Page 62 of 200 FirstFirst ... 125258596061626364656672112162 ... LastLast
Results 1,221 to 1,240 of 6586
    Mar 2005
    Sabihan kita sir I might order RP Filter for my Hyundai Santa Fe as soon as mahanap ko na yung tamang fit. So far ang stock ko lang ay pang rav4 Part# 10-267, Jazz 10-2840 and Sonata 10-28-76.
    Anyone tried Mag 1 FMX oils? Any feedback?
    Inspection Data
    Specific Gravity * 60°F (15.6°C) ASTM D4052 0.8522
    Viscosity * 40°C cSt ASTM D445 63.95
    Viscosity * 100°C cSt ASTM D445 10.93
    Viscosity Index ASTM D2270 163
    Pour Point °C (°F) ASTM D5950 -45°C (-49°F)
    Color ASTM D 1500 2.5
    Cold Cranking Simulator at (°C), cP ASTM D5293 4800 (-30)
    High Temperature / High Shear Vis at 100°C, cP ASTM D 6616 7.15
    High Temperature / High Shear Vis at 150°C, cP ASTM D5481 3.2
    Noack Volatility, % loss ASTM D 6375 10.5
    Calcium, wt. % ASTM D 5185 0.169
    Zinc, wt. % ASTM D 5185 0.091
    Phosphorus, wt. % ASTM D 5185 0.079
    Sulfur, wt. % ASTM D 4951 0.252
    Boron, wt. % ASTM D 5185 0.023
    Molybdenum, wt. % ASTM D 5185 0.0079
    Sulfated Ash, wt. % ASTM D 874 0.92
    Nitrogen, wt. % ASTM D 4629 0.102
    Pumping Viscosity at (°C), cP ASTM D4684 18,400 (-35)
    Shear Stability ASTM D 6278 9.43
    Foam Seq. I (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    Foam Seq. II (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    Foam Seq. III (Tendency/Stability), mL ASTM D 892 (Opt. A) 0/0
    High Temperature Foaming, static foam ASTM D 6082 (Opt A) 0/0
    Gravity, °API ASTM D287 34.54
    Copper Strip Corrosion (3 hrs*100°C) ASTM D 130 1a
    TBN, mgKOH/g ASTM D 2896 7.9
    Product Details - Mag 1
    429 pesos kuha ko sa Landmark Trinoma Hardware Store with 10% discount pa dahil sale kanina. Bali 386 na lang per quart. Gamitin ko sana to sa Gasoline Fortuner sa next oil change.
    Sep 2013
    Ang baba ng tbn. Kahit ano oil filter pa gamitin hangang 5,000kms lang.
    Ang sikat ngayon sa bob is the oil guy forum yung fram ultra. The best sa filtration, construction and can go the distance. Yung royal purple oil filter ang selling point nya pang extended mileage pero filtration hindi ganun kaganda for the expensive price.
    Kung tumatakbo kotse mo in a year 20,000kms sulit yung royal purple filter. Kasi kung 10,000km a year lang eh sayang dahil change oil and filter ka na. Mahirap kasi nakakabit oil filter for two years ng walang palitan. Sa america sanay sa mataas na mileage dahil interstate ang byahe kaya nasusulit nila yung synthetic filter naka 20,000kms wala pa one year.
    Example
    Pureone filter - not full synthetic glass media but efficient. Downside is cannot go the distance.
    Fram ultra and royal purple extended- can go the distance but not as efficient as the pureone.
    Dito sa pinas ang makakasulit lang for the expensive price eh taxi at mga delivery van.
    Ako sa situation ko na low mileage every year eh doon ako sa more efficient/filtration filter. 7,000 kms lang takbo ko sa isang taon.
    Yung mga oil filter pinapalagpas nyo ng 1 year? Lulutong gasket sa tagal at malaki probability magleak.
    Jun 2004
    ^ try to use baldwin or fleetguard oil filters para mas maganda filtration even if mahaba ang OCI
    Posted via Tsikot Mobile App
    Aug 2013
    Cmiiw, high TBN ay hindi gaano need for gas specific oil, para sa mga diesel engine oil lang, panagupa sa high acidity created ng diesel combustion.
    Sep 2013
    Pero mas maganda performance diesel oil pag gamit sa gasoline engine mas malinis makina. Mura pa price.
    Sa tbn kasi na 6 or 7 ewan ko kung kaya paabutin ng 10,000 to 15,000kms.
    guys,, was just looking around for oils and i saw some mineral oil with CH ratings for diesel engines.. would a mineral oil with CH rating be better than a fully synthetic oil with just CF rating? thank you guys..
    Oct 2009
    Quote Originally Posted by cocoy View Post
    Common na ang CI rating Castrol and even Petron trekker is Ci and have a 12.5 TBN.
    so what your saying sir, as long as the ratings is either CI or CH nga mineral oil, talo ang fully synthetic nga CF ang rating?
    Quote Originally Posted by povillo View Post
    Mga masters good for ilan KMs ang oil na ito?
    Oct 2013
    Standard naman sir na 10k or 1 year ang mga motor oil.
    Pero parang ang lapot ng oil na yan sir, susunod ko na gagamitin sir is 10W30 na valvoline ata yun from Canada, kaya lang 5 liters lang napadala sa akin, kulang pa ng 1 liter for VVTi hehehe...
    Aug 2013
    mas maganda yung red label na ganito paps. 15W-40 siya, diesel oil na pwede din sa gas engine.
    kapag naka subok ka na ng 15W-40 oil sa gas engine, masasabi mo sa sarili mo na hindi ka na babalik sa 20W-50, ang layo ng performance difference paps.
    semi-synthetic lang ata ito.
    correct if i'm wrong.
    Jul 2011
    check this out delo 400 multigrade.
    1, 600, 000 km mileage. Five Star bus
    http://youtu.be/0hpDWLa14Jk
    Oct 2007
    mind boggling yung 1.6M KM mileage na sinasabi dun sa video ah. Parang GTO-esque na yung claim na yan (for those familiar with that thread) Hehe
    Jun 2010
    1.6m km daw ang na takbo bago mag overhaul ulit
    May 2012
    Aside from shell stations, meron pa ba shell hx7 sellers?
    Any feedback from users of shell hx7 5w40, semi syn?
    Jun 2008
    any MOBIL 1 user here? pahingi ng feedback po.... TIA...
    Quote Originally Posted by mbk347 View Post
    Used it on my vios from 20k to 30k odo. Using Vic filter. Nung pina change oil ko sabi nung mekaniko malinis pa daw pede pa raw di palitan. Pero pinalitan ko na rin.
    Jun 2008
    worth it kaya boss BratPAQ, plano ko mag try ng ibang motor oil, been using ELF for the past 2 years...
    May 2010
    Alin mas ok? Kixx Turbo RV or Zic UP?
Mineral , semi synthetic or fully synthetic?
