Results 1 to 19 of 19
    Nov 2004
    Share ko lang sa mga naghahanap ng mahusay na mekaniko na mura maningil.
    Marikina Antipolo area
    0916-5827200
    Boy Romero
    Dati sya Chief Mechanic sa Mitsubishi then Toyota. 20years Casa Experience. Shop nya sa garage nya kaya reasonable maningil at may tawad pa. Kumpleto sa gamit from obd pati pang baba ng engine.
    Gas or Diesel From regular pms to general engine overhaul pati transmission matic or manual ginagawa nya.
    Banggitin nyo refer kayo ni Pao from tsikot ask for more discount.
    Sent from my LG-H870DS using Tapatalk
    Aug 2017
    Will try him out since I live in Marikina Thanks!
    Sent from my EVA-L19 using Tsikot Forums mobile app
    Nov 2007
    Same here. Thank you
    Jul 2016
    Good am mga ka tsikot. Ask ko lang if active pa etong number ni sir Boy Romero. I've been trying to rwach him thru this number but sadly wala ako makuha response. Need kasi ng reliable mechanic near Antipolo area. Maraming salamat sa mga sasagot.
    More power to Tsikot!
    Nov 2004
    Yes ser +63 916 582 7200 pa din number ni "tito boy" as we call him. May pajero sya gawa nung punta ko last month, around 60k daw sinisingil nung ibang several shops, baba ang makina kasi, inabot lang kay tito boy ng 20+k, personal nya kasi inspect at marami daw hindi nmn kelangan palitan, pati pagbili ng pyesa tinuturo nya kung saan mura like bestcolt in banawe etc imbes na isekreto at patungan nya encourage nya pa to canvass yun mismo customer. Pag sya pinabili nyo pyesa pati resibo ibibigay sayo pagkatapos ng trabaho.
    Kalalabas lng ng spacegear namin sa kanya, naputulan ng segunyal, pina tow ko dinala sa reputable shop na mura din maningil sa banawe dun kasi malapit, 90k ang estimate marami daw kasi papalitan. San ko nmn hagilapin yun 90k biglaan pa. Pinatow ko ulit hanggang masinag sa shop ni tito boy, nung matapos inabot lang around 20k labor materials total.
    Jul 2016
    Thank you sir Halimaw! Saan nga pal shop ni sir Boy? near masinag lng din location ko kasi.
    Aug 2017
    Quote Originally Posted by Kapitan tutan View Post
    Sa may Oliveros siya. Just went there for our Revo ATF dialysis. Charge ng labor is 3000. Drain and clean.
    Quote Originally Posted by willownavarro View Post
    labor alone is 3000? how much was the atf and ilang liters?
    Aug 2017
    Yes. Labor alone. Cause he mentioned that other mechanics just drain then put in the new oil, while he on the other hand, also cleans the strainer (? I don't remember the term) and no machine is used. ATF used was Dexron III at 170/L (10liters)
    I told him that Exalta in Banawe charges 600 for labor only. Sabi nya their techniques are different daw kasi.
    di mo nakita how the atf change was done?
    Aug 2017
    I was there. Nag drain muna siya nung oil. Then may tinanggal siya na metal na madumi then nilinis nya yun. Then pagkakabit ulit, saka naglagay nung ATF na 5 Liters muna, tapos kada liter na dagdag, nag drain ng 1 liter hanggang naging clear ang oil. Tama ba process? :/ Medyo namamahalan ako sa 3k actually. But since malinis naman ang output...
    Then it's shouldn't be called ATF dialysis.
    Ginagawa rin yan ng ibang mekaniko nililinis pati yun strainer.
    Aug 2017
    How much normally charge sa ganyan? Yung sa kanya naman is kahit ano papagawa under the hood, sakop na ng 3000. PMS rate tawag nya.
    Jul 2016
    Where is Oliveros? Parang hindi ata ako familiar sa lugar na un. Can you give me direction from Masinag or kahit mga familiar land mark will do. Thank you.
    Oct 2018
    Got to meet mang boy last saturday (oct 13) to repair my chevy spark...replacement of shock mount at tie rod...
    Magaling po siya...makuwento at mahahalata mong maraming alam sa kotse...pati sa trabaho ok sa olrayt...
    Recommended mechanic po si mang boy...
    Nov 2004
    Nice to know nakatulong sainyo sir.
    Yun lancer namin namatayan makina pag mainit na makina, hinala ko maf sensor dinala ko na din sa rapide yun kasi malapit sa tinirikan, maghapon nila dinaiagnose ayun sinukuan di makuha problema pati fuel line kinalas di naibalik maayos. Hinatak ko nlng. Pinasilip ko kay tito boy, wala pa isa oras napatino nya, ayos pa daw maf sensor, linya ng electrical nag loose lng pero need din daw palitan crankshaft sensor. Ayos na nmn problem solved nya as usual [emoji16]
    kapapalit lng din nya ng clutch ng jimny namin, after mapalitan matigas pa din ng konti pedal rinestore nlng nya cable ngyn good as new bulak ang lambot.
    Yun lancer pinalitan din nya clutch.
    Radiator ng lancer may tagas palit bago na pero ang mahal kahit sa motorix almost 10k abutin, may nakita sya sa best colt bago 3.5k lng pero need modify konti mounting. Napaubra nya no trace na may modify pulido sya gumawa di pede gamol sa kanya [emoji23] pag gusto ko ng problem solved result at di puro palusot ng mga makaniko dito sa malapit samin sa manila, dinadayo ko tlga si tito boy, iniiwan ko nlng oto sa kanya sya na bahala mag source ng pyesa etc. Mas tipid at wala pagod sakin kesa magikot pako at palipat lipat mekaniko, pinagsasabay sabay ko na pagawa lahat sa kanya..text nya lng ako pag ready for pickup na oto after ilan days, lahat resibo binibigay nya din. Minsan na sablay din sya syempre tao lng haha yun shifter bushing ng jimny wala sya makita pyesa kya fabricate sya ayun bumigay agad, balik ko daw sakanya pero alam ko mahirapan lng dahil fabricate binilan ko nlng pyesa sa suzuki casa 600 lng pala ngyn ok na. Haba na haha, in short mahusay tlga
    Feb 2019
    Any updates with you guys?
    Also ano po exact address ni sir Boy. Oliveros mismo yung malapit sa simbahan po ba?
    Nov 2004
    Tito Boy updated contact
    0917 166 1213
    Quote Originally Posted by halimaw View Post
    0916-5827200
    Boy Romero
    Is that the place where Oliveros has an uphill right-left twist (if coming from Sumulong highway)?
Mechanic na Magaling at Mura Singil Marikina Antipolo Area
