Page 59 of 200 FirstFirst ... 94955565758596061626369109159 ... LastLast
Results 1,161 to 1,180 of 6586
    Quote Originally Posted by red_one View Post
    *Pippo21: since binili mo 2nd hand, replace all fluids unless meron service record stating what fluid was replaced and when it was changed.
    if no valid service record, do the following:
    - Replace engine oil and oil filter
    - Replace coolant
    - Replace transmission fluid
    - Replace brake fluid
    - Replace differential gear oil
    - Inspect power steering fluid (Replace when needed)
    - Replace fuel filter
    additionally..
    - Inspect air filter (Replace when needed)
    - Inspect spark plugs (Replace when needed)
    - Inspect battery (Replace when needed)
    - Inspect tires (Replace when needed)
    - Inspect brake pads and discs (Replace when needed)
    - Inspect and clear air conditioning system
    - Inspect shocks for leaks and perform bounce test (Replace when needed)
    - Inspect wipers (Replace when needed)
    - Inspect U-joints (Replace when needed)
    - Inspect drive belts (Replace when needed)
    - Adjust Idle speed, Idle mixture
    about oil grade, the number before letter "W" practically does not matter because we do not have Winter season. instead, you should consider the working temperature range of the engine oil.
    next, ask yourself what type of oil you want -- mineral oil, semi-synthetic, or fully synthetic.
    Mineral oil - Replace every 5,000 km or 6 months, whichever comes first
    Semi-synthetic - Replace every 7,500 km or 9 months, whichever comes first
    Fully synthetic - Replace every 10,000 km or 12 months, whichever comes first
    ang gamit ko now is Fully synthetic, Petron Ultron Race 5W40, API Grade SN.
    Thanks sa advise sir! Getting ready for a barrage ng fluid changes actually.. budget nalang ang inaantay.. sponsor anyone? Although ung mga madadali na pde DIY, nagawa na like brake pads and fluid and power strering fuel level.. air filter( na napakadumi by the way)
    Ung tranny oil talagang for changing na kasi hirap na change gear when revs are even slightly higher.. pero ung enginr oil kasi golden pa ang kulay pero borderline low level.. kaya im thinking of topping up lang.. kaso nga... aun.. di ko alam anu binatong oil sa kanya..
    Anyway, BTT...
    So 15w-40 SH pde na pala perp change oil na dn para included na ang oil filter hehe
    Samsung N9005 powered by Smart posted using tsikot mobile app
    Aug 2013
    Quote Originally Posted by Pippo21 View Post
    So walang masamang mangyari sa makina kahit maling oil itop up ko? Wala kasi idea kung semi or dino, let alone lapot na nilagay ng mekaniko eh
    Kung wala pa budget, pwede naman top up, use mo medyo low viscosity pero huwag patagalin, a month use is okey lang, change after.
    Sent from my HTC Explorer A310e using Tsikot Forums mobile app
    Mar 2004
    Quote Originally Posted by johnjoseph View Post
    Don't do this.
    Aug 2013
    Don't do this.
    This won't hurt if top up only for just a short time, better than low oil level for a short time...
    Kung ayaw nila, change oil mo na lang. Hehehe!
    Oct 2011
    anynoe using Bardahl FS oil? it is rated API CJ-4/SM.....
    Jun 2012
    Mga GMs tanong lang kakalito kasi ung chart and pinagkaiba ng mga temperature? Ano ba pinaka OK na oil mitsu mirage auto KO and kaya bagay last name ginamit KO 15 w 40 na valvoline OK na ba in tnx
    Posted via Tsikot Mobile App
    Sep 2013
    Quote Originally Posted by wutangclan_79 View Post
    Malinaw yung chart.
    Dito sa pinas mas ok ang 10w40 sa gasoline engine at 15w40 sa diesel engine.
    Personally hindi ako gagamit ng 10w30 or 0w20 sa metro manila lalo na pag summer.
    Dec 2009
    its in the manual, atmospheric temp chart shows different from the one presented here *50 degC viscosity 50, 40, 30, 20 all works the same hunky-dory. lower figure result in better fuel economy, so its up to you what to choose
    in addition it indicates SG or HIGHER thats why in the service manual SL is recommended. btw, the letter S stand for suitable to SPARK operated engines or in other word gas engines. the letter following S indicates the latest or the better oil compared to the other & interpreted chronologically thats why SN is better than SL
    Hi sirs.. just wanted to throw two questions here
    1. any harm in switching from different brands of engine oil per interval (no flushing solutions involved), am using a 5000 km spread.
    2. any current/previous users of Mobil super 1000? parang medyo mura na kasi sya sa ace hardware (and mobil brand at that)
    Sep 2013
    Quote Originally Posted by froztburn View Post
    AFAIK di naman
    nope, di pa ko gumamit ng mobil super eh.
    Aug 2013
    AFAIK, no bad effects on using different oil brands every oci kahit hindi use flushing oil. As much as possible, use sae grade nearest to what's recommended sa car mo.
    How much ang Mobil Super 1000 sa ACE? Ano sae grade niya?
    Oct 2011
    20% off this weekend sale on friday at Ace Hardware MOA for the first three(3) hours 9am-12nn.
    Aug 2013
    Ano mga sae 10w40 motor oil brands ang locally available, mineral or semi synthetic? Try ko next OC this coming June.
    Oct 2011
    Usually synthetic na yan sir pag ganyan ang oil grade.
    Aug 2012
    Manila:
    Average Low = 23C
    Average High = 32C
    Record High = 42C
    Record Low = 17C
    Baguio
    Average Low = 11C
    Average High = 25C
    Record High = 28C
    Record Low = 6C
    Climate of the Philippines - Wikipedia, the free encyclopedia
    So tama lang to get SAE xW40. where x can be any value since we do not have Winter season, i.e. 5w40, 10w40, 15w40.
    Aug 2013
    Ano sae grade ng Mobil Super 1000 engine oil?
    Oct 2011
    15W-40 sir mineral based oil.
    Aug 2013
    Which do you think is better, Mobil Super 1000 or Zic A? SAE 10w40 ang Zic A at semi synthetic Korean made oil, low viscosity sa start up.
    Oct 2011
    mas maganda Zic A sir semi synthetic na yan eh tska API SM/CF lang ung Mobil Super 1000 not unless you get the 2000.
    Nov 2013
    sir saan pala availalbe yung Zic A semi synth?
Mineral , semi synthetic or fully synthetic?
