Results 71 to 80 of 1853
May 14th, 2011 07:12 PM #71
*dvldoc - so qd32 is better than zd30?? un lang.. change oil ko muna trak ulit...para magkaalaman na ng tuluan..
i think nissan loves to under rate their engines on paper...
May 14th, 2011 08:48 PM #72
If your comparing the non turbo charged QD32 to the Non turob ZD30 and not the QD32ETI vs ZD30Etti then the QD32 and ZD30 are close in reliability and power, the turbo version of the ZD30 has many problem like overboosting and loves to kill turbos and crack heads and I have not seen a dyno on on yet that was over 105hp and they are supposed to be 170hp they should put down at least 130hp to the wheels.
The N/A QD32 is a rock solid engine it's the TD27's big brother without all the overheating taken care of should run damm near forever. 2T oil, oil catch can good filters will go a long way on these.
The other thing is parts QD32 shares like 80% of stuff with the TD27 so parts are easy to get, ZD30 good luck with that it's going to be expensive.
May 15th, 2011 12:26 AM #73
I tried this on my 06 D4D innova, 200ml of 2T * 48 liters of Diesel from seaoil. So far so good, the engine runs smoother.
- Dec 2003
- 137
May 15th, 2011 09:25 AM #74Currently on my second tankful. On a 2006 Mitsubishi Adventure with 4D56. 200ml of Castrol 2T Trimax added to a 55 liter tank.
First observation is that shutoff shudder is not as strong as before. Also, not as noisy as before. Also, I was having weird vibrations on my gas pedal when accelerating before. When I started adding 2T, this lessened to a point that I have to be looking for it to notice it. Maybe it's not connected, but I'm not complaining.
The icing on the cake? Normal FC of around 10KmL jumped to 11.4KmL.
May 15th, 2011 10:14 AM #76
May 16th, 2011 12:03 AM #77
May 16th, 2011 03:30 AM #78
The do not use for 2007 models does not really apply to the diesels sold there unless they are very high end cars. That warning is more for US Turbo diesel trucks and high end cars like BMW and Mercedes turbo diesels I posted on here regarding this on a early post. None of the JDM diesel fall into this category or even vehicles like the Fortuners with the D4D they are not the super high pressure Common rail and high end pizo-injectors that these would effect that were designed to run on low sulfur diesel.
The 4M41 has been around since 2000 and has not changed at all.
http://www.mitsubishi-motors.kiev.ua...ee9409/11B.pdf
May 16th, 2011 07:55 AM #79
May 16th, 2011 01:06 PM #80
Tried it yesterday on my way home from my beloved province.....
Ran 360 km for 8 hrs. started the trip at 12nn...Engine non-stop.
Filled up 100 ml to 21 liters (P1k) diesel: no effect yet (i presume)....
Filled up again the same amount of fuel and 2T halfway through the trip: i don't really know if it's just me or my oneness with my rig....i observed greater amounts of smoking on abrupt acceleration with a 500 kg load at the back.....or could be the general behavior of these 4d56s smokin too much.....but somehow i sensed via the pedal a decreased amount of engine rattle on the 2nd fill.....
Stuck to Shell's regular diesel and 2T during the trip.
Pulling power and top speed seems to be the same....
Katamaran. Lalo na yung mga really old cars na 2nd or 3rd owner na, and sold off for mga 80k and...
LTO car registration and late registration fees
