Results 1 to 20 of 23
    Oct 2004
    guys i need your help. I am thinking of changing my tamaraw's 5k engine to a diesel engine. Ano kaya ok? Pwede ba makina ng crosswind ? Hanap ko kasi powerful and fuel efficient as well. Thanks in advance.
    2C turbo engines are a straighforward swap into the Tamaraw FX.
    I wonder if the 4AGE will fit? :D
    Or Isuzu's C series engines; C190, C221, C223. But the last engine will require tranny change and engine/tranny supports remounting.
    Oct 2004
    Thnx guys, ok kaya yung sa makina ng isuzu pickup like fuego.
    May kalakihan ang makina ng Isuzu Fuego, baka hindi magkasya sa engine bay. Plus the added weight, that will require you modify front suspension settings to compensate. Btw, were you referring to Fuego 4x2 Standard 4JA1 Naturally Aspirated or 4x2 LS 4JB1T Turbo?
    Isuzu diesel engines:
    4JA1 2.5L - Power=78*4000 (ps/rpm); Torque=17*2300 (kg-m/rpm);
    4JB1T 2.8L - P=100*3800; T= 23*2300
    C190 - P=62*4400; T=?
    C223 2.2L - P=61*4000; T=13.3*2000
    Toyota diesel engines:
    2C 2.0L - P=73*4700; T=13.5*2800
    2C-T 2.0L - P=87*4000; T=18.3*2200
    For reference, your previous engine is:
    5K 1.5L (gas) - P=83*5200; T=?
    Oct 2004
    Thanks ungas for your info. so you are saying the 2c-turbo is the best option for me right now" Balita ko kasi "disposable" daw na makina yun . Mas maganda ata feedback sa 2L kaso mukhang malaki yung makina. What do you think? If i change the engine to 2c or 2L , for sure i will change the transmission gear ratio right?
    May 2004
    my guess is
    if you choose 2c, no need to change tranny
    baka sa 2L, you will do some modifications.
    Jan 2003
    yung disposable po ay yung 2C dahil merong mga plastic parts sa loob. hindi po yung 2C-T (with turbo).
    sir ghosthunter,
    may gumawa na ng 4AGE sa tamaraw. hehe.
    Oct 2004
    thats good news... thanks a121 for the info.....i plan kasi to pimp my ride.....of course since this will be my ride, it has to have a powerful engine as well as a fairly fuel efficient one.......here are my specs:
    Model Make: 92 Tamaraw fx hspur
    color: red
    engine: 2C-T (soon)
    aircon: sanden dual aircon
    sounds: pioneer in dash cd-player w/ ryan audio speakers but i plan to improve the sounds
    seats: bucket seats to be fitted on the front
    wheels and tires: stock lang, ano kaya ok?
    suspension: balak ko palagyan ng coil springs, pwede b yun?
    steering: manual pero lalagyan ko ng power steering heheh..
    alarm: avital with power locks
    before may mega taxi ako fx standard with c190 makina swak na swak yun modify lang yun transmission, engine support and oil pan. yakang yaka ng makina yun body ng fx kayang pag hampasan sa star hway wag lang paakyat hirap sya dahil sa differential ng fx is high speed yata kaya nag palit me ng low speed.
    Oct 2004
    thanks...sakin ata eh low speed ang transmission ko pero gusto ko high speed. tinging ko mukhang viable option ang 2ct kasi bolt on and toyota .... matipid kaya yun sa diesel?
    Yung sinasabing disposable sa 2C engines yung picha, or spacers para sa valve clearance. But I sure did dispose our 2C engine with the vehicle. :D Mahina kasi ang power band.
    I strongly suggest you don't modify any existing suspension part. Better if you just sell the vehicle and look for a coil sprung one.
    Sep 2021
    Quote Originally Posted by geo View Post
    Sir kumusta ung pinalit nyo mg chachange engine rin sana ako
    Sep 2021
    Jul 2013
    way back in 98. nag-change engine kami ng FX
    yung "L" engine noon was too big and baka di kayanin nung front suspension (plus we wanted to avoid changing the radiator)
    We decided to use a 2C engine na Japan surplus.
    It looked very different from the 2C engine na ginamit sa local FX.
    Jan 2008
    sikat yan L engine ng toyota.. yan naka kabit sa hiace.. yung 2C na japan surplus, yan naman nakakabit dun sa toyota previa.. na nasa gitna ang makina..
    Dec 2019
    back 5 years ago i saw an ad on OLX selling a 2L swapped FX in Baguio city. The owner modified the engine bay firewall to make the 2L engine fit inside. L series engine swap is possible without modifying the front suspension. FX uses a front suspension similar to the 1980s 4x2 Hilux.
    Jul 2013
    yup. kaso masyadong mahaba.
    plus change in radiator (larger engine)
    Another benefit of the Japanese 2C (if I remember correctly), adjustable yung valve clearance nya. unlike the local 2C
    you also have to consider that we're talking about a 25 year old car.
Best diesel engine for 92 tamaraw fx
