Results 1 to 20 of 27
    Aug 2012
    Baka may makatulong lang po sakin. '92 Lancer EL M/T carb. Pag nagshift into gear walang problema sa lower RPMs, pero pag todo apak na sa gas, parang nawalan na po ng hatak. Short shift tuloy para tumuloy ang pagaccelerate. Last weekend po pinacheck na yung fuel at air filter ok naman. Nilinis din yung spark plugs at nagpalit na rin ng high tension wire as per nung mekaniko. Ano kaya problema nito? Thanks po sa makakatulong
    Quote Originally Posted by Nforcr View Post
    Have you checked the fuel filters? (in-line and in-tank).
    Sounds like a slipping clutch to me...
    Yup,- slipping clutch ang tingin ko..
    Humuhugong ba ang makina, pero makupad ang takbo?
    16.6K:sunny::sampay:
    Aug 2012
    Nacheck naman ok naman yung mga fuel filter.
    Quote Originally Posted by erick_214 View Post
    Basta pag mataas na yung RPM pag niratrat, nauubusan na po. Papacheck ko this weekend. Thanks po sa mga reply..
    try mo shift yung gear tapos release mo yung clutch, pag di umandar o namatay makina mo slide na nga clutch mo...
    Apr 2024
    Normal ba kapag 4th gear ka tapos downshift sa 3rd gear tumataas rpm kahit inde ka naka apat sa gas
    Jan 2009
    Quote Originally Posted by Rjmar View Post
    Yes...⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀
    Jun 2011
    Opo, dahil sa momentum ng speed galing 4th gear.
    agree with bxr.
    when you shift from 4th to 3rd gear, the momentum of the vehicle is the one pushing the engine to turn faster and not vice versa.
    Jan 2009
    To add, that's why you have to be careful when downshifting, especially on manual transmissions (M/T), to prevent over-revving the engine beyond its operational range. On your manual, it will often indicate the maximum speeds for each gear.
    As an example, here's info for the 2nd Gen Innova:
Walang Hatak * High RPM
