Results 1 to 20 of 25
    Jul 2019
    Hi, I'm confused about this belt stuff, so is the drive belt/serpentine belt the same with fan belt, compressor belt, alternator belt? The car is a Honda Civic 2015 1.8 S AT. Mileage is already at 44k km
    Thanks in advance
    Jun 2011
    Quote Originally Posted by Suzumiya View Post
    Thanks in advance
    Tama po. Iisang belt na ang lahat na iyan. Isang palitan na lang, mas tumatagal ngayon di tulad ng kapanahunan na mabilis maputol.
    Jul 2019
    Quote Originally Posted by bxr monkey View Post
    Thanks sir for enlightening me. At least now I can go to the autoparts store and know what I want to buy.
    Jan 2016
    Mas matibay nga siguro kasi I haven't replaced mine which will turn 8 years old in 3 months with 80k+ kms traveled. No signs of slightest fraying, kaya I wondered if the author was just curious or his unit needs replacement na, it's half my mileage and 2 years younger, mine's also a 2013 FB.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Jul 2019
    I just want to have the part ready should the inspection from the mechanic turn out to be negative on that part, in any case the car is already 5 years old this 2021 and my aunt is the second owner, I asked for maitainance records and she has none she had relied so much on her previous driver and mechanic, so I might just have it replaced out of caution. I don't want to wait till some signs of a bad belt shows up. heheh but kudos to your car sir tibay nga.
    Jan 2008
    serpentine belts are replaced based on physical appearance or years in service.. some manufacturers suggest to replace the belt every 4 years regardless of its physical appearance.. some maybe even longer around 6 years.
    Jun 2004
    Belts nowadays last longer, just recently replaced a timing belt after 11 years and around 40k mileage, belt had no cracks or damage and looks like it could have gone a few more years given the low mileage per year. But still materials degrade over time. Belts are not too expensive anyway and is included with regular PMS. I recommend getting original part from dealer or having the PMS done at dealership as I have experienced before mas mahal pa sa suking auto shop.
    i had my non-honda's timing belt replaced in the casa, on its 14th year / 120K km. it was still less than the manufacturer's replacement schedule. the belt still looked fine to me.
    casa, for the perceived genuine-ness of the belt, and the perceived warranty.
    the difference between casa cost and banawe cost wasn't that much.
    Feb 2017
    I haven't replaced my 2017 civic's serpentine belt since I got it. It's already 4 years but according to the pms schedule it should be replaced every 3 years. Based on visual inspection, it's still good no signs of cracks and is still thick. Maybe I'll replace it on the 5th year.
    Sent from my HD1913 using Tapatalk
    Quote Originally Posted by zero3 View Post
    many pms manuals assume the car owner is an automotive dumbo,
    hence the more aggressive replacement schedule.
    after all, that is what pms is all about: pre-failure management scheme. replace it before it brakes.
    but if one is knowledgeable, willing to take risks, and does not drive out into the boondocks naman, one can opt for the physical and visual inspection instead.
    i do.
    some owners have a spare belt in the car, for those justin cases.
    i have replaced my 2005 innova's belt with over 140K km on the car,
    only once.
    somewhere between the 70K and 100K mark, i vaguely remember.
    now that you mention it, i think it is time to inspect the belt...
    Jan 2016
    Mine hasn't been replaced since June 2013
    Jul 2019
    Had it replaced a week ago, mechanic said it was a good time to replace, may tama na daw bang belt anytime pwede na bumigay.
    Sent from my CPH2159 using Tapatalk
    Jan 2016
    Magkano nagastos mo?
    Jul 2019
    10k including the auto tensioner.
    Jan 2016
    Wow! Sa casa ba yan?
    Jul 2019
    Hindi paps sa mekaniko lang ng tiyahin ko, matagal na sya gumagawa ng sasakyan ng tyang.
    timing belt or "fan belt" ?
    how long did this natamaan na belt last since new?
    some time ago, a banawe mekaniko recommended that i replace my innova's fanbelt.
    after a few weeks, i asked another mekaniko not from banawe, to see if it needed replacement.
    "ok pa po. hindi kailangang i-replace."
    my over-140K km innova has had its fanbelt replaced only once pa lang.
    Jul 2019
    Drive belt/Serpentine Belt
    Jul 2019
    First replacement since binili, ok pa daw kaso sinabi nya wag na dalhin sa malayo since may tama na, usually dinadala namin sa Bicol si Civic so he recommended to replace.
A question on belts in Honda Civic 2015
