Page 103 of 118 FirstFirst ... 3539399100101102103104105106107113 ... LastLast
Results 2,041 to 2,060 of 2351
    #2041
    thanks sir...
    about sa egr sir to blank/disable/delete or to clean(intake and egr) nalang regularly? TIA
    Jul 2011
    #2042
    good day sir diesel dude, may nissan eagle ako, for the last two months ay namamatay na lang ito while running pero after ko i pump ung sa mechanical pump nya ay ok na naman siya, mga once a week ko siya na eexperience na ganito,ano kaya ang possible problems nito sir, madami thanks
    Sep 2006
    #2043
    Quote Originally Posted by dh0n View Post
    thanks sir...
    Keep it. Egr problems can be minimized by occasionally driving your car at full load.
    Sep 2006
    #2044
    Quote Originally Posted by pj3378 View Post
    Madaming possible causes. Check mo, baka nakakahithit ng hangin ang pump. Areas to check: fuel filter, fuel filter head, hoses and loose hose clamps.
    Jun 2011
    #2045
    SIR DD where is your shop? can i serviced my egr there?
    Jul 2011
    #2046
    Quote Originally Posted by Dieseldude View Post
    ok po sir, madami salamat
    #2047
    Hi DD,
    I never really became OC with EGR until I experienced stalling and choking in my last vehicle. Based on some research its normally off on idle and will not turn on until normal operating temp is reached by the engine.
    1. So will this be good for short distance driving like 3kms a day where the normal temp is not even reached (parang blanked lang siya) or should I drive more and let it reach normal operating temp? I mean if its not opening, its like blanked and no soot will form right?
    2. Will it help if I do some short high rpm shifting say 2.5krpm during short distances or should it be constant speed at high rpm?
    3. For a 5 day a week short trip (3kms a day), is it okay to do a once a month highway driving to burn some formed soot or should it be more often say 2x a month? Whats the procedure, 2.5k rpm steady for a number of minutes?
    Many thanks Sir!
    Feb 2012
    #2048
    my 1997 Kia Sportage RF TDI 4x4 had a very poor FC. Computed 7km/liter (city driving) with AC ON, driving in a very light traffic.
    Injectors was calibrated twice this year
    Injection pump is new (1 year old)
    Fuel Lifters is new (1 mo old)
    Air Filter is new (2 weeks old)
    Engine Oil is new (10w-30 wid X1R)
    Oil Filter is new (4 months old)
    its suppose to be driving at 12km/liter malayo masyado sa 7km/liter.
    1.) anu at saan kaya ang may problema? bakit lakas uminom ng sportage ko?
    2.) ipa recalibrate ko ulit? kxi nakakaduda ang 2 calibrations
    3.) totoo kaya baka butas na masyado injectors neto? (220k nsa odometer)
    Salamat sa inyong advice.
    Sep 2006
    #2049
    Maganda ba ang andar? No excessive white ot black smoke?
    Injectors was calibrated twice this year Why was injector calibration done 2X in one year?
    Injection pump is new (1 year old) New pump has the same part number as the original pump?
    Fuel Lifters is new (1 mo old) What do you mean by fuel lifters?
    Baka wala sa timing ang injection pump.
    Dapat once lang ang injector calibration kung kumpleto sa test equipment and test data ang diesel workshop.
    Papalitan ko na ang nozzles kung 220k na ang tinakbo nito.
    Salamat sa inyong advice. :
    Sep 2006
    #2050
    Hi DD,
    I never really became OC with EGR until I experienced stalling and choking in my last vehicle. Based on some research its normally off on idle and will not turn on until normal operating temp is reached by the engine. EGR works weather the engine is cold or hot.
    1. So will this be good for short distance driving like 3kms a day where the normal temp is not even reached (parang blanked lang siya) or should I drive more and let it reach normal operating temp? I mean if its not opening, its like blanked and no soot will form right? EGR is open when engine is at idle; and closes when engine is loaded.
    There is no exact procedure. Just drive the car with pedal on the floor occasionally. This will exercise the EGR to open and close, as well as clean the system
    Many thanks Sir!
    #2051
    Hi DD,
    Many thanks Sir!
    Per num 1. Confusing as all articles I read over the net says egr stays closed when idle as if it is open the engine will misbehave causing erratic idling. The way I understand it is that it behaves in extremes. Closed in idle then open mid cruising then closed again in wot.
