For Toyotas I like going slightly bigger these are just a 1 inches longer. Cross with a FRAM PH3614
Fleetguard LF3335
Largest OD 76.81 mm (3.024 in)
Overall Height 88.65 mm (3.49 in)
Thread Size 3/4-16 UNF-2B
Baldwin BT223
Thread: 3/4-16
O.D.: 2 29/32 (73.8)
Length: 3 1/2 (88.9)
Donaldson 550335
Thread Size: 3/4-16
Length: 3.4" (86 mm)
Outer Diameter: 3" (76 mm)
STOCK Toyota
Crosses as FRAM PH4967
Fleetguard LF3614 is the cross but I would not use because it does not have a anti drain back valve or bypass valve.
Baldwin b33
Thread: 3/4-16
O.D.: 2 11/16 (68.3)
Length: 3 (76.2)
Donaldson 502024
Thread Size: 3/4-16
Length: 2.56" (65 mm)
Outer Diameter: 2.68" (68 mm)
I would go with the bigger filter. And it will fit with no issues.
These will fit basically all Toyota 4cly and 6cly vehicles except ones with 1kzte, TD42, Engines. 100% Will fit 1999 and UP 4cly and 6cly engines.
Be sure to share where and how much you payed for yours.
