for a japanese manufacturingncompany in Laguna for 2 years and our products were stamped "Made in Japan." So dont believe everything you see.
    Stock Engine Modified Driver...
    Jul 2011
    If you want higher TBN check seaoil deomax rated 13+, pero ok na ako sa delo 400 TBN 12, baka sa internet lang mataas yung TBN ng seaoil.
    Nung makita ko kasi mitasu wala akong alam sa mitasu at di ko man lang nababasa sa mga forums/reviews, kaya di ko kinuha, research muna medyo mahal eh. Yung pang gas engine nila 1k per 1L presyo wow.
    Sep 2013
    May barkadas oil filter for his mitsubishi mirage, subaru brz and honda s.i.r
    May 2005
    Quote Originally Posted by chookchakchenes View Post
    B1402 - compatible with Subaru FB engines and Honda
    B1431- longer version of B1402
    Which one is for the mirage ?
    Sep 2013
    Fleetguard for the brz
    B161, b1402 , b1431 - civic s.i.r, mirage.
    Yung sa fleetguard pwede din civic and mirage kaso malapad baka may tatamaan.
    May 2005
    Its not clear from the pic, care to share the model # of the fleetguard ?
    thanks
    Jul 2010
    Mga boss ask lang ano ba ang TBN rating ng royal purple synthetic oil 15W40? I want to compare sana which is better between delo 400
    Jan 2014
    Quote Originally Posted by joemelr View Post
    Mga 8-9 lng tbn ng rp sir compare sa delo 12? Wondering di mas maganda ang delo sa rp??
    May 2008
    Bought a new set of filters from Volmax earlier. I was surprised that the BF7535 had a slightly different box.
    Compared it with the box of BD28:
    No print where it was manufactured
    Logo and red tint are slightly off
    Extra Labels
    Jan 2014
    Quote Originally Posted by Reepicheep View Post
    Extra Labels
    Magkano ang bf 7535 sir? Orig ba sa tingin nyo? Sa me trackzone me Baldwin din sa me Abad santos
    May 2008
    P985 for the BF7535. I'm not yet sure on its authenticity pero orig naman lahat nung BD28 na binili ko from them the past months.
    Sabi rin nung sales lady China na daw yung mga BF7535.
    May 2004
    gurus, me nakita ko benta baldwin BD7029 sa sulit na made in china but purchased from the US. legit ba? tia
    Sep 2013
    number001,
    After ko picturan, nag oil change na. Tanungin ko friend ko kung ano code.
    Jul 2011
    siguro yung rp more on performance than protection, tapos yung delo is semi-syn designed para sa fleet at extended oci.
    Jul 2010
    Quote Originally Posted by MrQ5 View Post
    Safe kaya sa 10K oci ang delo 400 using bd28 kc semi synthetic lang ito?
    Presently im using rp with bd28 oci ko is 10K malakas loob ko kc fully synthetic oil
    Ano sasakyan mo, if bago naman tingin ko kayang-kaya na. Tsaka may napost na dito na mga gumagawa nang used oil analysis. Kung sa MM ka, bakit hindi mo i-try sa 7.5K kms muna tapos pa-UOA mo para sure ka kung kaya pa ma-extend.
    Seach mo lang dito yung mga companies na gumagawa nang UOA>
    Jul 2011
    no experience with rp and neither an expert, depende siguro sa history ng pms at kung kelan ka nag shift to rp.
    actually my nag-post na yata dito na yung delo 400 sa L300 fb? nila 7.5k pa lang iba na yung oil.
    pag galing siguro. sa low to high detergents oil mas mabilis siguro umitim oil.
Remote bypass oil filtration