    Sent from my GT-I9082 using Tapatalk 2
    Feb 2012
    #2052
    No Black Smoke, Ok ang Acceleration, Start/Cold Start, top speed 115Kph. Matakaw lang talaga sa Crudo
    Nagdududa ako sa 1st probably pinagperahan lang ako, pakita ng resibo kunwari, so the 2nd mechanic Recalibrate but he shown to me na maitim na ang nozzle at magaspang na
    Injection pump is new (1 year old) New pump has the same part number as the original pump? YES
    Fuel Lifters is new (1 mo old) What do you mean by fuel lifters? Opps my bad, its Diesel Primer Pump both Filter and P Pump are Bnew
    Bbaka wala sa timing ang injection pump. Hanap ako ng Mekaniko para dito
    Papalitan ko na ang nozzles kung 220k na ang tinakbo nito. Tama Lagi Laspag na ang mga injectors
    Follow-up Questions
    1.) Magkano Budget ko para sa 4 na nozzles? 700 daw kada nozzle?
    2.) Pati ang pagpapa Timing ng Injection Pump magkano kaya?
    Maraming Salamat sa inyong advice. :
    Sep 2006
    #2053
    [QUOTE=van1029;2208117]my 1997 Kia Sportage RF TDI 4x4 had a very poor FC. Computed 7km/liter (city driving) with AC ON, driving in a very light traffic.
    Follow-up Questions
    Hindi ko alam ang tamang nozzle part number........can't give you a price.
    Can't quote, dapat makita muna ang engine para ma-estimate ang labor. Bihira pumasok sa amin ang '97 Sportage.
    Sep 2013
    #2054
    Gud pm, Sir,
    Bago lang po ako sa forum.. May tanong lang po ako tungkol sa engine light ON sa dashboard.
    Bigla pong iilaw yung engine Light ON pag nakahinto po ako, tapos tatabi lang ako at i-turn off ko yung engine. Then, start uli (one-click) tapos wala na po yung ilaw sa engine. Hindi naman po nagbabago yung hatak at tunog ng engine.
    Hindi rin po madalas nangyayari ito. Sa pag gamit ko ng 4 na buwan mga 10 beses pong umulit ito. Lumapit na po ako sa CASA, kaya lang ang sabi nila hintayin ko uling umilaw yung engine light para madiagnose nilang mabuti. Kya lang ayaw magpakita sa kanila eh!
    Naobserbahan ko po, pag nakahinto ako at naghand-brake, mga ilang Segundo lang iilaw na yung Engine light. Ano kaya ang problema? Sana matulungan po ninyo ako.
    Yung VAN ay - 2nd hand, Innova 2006 E, MT, Diesel, 56K – odo; fuel – Diesel V shell
    thanks
    Feb 2013
    #2055
    Ganito yan para madali mo maintindihan at i-explain mo sa casa.
    Di kailangan na magpermanent na check engine light ka para malaman nila na may problema. Ibig sabihin na nag check engine light ka, may problema na sasakyan mo pero intermitent pa ito for the meantime kaya ganun rin ang pag ilaw nya.
    Ipa scan mo ang sasakyan mo sa pinakamadaling panahon bago pa mag permanente na ilaw yan.
    Sa totoo lang, ang engine or ecu scanning ay dapat kasali sa PMS ng mga sasakyan na may ecu, kasi kahit di man umilaw ang check engine light, may mga errors yan na naka log sa memory.
    Sa scanning mo rin makikita kung fuel efficient pa sasakyan mo at yung mga threshold/limits ng mga sensors mo.
    Sep 2006
    #2056
    Tama si siopaona toasted. Meron kang intermittent fault.
    Normally, makikita ng scan tool ang fault ng car kahit off ang check engine light dahil naka save ang fault sa computer box as passive or historic event.
    Mabubura ang passive faults ng scan tool, o sa pagtanggal ng battery connection for a few minutes. Hindi mabubura ang active faults.
    Sep 2013
    #2057
    salamat po... pa check ko uli sa casa...
    Sep 2013
    #2058
    Sir DD, pwede bang dyan mag pa scan sa shop ninyo at magkano kaya ang aabutin?
    Jun 2011
    #2059
    SIR DIESEL DUDE..
    where is your location?
    baka po dyan ko nalang ipadala for repair and check up nung CAR ko na diesel na kinargahan ng gasolina..
    ANYONE here who knows diesel dude shop location?
    #2060
    SIR DIESEL DUDE..
    Central Diesel in Q.Ave. cor. Sct. Magbanua
    Home | Central Diesel (Philippines)
Diesel Fuel Injection System Help Desk
