Page 9 of 48 FirstFirst ... 567891011121319 ... LastLast
Results 161 to 180 of 1853
    Aug 2008
    Good day sirs. Is it normal or, should I say, is it part of the cleaning/lubricating effects of adding 2t if the engine starts exhibiting the following:
    1. No longer starts on 1 click?
    2. Engine sputters at start up?
    My ride started showing these symptoms today. When I started up this morning, it took 3 attempts before it finally started. It started on the 2nd try but sputtered and died. Once it started, it was ok but gave me jitters that it would unexpectedly sputter/die again when driving (fortunately it did not). Again, it happened this afternoon. This time, 4 attempts. 2nd and 3rd tries were the start-sputter-die cycle. The engine always started on 1 click prior to my starting with the 2t. Is this a good thing (meaning it is showing signs of something that will be improved later on)? Has anyone experienced the same thing?
    Dec 2007
    Quote Originally Posted by dbok02 View Post
    It would not have any effect on how your engine starts. You might want to check your fuel filter.
    Check your battery as well. Start-up problem usually is battery or fuel filter or fuel injection having some kind of issue. Puwede din sabay-sabay yan. Baka dahil sa 2T na-dicongest fuel lines mo at nagbara fuel filter kaya sinisinok ride mo sir.
  4. #4
    Same thing happened to an L200 but was addressed after the all injector nozzles were cleaned (P350 labor for all) and a new fuel filter was put in. Probably the injectors got clogged because of the deposits in the injection pump and fuel lines that the 2T oil freed up. Now, it runs with 2T like a wonder.
    Quote Originally Posted by kompressor View Post
    Yeah, probably that's the situation with dbok02 since he is using 2T just recently.
    1. glennm- on and off for 6-7months -diesel
    2. yapoy86 - on and off for 3 months - 4D56, one time on gas engine K10A
    3. bertzus - 13 months and counting - 4D56T
    4. RT - 18 months - 4d56T, 4m40T
    5. valskie01 - 8 months - d4ea(2008 kia carens), 6 months - j3(2012 kia carnival)
    6. mac40-2 days 4d56 Advie
    7. dvldoc 2 years- QD32ETI (1999 Elgrand)
    8. 9701 - 2 months - 4M40T (2003 FM)
    9. coiter - more or less 1 year - TD27 (1998 terrano)
    10. G01 - 5 months - 4m41 (2008 Strada)
    11. regaia - 4 months - 4JJ-TC (2008 Alterra), 3 Months - 1NZ-FE (2004 Vios)
    12. babynos01 - 2 weeks - 2005 tucson crdi
    13. Zhandros - 6months - 4M41 (2009 Strada)
    14. butchyboy - 4-5 months - 4D56 VGT (MS GLSV)
    15. kihmari- 6months- 6he1(1991 isuzu forward), 4hg1(1996 isuzu elf), 4ja1(1998 1.4(2006 hyundai getz),(2009cbr150)
    16. Reepicheep - 2 full tanks (1999 Pajero Fieldmaster 4m40)
    17. kompressor - 9 months (19forgotten Nissan LD20II, 1995 4D56 L200)
    18. D_rock_777 - 6 months - QD32 (2001 Frontier)
    19. MrQ5 - 18 months - 2kd-ftv (2010 Innova G)
    20. Halimaw - 3+ months - 4M40 Pajero Fieldmaster 4x4 M/T
    21. dbok02 - currently on 2nd full tank (4d56 N/A Pajero Gen 1)
    22. otil_flores- 6 months isuzu crosswind 4ja1 matic.
    23. edtf - on & off for a year 4JG2, 4d56T, 2.9 CRDI kia engine (carnival)
    Aug 2008
    Just an update sirs, I just found a leak from the feed pump sensor (the one attached to the fuel filter). Its coming from the small drain valve below the assembly. I believe this is the one causing the hard starting and sputtering of the engine. Had the engine die on me 7 times last night from airport to mandaluyong. The thing is, I had this same part replaced barely 3 months ago due to a similar leak (this was before I started using 2t, fuel filter is also roughly 3 months old). Could this be also due to clogging (assuming the 2t already freed up a pile of gunk from the fuel lines) or to a defective part? Will have the injectors checked and cleaned as suggested though. Also, is there a process for cleaning/purging fuel lines (do I need to have this done)? Hoping things would be ok after this.
    Quote Originally Posted by eminem6480 View Post
    Sir 60 or 65 pesos ang naalala ko. Petron Otis station.
    Mura lang 2t. Nasa 2pesos lang yung maliit na bottle
    Apr 2010
    after about 40kms, my TD27T now purrs like a CRDI no noticeable increase in pulling power but smoke is almost gone. shutoff shudder is almost nil. thanks to doc
    At first we were hesistant to try this, but i insisted it to my dad,since i read many forumers are using it already.haha. after consuming a total of 4 2T oils(1 week interval) from seaoil, the idling and running of our 4m40 engine became smoother, thanks for sharing this! Totoo nga nawala yung "nginig" pag pinapatay yung makina
    Jun 2011
    Ive tried putting more than 5ml of 2t for every liter of fuel.... every time na dagdagan ko ng 2t parang mas gumaganda ang hatak aand nawawala ang usok while on idle.... right now i put approx. 15ml of 2t for every liter of diesel.... so far wala pa din white smoke para ngang gumaan pa ang takbo.... i use only the cheap 2t bought at a local motorcycle shop worth 100 pesos / liter......
    Quote Originally Posted by Arj_11 View Post
    On a road trip up north was able to buy FB rated 2T oil in a Petron station near San Matias, Pampanga (along MacArthur Highway) for only P150 per liter
    Sa mga auto supplies 100per liter lang yun. Hehe
    May 2012
    Saan auto supply eto boss? hehe. Actually Las Pinas area ako. Medjo hirap maghanap sa area namin. Nadaanan ko lang nung napuntang San Fernando.
    Jun 2011
    sa auto supply ng mga tricycle sir dun mura.... may tig 100php lang sila... pag yung petron 2t nasa 110php per liter....
    May 2012
    Thanks for the heads-up guys, will buy sa mga motorcycle shops. Admittedly, there is a big difference in engine response, less smoke, less noise/vibration. Dati umaalog side mirror ko pag naka stop, ngayon hindi na! Also changed to a Baldwin fuel filter. Two Thumbs up!
    Apr 2012
    Kakabili ko lang at kakalagay lang ng Petron Powerburn 2T kay Advie ngayon. Observe ko kung may difference kapag wala at meron. Price: 1 liter-125 pesos, 200ml-30 pesos.
    Jun 2008
    Please include me....
    Ongie 28 - 2 mos - TD27 (2003 Nissan Frontier)
    May 2008
    Iv'e been using 2T for my vios for a few months now, engine is running more quietly and smoother (bear in mind that my car has 125k in mileage). It is also has better fuel economy (not by much). In my opinion if the engine is new you probably wouldn't be able to tell the benefits (NVH reduction and fuel economy) but, if the engine is old the benefits are more pronounced. I dare say that the 2T restored the running condition of the engine to when it was new. Ratio I am using is 1.5 ml per liter. My spark plugs do not have any oil residue. In fact, my mechanic did not advise me to change my spark plugs since its still in good condition, they just cleaned it. HTH.
    Jun 2011
    Quote Originally Posted by regaia View Post
    pwede din pala sa gas engine? pwede kaya sa 2008 focus 1.8?
    May 2009
    ramdam ko pagkakaiba ng may 2t at wala sa accelerator pedal.
Diesel owners that add 2T oil to fuel
