sir just out of the blue question..
how dirty is our diesel fuel compared to other asian countries.. specally thailand? i think u already know where im goin with this question.
Sir Dieseldude,
Update on my problem, sir my engine is a pajero 4m40 and may lumalabas na usok sa breather ng eninge which is connected sa air filter (when I removed it). When I opened the dip stick oil. May lumalabas din na usok pero minsan wala naman. I have no problem with power. Mahatak naman sha and Hindi hard starting pag umaga. Last february pina-"dukot" ko sha. I changed my piston rings and pinaover sized ko.
Does my engine need an overhaul or kaya mawala ung black smoke if i will calibrate my injection pump?
how dirty is our diesel fuel compared to other asian countries.. specally thailand? I really don't know....., but I'm very happy with our local diesel fuel.
i think u already know where im goin with this question. Yes, I have an idea.
Sir Dieseldude,
Update on my problem, sir my engine is a pajero 4m40 and may lumalabas na usok sa breather ng eninge which is connected sa air filter (when I removed it). When I opened the dip stick oil. May lumalabas din na usok pero minsan wala naman. This is engine blowby (combustion gasses which leak past the piston rings). Blowby is normal, low on new engines and steadily increasing as the engine ages due to normal wear on the rings.
I have no problem with power. Mahatak naman sha and Hindi hard starting pag umaga. Good.. Last february pina-"dukot" ko sha. I changed my piston rings and pinaover sized ko. Nag rebore ka ba ng cylinders?
Does my engine need an overhaul or kaya mawala ung black smoke if i will calibrate my injection pump? Check/replace air filter muna. Then compare smoke levels with and without the blowby hose connected to the air intake system.
Pleck,
Normal ang konting usok/oil sa filler cap at dipstick sa mga high mileage engines.
80kph maximum speed is not normal. Baka barado lang ang air/fuel filters.... or pwede rin na calibration ang kelangan mo.
for those asking on idle up adjustment for 4d56 engine, ito po siya. these are the same ones provided before on this thread.
HTH
here is an explanation on bosch ve injection pump for cold start compensation
nangyari na rin sa akin yan low rpm during cold start (for WLT-31 engine). sira pala yung solenoid valve. pero habang di pa napalitan eh manual advance na lang. in short, depress na lang yung accelerator to attain higher RPM.
thank you again sir..
just want to asked again. if in fact it hasnt been asked here before..
why is it that there are so many isuzu crosswinds that emit black or is just basically smoking..
i was looking at the engine bay of an isuzu crosswind very new model.. and i noticed that there is a water separator before the fuel filter..
this should therefore protect it from water contamination that could cause problems to the injection pump. but it has this device. so what is causing the smoke?
[QUOTE=cocoy;1523222]thank you again sir..
I don't think it is a ISUZU Crosswind-speific problem; rather it is a maintenance problem. A lot of times, rather than replacing the air filter with a new one, 'pinalilinis lang nila' at dito nagsisimula ang black smoke.
The water separator is placed there so that water contamination will be minimized. It does not mean na never na magkaka tubig ang fuel system (e.g. pag hindi mo pinapalitan ang fuel filter na may tubig na. pag napuno yun, papasok na rin ang water sa fuel system.) and its not connected to the black smoke problem. contamination of water would lead to rusty injection pump and stuck up nozzles.
Regards,
ISO4113
Di po ako nakapagrebore ng cylinders sir, kasi need ko ibaba yung engine pag ganun. Do I need to rebore my cylinder liners sir?
I did check and replace my air filter sir. The smoke levels dont change if i put my airfilter and blowby hose in the engine system cycle and still the same result of black smoke without those in place.
