Results 921 to 930 of 2348
- Sep 2003
- 28
March 14th, 2010 10:01 AM #921Sir, i have a musso w/ a 5cyl diesel engine, I was told that I need to replace the o-rings on the it inline injection pump. Do you have any idea where I can source the parts? I think the injection pump is a bosch. Thanks
- Sep 2006
- 1,335
March 14th, 2010 02:43 PM #922
- Sep 2003
- 28
- Mar 2010
- 3
March 21st, 2010 03:44 PM #924sir otep OIL IN THE ENGINE IS NOT ONLY FOR LUBRICATION BUT ALSO FOR COOLING COZ IT REDUCE FRICTION BETWEEN TWO RUBBING METAL TO METAL CONTACT,WATER IS PRIMARILY FOR COOLING.
BOYKALIKOT42
- Mar 2010
- 3
March 21st, 2010 03:48 PM #925Engine motor oil has a dual function lubricating and the same time cooling.
boykalikot42
- Apr 2010
- 3
April 2nd, 2010 12:50 AM #926
- Sep 2006
- 1,335
April 2nd, 2010 12:15 PM #927
- Apr 2010
- 3
April 2nd, 2010 03:15 PM #928
- Sep 2006
- 1,335
- May 2006
- 138
April 5th, 2010 12:46 AM #930*dieseldude
engine is 4d56 NA in a mitsu L3FB ... problem is ... upon running for a few meters and slowed down or stop, engine shakes heavily that I need to rev the engine higher to keep the engine running ... failing to step on the accelerator pedal would cause the engine to die ... I used to experience this engine behavior when I'm low on diesel but now I am experiencing it even on half or full tank of diesel ... performed the following already: fuel filter check (it's clean/unclogged upon disassembly), fuel lines check (no fuel leak or air getting into fuel lines) ... currently, the engine emits a moderate amount of black smoke when revved. Do you think that the "engine shaking" might have something to do with the injection pump's or injectors' condition?
Let me know your thoughts sir. I would really appreciate them.
Thank you.
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
