Results 991 to 1,000 of 2348
- Sep 2006
- 1,335
July 20th, 2010 09:01 AM #991
- Sep 2006
- 1,335
July 20th, 2010 09:20 AM #992I don't have it at the moment........will try to look for it.
Basically, you have to check 3 things:
- Mechanical adjustment of the idle-up lever on the injection pump. It should pull the IP lever to increase idle when the AC compressor turns on.
- Disconnected or damaged vacuum hoses
- No 12v power to the idle-up solenoid.
- Nov 2008
- 210
July 20th, 2010 06:10 PM #993Hi to all diesel guru,
I need your advice. My ride is JDM pajero w/ turbo 4d56 and AT tranny. Bagong change oil, air filter and fuel filter last month lang. Bakit kapag bagong andar at hindi pa mainit ang engine ko very low ang rpm ko then pag mainit na nasa 900 then kung naka aircon naman nasa 1000.
Hindi ko mapatakbo kung malamig pa ang sasakyan dahil sobrang manginginig. Hindi naman siya hard starting just one click lang start na agad and hindi
rin mausok kahit biglan apak sa pedal.
Ano kaya ang problem nito?
July 20th, 2010 07:06 PM #994
Hi Sir Dieseldude
My problem is nag po power loss ung sasakyan ko unti unti decrease nya ng rpm hangang mamatay engine kung hindi ako mag accelerate mamatay engine(when idle)(Ano kaya ang posibleng reason?)i have checked replace fuel filter(baka barado na) checked the fuel line ok naman wala rin bara(nag palit din ako fuel hose)(I read from previous post same problem with mine kahit rekta na namamatay bigla engine) ..and also I have the same problem with the recent post bumaba din ang idle ko pag on ko ng Aircon.(Is there a connection with the first problem?)
Pina chek ko sa kilalang mechanic sabi calibration na daw dapat baka daw may problem na sa rotary pump ng Injection Pump is it possible? (Baka daw kasi)also please do send me a copy of Pajero's idle and idle-up setting procedure. my email is yeye6a*yahoo.com.Thank you
- Sep 2006
- 1,335
July 20th, 2010 10:04 PM #995Hi to all diesel guru,
I need your advice. My ride is JDM pajero w/ turbo 4d56 and AT tranny. Bagong change oil, air filter and fuel filter last month lang. Nag simula ba ang problem pagkatapos ng change oil and filters? Ano ang oil grade na ginamit mo? Meron pa bang ibang ginalaw sa engine mo?
Hindi ko mapatakbo kung malamig pa ang sasakyan dahil sobrang manginginig. Bakit di mo mapatakbo, wala bang power kung malamig? Do you experience white smoke when cold?
rin mausok kahit biglan apak sa pedal. Dapat meron konting usok sa biglang tapak ng acc pedal. Meron bang power pag mainit na ang engine o kulang pa rin?
- Sep 2006
- 1,335
July 20th, 2010 10:14 PM #996Hi Sir Dieseldude
My problem is nag po power loss ung sasakyan ko unti unti decrease nya ng rpm hangang mamatay engine kung hindi ako mag accelerate mamatay engine(when idle)(Ano kaya ang posibleng reason?)i have checked replace fuel filter(baka barado na) checked the fuel line ok naman wala rin bara(nag palit din ako fuel hose)(I read from previous post same problem with mine kahit rekta na namamatay bigla engine) Subukan mo mag adjust/increase ng idle speed.
..and also I have the same problem with the recent post bumaba din ang idle ko pag on ko ng Aircon.(Is there a connection with the first problem?) This is possible...
Pina chek ko sa kilalang mechanic sabi calibration na daw dapat baka daw may problem na sa rotary pump ng Injection Pump is it possible? (Baka daw kasi) This is also possible....
Sorry, wala na akong copy ng ganitong procedure. Search mo sa previous posts, baka makita mo. Calling Rion......
- Nov 2008
- 210
July 21st, 2010 09:29 AM #997Hi to all diesel guru,
I need your advice. My ride is JDM pajero w/ turbo 4d56 and AT tranny. Bagong change oil, air filter and fuel filter last month lang. Nag simula ba ang problem pagkatapos ng change oil and filters? Hindi ko sure kailan nagsimula kasi si misis ang laging gumagamit nito, abroad kasi ako nagwork. Ano ang oil grade na ginamit mo? petron trekker 15w-40 Meron pa bang ibang ginalaw sa engine mo? wala po.
Hindi ko mapatakbo kung malamig pa ang sasakyan dahil sobrang manginginig. Bakit di mo mapatakbo, wala bang power kung malamig? meron naman power but automatic kasi kung tapakan mo ang brake na malamig pa ang engine and naka drive sobrang manginginig ang engine. kailangan i-preheat ko muna for 2-4 mins para maganda na ang takbo. Do you experience white smoke when cold? wala naman white smoke sir.
rin mausok kahit biglan apak sa pedal. Dapat meron konting usok sa biglang tapak ng acc pedal. Meron bang power pag mainit na ang engine o kulang pa rin? wala naman ako problem sa power nito sir. ang problem ko lang ay sobrang low rpm basta malamig pa ang engine. i think mas mababa pa sa 750 rpm.
pinaadjust ko sa taga petron ang idle ko kaya nagiging 900 na but ganun parin kung malamig ang engine very low rpm parin.
thank you for your reply sir
- Dec 2009
- 47
July 21st, 2010 05:00 PM #998bago lang ako sa diesel engine kakabili ko lang ng l400 ko local space gear pag kuha ko after 2-3 days sa akin change oil na ako, change oil filter , fuel filter, air filter lininis lang. then after 2 days nag salin ako ng oil ( may leak kase sa crankshaft oil seal ) pag open ko ng oil filter cap ko may usok so kinabahan agad ako hinugod ko agad dipstick wala pa naman usok dun at walang talsik ng oil after a week byahe ako makati pag check ko ng dipstick ko (hinugot ko ng konti ) may usok na din at talsik ng oil na pa konti konti
kanina nag pa compression test ako sabi ng mekaniko ok pa naman daw
ano kaya cause nitong usok sa dipstick at oil cap?
4D56T engine SPACEGEAR LOCAL max speed niya 80kph pwede pa pigain pero hirap na hirap
hindi ko na alam san ko dadalhin to at saan ipapagawa
btw one click pa din po space gear ko at no overheat hindi rin nag babawas ng langis sa oil not sure minsan ko lang kase gamitin
July 21st, 2010 09:24 PM #999
- Jun 2008
- 41
July 21st, 2010 10:36 PM #1000Thank you for the advice sir Dieseldude. I will check my parts as soon as possilbe.
Those are fair points. It is quite early in the game for the Philippines when it comes to EV...
All New Toyota Corolla Cross
