Page 61 of 330 FirstFirst ... 115157585960616263646571111161 ... LastLast
Results 1,201 to 1,220 of 6586
    Jan 2012
    #1201
    Just bought ZIC A for my next oil change (5,000 OCI muna for the 15,000km service then starting at the 20,000km mark, i'll go FS + Baldwin for a 10,000kms OCI). This is semi-synthetic, 10W-40 and it cost P768 for a 4L bottle and P 218 for a 1L bottle (i needed 5L) from a seller on Sulit.
    768 for 4 liters? Mura yan idol. Ano TBN ng Zic A?
    #1202
    Sir, okay ba Mag-1 engine oil?
    haven't really tried it yet bro but here's its specs:
    Product Details - Mag 1
    Jan 2012
    #1203
    not bad. taas ng Zinc, Boron and Moly
    Oct 2011
    #1204
    Thanks sir, nakita ko sa Ace slighly different viscosity grade. Mag-1 FS 5W-40 and 10W-30 respectively. Ung 5W-40 nasa PHp679.50/Li.
    #1205
    Mga idol, I had to face a dilemma today, nag pa PMS ako sa toyota vios ko w/c uses Delo Gold Ultra...coming from FSyn oil...
    Tapos ito na 10k pms, ang quote sakin 6.1k sa FSyn, 5.6k naman sa mineral, ang liit ng diperensya kaya nag pa Fsyng nako...
    tanong ko lang kung may masamang epekto ba to sa engine?
    #1206
    Mga sir, how do you check what's the ppm safe for gasoline with cat converters? The sulfated ash or phosphorus? Paturo naman. Sa pagkakabasa ko, it should be <1200pm. But how can you check that sa mga engine oil? Thanks!
    Dec 2009
    #1207
    Quote Originally Posted by timykoo View Post
    face value na accept mo yung nakalgay sa PDS nila if meron or sa mga bottle labeling...
    the only way to verify and confirm what is written sir is through Virgin Oil analysis....
    Monarc in libis offers that procedure
    Dec 2009
    #1208
    Quote Originally Posted by ronki View Post
    kasama yan sir sa oil myth, you can always use mineral then switch to FS, or Coming from FS switching to mineral....
    wala epekto yan sir...
    *possible problem is pag meh "inherent nang problem" ang engine tapos ginamitan ng FS with low viscosity,, which could trigger some leaks and accumulated engine gunk to move around...*
    Jul 2011
    #1209
    Quote Originally Posted by miko101130 View Post
    fyi, wala na monarc sa libis. nuvali na ata sya ngayon.
    sir alam mo magkano price ng oil analysis?
    #1210
    Quote Originally Posted by s10pao View Post
    I think Monark retained a small office behind Calle Industriya (the side road going to the Eastwood back entrance). That moved out as well?
    Jul 2011
    #1211
    not sure about this, di kasi ako nagagawi sa part na ito ng eastwood. thanks for info sir.
    Oct 2011
    #1212
    saan sa nuvali? kailan pa lumipat ang monark? nagpa quote ako before kay monark. check ko lang ulit kung magkano.....
    Jul 2011
    #1213
    correction pala, nuvoland (office or display room?) ung makikita ngayon dun sa kanto ng calle industriya at libis
    #1214
    Salamat sir!
    Phosphorus yung dapat below 1200ppm sir. Nasa PDS minsan yang data, minsan wala din. Serhc ka sa net at baka meron, if wala check mo sa B.I.T.O.G nga kung may virgin oil analysis niyan, if wala, stick ka sa gas engine if ayaw mo mag-take ng chance.
    #1216
    Thanks boss! Ano yung phosphorus content ng delo gold, dgu, mobil delvac mx?
    Dec 2009
    #1217
    [QUOTE=s10pao;2095460]not sure about this, di kasi ako nagagawi sa part na ito ng eastwood. thanks for info sir.]
    last time tumawag ako yun address nila eh... parang 1.3k ata singil nila... hindi pa yun elemental analysis... basic testing
    Delo Gold multigrade 15w40= 1500ppm ( hindi puwede)
    Delo Gold Ultra 15w40= 1100ppm
    Delo 400 15w40= 1500ppm (hindi puwede)
    mobil delvac mx 15w40 = afaik <1200ppm din. So puwede sa gas engines din.
    Mobil delvac 1 5w40 = 1090ppm (fully synthetic, puwede din sa gas engine.)
    #1219
    Thanks boss!
    Aug 2010
    #1220
    Malaki ba difference ng 10w30 sa 15w40? For metro manila use
Mineral , semi synthetic or fully synthetic?
