Results 1 to 20 of 6586
    Oct 2011
    haven't really tried it yet bro but here's its specs:
    Product Details - Mag 1
    Thanks sir, nakita ko sa Ace slighly different viscosity grade. Mag-1 FS 5W-40 and 10W-30 respectively. Ung 5W-40 nasa PHp679.50/Li.
    Mga idol, I had to face a dilemma today, nag pa PMS ako sa toyota vios ko w/c uses Delo Gold Ultra...coming from FSyn oil...
    Tapos ito na 10k pms, ang quote sakin 6.1k sa FSyn, 5.6k naman sa mineral, ang liit ng diperensya kaya nag pa Fsyng nako...
    tanong ko lang kung may masamang epekto ba to sa engine?
    Mga sir, how do you check what's the ppm safe for gasoline with cat converters? The sulfated ash or phosphorus? Paturo naman. Sa pagkakabasa ko, it should be <1200pm. But how can you check that sa mga engine oil? Thanks!
    Dec 2009
    Quote Originally Posted by timykoo View Post
    face value na accept mo yung nakalgay sa PDS nila if meron or sa mga bottle labeling...
    the only way to verify and confirm what is written sir is through Virgin Oil analysis....
    Monarc in libis offers that procedure
    Phosphorus yung dapat below 1200ppm sir. Nasa PDS minsan yang data, minsan wala din. Serhc ka sa net at baka meron, if wala check mo sa B.I.T.O.G nga kung may virgin oil analysis niyan, if wala, stick ka sa gas engine if ayaw mo mag-take ng chance.
    Thanks boss! Ano yung phosphorus content ng delo gold, dgu, mobil delvac mx?
    Delo Gold multigrade 15w40= 1500ppm ( hindi puwede)
    Delo Gold Ultra 15w40= 1100ppm
    Delo 400 15w40= 1500ppm (hindi puwede)
    mobil delvac mx 15w40 = afaik <1200ppm din. So puwede sa gas engines din.
    Mobil delvac 1 5w40 = 1090ppm (fully synthetic, puwede din sa gas engine.)
    Thanks boss!
    Feb 2012
    Good pm sir yong Valvoline All Fleet Premium sa Ace Hardware sir ilan po kaya phos. content? Hindi po kasi nkalagay sa website ng Valvoline Asia. Thanks in advance
    Dec 2009
    Quote Originally Posted by ronki View Post
    kasama yan sir sa oil myth, you can always use mineral then switch to FS, or Coming from FS switching to mineral....
    wala epekto yan sir...
    *possible problem is pag meh "inherent nang problem" ang engine tapos ginamitan ng FS with low viscosity,, which could trigger some leaks and accumulated engine gunk to move around...*
    Quote Originally Posted by miko101130 View Post
    Salamat sir!
Mineral , semi synthetic or fully synthetic?
