Results 1,121 to 1,130 of 2348
- Sep 2006
- 1,335
October 24th, 2010 03:36 AM #1121chief,
Do you check Pajero Fieldmaster?
I am experiencing loss of power, black smoke on flooring or arangkada and high FC. Check / replace air filter before considering any repairs.
Do you also repair/check/parts for fieldmaster turbo?
Please advise.
thanks
- Sep 2006
- 1,335
October 24th, 2010 03:58 AM #1122Hi Sir Diesel Dude thanks for the reply.
Nalimutan ko banggitin that the fuel filter has been replaced as well. Good.
The scan was made at our suking servitek and if i remeber correctly yung brand ng scanner nila was coincidentally innova din. Never heard of an Innova scan tool.
IACV and EGR are still in their original form. No repairs done yet. Did servitek assure you that fixing the IACV & EGR will correct the problem?
Still have to check the fuel supply pump and bleed the fuel lines. You can bleed the fuel supply lines to the pump. I don't suggest that you check the supply pump if you don't have the proper training and tools......... danger due to extremely high fuel pressures. Leave this to the experts.
There are days upon start up it will idle straight away but then there are also those when the symptoms re-appear. On normal driving everything seems to be ok no rough idling, no engine cutting out never pa naman tumirik or nag stop yung engine. This is a possible fuel supply pump problem.
Many thanks You're welcome.
- Apr 2005
- 73
October 25th, 2010 03:34 PM #1123
- Jan 2007
- 31
- Oct 2006
- 14
October 28th, 2010 09:18 AM #1125Sir Diesel Dude,
My problem is engine knocking noise upon start up in the morning, but it disappears after about 30 seconds, okay la ba yun? kasi i had never heard it before siguro mga 3 days pa lang nagumpisa ang ingay. My ride is a 4x2 nissan frontier td27 engine
- Jul 2009
- 26
October 28th, 2010 12:17 PM #1126rasambo:
do you have any smoke when you start up in the morning? what color? white or black? naka on ba ang CHECK ENGINE light mo?
ano ang nangyare sa kotse before nag simula ito? nag over heat ba? nag change oil? more details give way to a better diagnosis.
regards,
ISO4113
October 28th, 2010 01:06 PM #1127
Good morning sirs,
Can you recommend a good, reliable and affordable shop that can clean nozzles/check injection pumps? My hi-lander is nearing 180k kms, medyo mausok na rin even after it has warmed up. Ok naman power pero would like to have it checked just the same.
Thanks in advance!
- Sep 2006
- 1,335
October 29th, 2010 10:27 PM #1128
First step: Check & replace Fuel Filter/Air cleaner. Replace if necessary, and see if emission improves.
180k kms is quite high....definitely, some wear on the engine and fuel system. "Just cleaning" is a misconception. When you bring your pump/injectors to a reputable shop, injectors are cleaned, tested for spray pattern, opening pressure, and backleakage. If failed, parts need to be replaced and calibrated to specs. etc...Pumps, cleaned, disassembled, parts inspected, replaced as needed, then mounted on test bench for calibration (bringing it back to original OE/like new condition)
Regarding smoke: White smoke would indicate a possible engine problem. Black smoke will most likely be related to your fuel systems (pump and Injectors), or air starvation.
Bear in mind that your vehicle has accumulated a lot of mileage.
- Jul 2008
- 935
October 30th, 2010 10:26 AM #1130Hi DieselDude,
tanong ko lang...nagtataka kasi ako kung bakit yung mga diesel engine dito sa atin eh parang ang bilis ata umusok lalo na yung Isuzu? Pero sa ibang countries naman eh hindi. I have a van kasi na galing japan and 260,xxx na yung ODO niya eh hindi naman mausok at wala naman prob sa engine...Ano ba ang mayron sa makina ng mga sasakyan sa ibang banda na wala yung makita dito sa atin?
Xiaomi E-Car
