Page 330 of 330 FirstFirst ... 230280320326327328329330
Results 6,581 to 6,586 of 6586
    #6582
    So tl;dw:
    GM has a massive engine recall going on. For affected cars they will inspect the engine. If the engine is already out of spec (i.e. damaged) they will replace it. If it isn't out of spec, they change the oil from 0W-20 to 0W-40. Apparently even with the inherent design or manufacturing flaw, having thicker oil is enough to keep the engines from failing. Scientific explantion follows on why thicker oil can be better (higher Hershey number etc.)
    Some other interesting stuff mentioned, like spining the engine faster (revving higher) = more hydrodynamic lubrication. So yeah, revving is good pala!
    Also explanations on how changing viscosity works. i.e. from 5W to 0W it's safe, likewise from a -30 to -40 also safe because the new oil falls within the range of the originally recommended oil, but not the other way around, but also why lower viscosity oil is no big deal if your engine was manufacturer correctly so I guess arguments for both?? Labo ng video haha
    ^ napanood konnga iyan kanina Kasi biglang bumulaga sa timeline ko. Unfortunately, I made it only to the halfway mark before calling it a day. 😅
    Btw, paano ma na attache mo sa post iyong image mo Na taken from the vid?
    Jan 2009
    #6584
    Here's another one:
    And why I insist on going higher up on the allowable viscosity than what the OEM 'recommends':
    #6585
    I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
    Feb 2026
    #6586
    Quote Originally Posted by igiwtf View Post
    whats the cheapest way to maintain an engine? in Petrol or Diesel engine?
    what particular brand do you use?
    synthetic? 10kms interval change oil
    semi / mineral? 5kms interval change oil
    Price difference is nothing to be mentioned, so fully synthetic.
Mineral , semi synthetic or fully synthetic?
