Page 52 of 118 FirstFirst ... 24248495051525354555662102 ... LastLast
Results 1,021 to 1,040 of 2351
    #1021
    Quote Originally Posted by alrorskyz View Post
    thank you sa info. I'm not sure if may solenoid valve ba ang 4d56.
    meron siya. yung #3 po ang solenoid valve sa above pic
    Sep 2006
    #1022
    Quote Originally Posted by chilledoxygen View Post
    Di po ako nakapagrebore ng cylinders sir, kasi need ko ibaba yung engine pag ganun. Do I need to rebore my cylinder liners sir?
    I did check and replace my air filter sir. The smoke levels dont change if i put my airfilter and blowby hose in the engine system cycle and still the same result of black smoke without those in place.
    Black smoke could be due to an injection pump problem.
    Dec 2009
    #1023
    Quote Originally Posted by Dieseldude View Post
    Wag muna. Temporarily replace the black rubber hose between the fuel filter and the injection pump with a clear plastic hose. Tingnan mo kung sumisipsip ng air bubbles ang pump.
    Sir Dieseldude
    Update sa problem ng ride ko..Dinala ko sa calibration center to check yung injection pump ko.I mentioned mga na encounter ko na problems and sabi nila my problem sa rotary pump.. Nang ni chek Aun nga argh may tama nga nag ka roon ng mga gasgas ung pump or distributor (tama b sir ang term ko?) and besides nagkaroon ng oil na dapat diesel lang daw meron dun ( dumaan daw sa O-ring ung oil.)
    After mapalitan ung parts and calibrate na rin nag ok na at nde na namamatay ung engine.
    Ask ko Sir kung bat ganun ung accelerator pedal ko nanginginig once umabot na ako ng 2 rpm pero pag dini inan ko pa apak nawawala naman. Normal ba sir un ? dati nmn nde ko nmn nararamdaman un. Thanks in advance!
    Sep 2006
    #1024
    Quote Originally Posted by DonPempe View Post
    Sir Dieseldude
    Maraming pwedeng panggalingan ang nginig; engine supports, balancer shaft, atbp. Pero kung dating walang nginig sa 2k rpm, baka may problem sa calibration or sa pump installation. Meron naman siguro warranty yung calibration shop na gumawa sayo.
    #1025
    hi,
    i have a diesel daewoo forklift, it spews white smoke at idle and even more smoke when you rev it.
    had the injection pump recalibrated and it seemed to lessen the smoke, but the is still a noticeable amount of smoke.
    had 2 mechanics look at it and they say the engine is a goner, blow-by na.
    but since its just smoke, and its just a forklift used in private property, no problems with law enforcement. so i just kept using it as it is, all smoky as hell.
    but lately, it doesn't want to start, sometimes, when you're using it, it just stalls and doesn't want to re-start.
    have ruled out overheating since i just installed a temp gauge and it was used extensively then whole day yesterday but it didn't stall.
    my only 3 reasons for it exhibiting the problems are:
    1. faulty starter
    2. stalling/hard starting because of blowby??? <-- this one i'm not sure.
    3. gremlins in the electrical system. <-- so very hard to diagnose. but had a relay recently replaced.
    any ideas? thanks!
    #1026
    Your problem seems to be air in the fuel system, or a faulty injection pump.
    okey Sir thank u, if injector pump ang may problem ilan kaya ang magagastos ko dito at ano kaya ang papalitan na parts? taga province "leyte" kasi ako maghanap pa ako ng marunong magcalibrate nito.
    #1027
    Quote Originally Posted by rmpmla View Post
    diba sir para sa aircon lang yun solenoid. kung hindi pa naka turn-on ang aircon hindi pa magfunction yun solenoid. tama ba ako?
    #1028
    for cold start compensation, kailangan ng solenoid valve or mechanism para tumaas yung idle RPM. Hindi ako familiar sa injection pump ng 4D56 engine. pwede rin nag share yung aircon at cold start compensation ng solenoid valve during engine start. best way is to observe similar good running 4D56 engine and see how it behaves during cold start .
    For WLT31 engine kasi eh separate ang solenoid valve ng cold start at aircon. At cold start eh kita ko na na-activate yung vacuum actuator para tumaas yung idle then after 2~3 minutes eh release na ito.
    HTH
    Sep 2006
    #1029
    hi,
    Run the engine temporarily without the exhaust manifold to see if all cylinders are smoking white. It is possible that only one cylinder is smoking..
    1. faulty starter and/or relay, weak battery = no crank or low cranking rpm
    2. stalling/hard starting because of blowby??? <-- this one i'm not sure. Do a compression test. Is the engine consuming oil?
    3. gremlins in the electrical system. <-- so very hard to diagnose. but had a relay recently replaced. Starter relay? Also possible if the pump is rotary and has a fuel shut-off solenoid.
    any ideas? thanks!
    Sep 2006
    #1030
    6 - 10K is the range of repair cost.
    Sep 2006
    #1031
    Tama ka. Idle compensator lang kasi ang nasa Pajero.
    Dec 2009
    #1032
    sorry double post
    Dec 2009
    #1033
    Pleck,
    Normal ang konting usok/oil sa filler cap at dipstick sa mga high mileage engines. 128k palang po tinakbo
    80kph maximum speed is not normal. Baka barado lang ang air/fuel filters.... or pwede rin na calibration ang kelangan mo.
    bago po fuel filter ko
    air filter lininis lang binugahan ng high pressure air 115kph sagad ko pigang piga
    4D56T BTW sir diesel dude magkano po aabutin sa pag papa calibrate?
    #1034
    hd my starter checked out, so far so good. they did some repair on it.
    now its starting better. i'm still going to observe the stalling.
    how do u do a compression test?
    Sep 2006
    #1035
    Quote Originally Posted by pleck View Post
    Pleck,
    Approx. 6K to 10k.
    Check your accelerator cable adjustment. Baka hindi ito sumasagad.
    Sep 2006
    #1036
    Quote Originally Posted by chase View Post
    Compression test is performed with the engine cold and not running.
    1. Disconnect the wire to the shutdown solenoid so that the engine will not start.
    2. Remove all glow plugs in order to install the compression gauge on cylinder #1.
    3. Crank the engine and read maximum compression pressure.
    4. Repeat this procedure on cylinders 2 to 4.
    5. Compare your compression readings with official Mitsubishi service infotmation.
    #1037
    any idea where i can buy a compression gauge? and how much would it cost?
    thanks!
    Apr 2005
    #1038
    Sir Dieseldude,
    Need your usual help here..
    What would be the cause of knocking sound on my TD27 Turbo engine?(Nissan Homy)
    Engine was newly overhauled,calibrated the inj pump & nozzle.My trusted mechanic told me that rocker arm was the problem due to big clearance on cam shaft.Then I replaced with surplus(sariwa) camshaft & rocker arm,unfortunately knocking sound still there.
    The person who did calibration,checked also if the nozzle is the cause of knocking sound but found wasnt.
    Pls advice other possible causes.
    thanks,
    nitram
    Sep 2006
    #1039
    Sir Dieseldude,
    Does knock come from all cylinders or from a single cylinder only?
    thanks,
    nitram
    Apr 2005
    #1040
    Sir Dieseldude,
    thanks,
    nitram
    sir dieseldude,
    not sure if knocking sound came from all cylinders.
    what test need to be done in order to check if the sound came from cylinders?
    will try to drop by in your place for proper diagnosis..
Diesel Fuel Injection System Help Desk
