Safe yan.. D4D 2.5 vnt 2T user.. Minsan sobra sobra pa nilalagay ko.. No bad effects naman
1st USE : Shell 2T with decarbonizer
2nd USE : PTT Hi-speed 2T
3rd USE : PTT Hi-speed 2T and so on...
SHELL 2T = SAE 30 / yellow gold color / unscented
PTT 2T = SAE 20 / green color / bubblegum scent
UNIOIL 2T = SAE 20 / clear / lemon scent
200 : 1
200L = 1000mL
100L = 500mL
90L = 450mL
80L = 400mL
70L = 350mL
60L = 300mL
50L = 250mL
40L = 200mL
30L = 150mL
20L = 100mL
10L = 50mL
Adding 2T will loosen all dirt and rust which will accumulate in the fuel filter thru fuel line from tank-to-filter.
The dirt coming from the rusting inside of the fuel tank if any. Inspect the fuel filter to see if there are dirt or rust collected.
Replace the fuel filter if found full of dirt after several full tanks to protect the injection pump and nozzles.
^^^ Is this true? Naglalagay panu dati yung utol ko sa Mitsu Canter nya kaso isang araw pumalya makina yun pala clogged yung fuel filter sabi sa kin yung 2T daw na sinabi ko cause. Told him na the 2T is for lubrication only and his fuel filter might be really due for replacement
Although at first laki talaga nung pinagbago daw nung engine![]()
Exactly... It is necessary and required to change fuel filter whether it is expensive or not. For the sake of the health of our engine.
1st USE : Shell 2T with decarbonizer (JASO FB)
2nd USE : PTT Hi-speed 2T (JASO FC)
3rd USE : PTT Hi-speed 2T (JASO FC) and so on...
200 : 1
200L = 1000mL
100L = 500mL
90L = 450mL
80L = 400mL
70L = 350mL
60L = 300mL
50L = 250mL
40L = 200mL
30L = 150mL
20L = 100mL
10L = 50mL
Why try something else?
2t has earned many various types of reputation evidence & testimonies local & international..
Just my 0.02
Is that the petron diesel booster? To tell you the truth ive been using that prior to the time i was using 2t on my old school pAtrol. it gave it a little more power of some sort but it did not have any effect on the roughness of the engine and emission. FC was about the same.
But when i started using 2t i stopped using that diesel booster. 2t gave me more perceptible effects. But that's just me... you can try it, i think it would not have an adverse effect naman on your engine.
