Results 1,071 to 1,080 of 2348
September 2nd, 2010 01:17 PM #1071
HI! I hope you and Dieseldude doesn't mind. Your fuel filter has been changed last January so it must be needing replacement already. Even if you seldomly use your vehicle like me, I think you should have reached 5000km of travel already since January. It is recommended for diesel engine fuel filters to be changed every 5000km. I hope this will help you in addressing your concerns.
- Sep 2006
- 1,335
September 2nd, 2010 08:10 PM #1072Sir Dieseldude:
So just to confirm - on the BOSCH Mechanical Governor VE pumps, there seems to be NO control of the injection timing advance for LOAD - just for SPEED. Yes.
Is there a provision for injection timing advance on Electronically-governed BOSCH VE pumps? Yes the timing control valve.
You also mentioned that during large increases of load injection timing RETARDS due to loss of fuel pressure. Yes.
If that is so, can it be compensated for by placing a pressure-sensitive valve on the pump restriction/outlet so that losses in pressure are compensated for? An overflow valve is normally installed on the fuel return port. There are two pressure areas on the VE pump; one is behind the timing device piston to control timing, the other is in the housing cavity.
You know on old-model gasoline cars, there is usually a tap to the carburetor's venturi's that connects to a vacuum-advance diaphragm on the distributor.
This serves to advance ignition timing with load - as higher engine airflows result in higher vacuum/depression.
Thus even with engine RPM's low, if you step hard on the accelerator, the high initial airflow causes ignition timing to advance.
If you remove or disconnect this advance line the car's performance is severely affected. Sorry, I don't know much about petrol engines.
Is this lack of timing advance under load one of the reasons older diesel engines don't perform as well as their gasoline counterparts? Mechanical and hydraulic timing devices are limited in their capability to alter timing. The common rail system has solved this problem.
Thanks again.
Dusky Lim
- Sep 2006
- 1,335
September 2nd, 2010 08:22 PM #1073
- Sep 2006
- 1,335
September 2nd, 2010 08:31 PM #1074
- Sep 2006
- 1,335
September 2nd, 2010 08:36 PM #1075HI! I hope you and Dieseldude doesn't mind. All suggestions are welcome in this site.......nobody has a monopoly of knowledge. Sharing is caring.
- Sep 2004
- 161
September 2nd, 2010 10:31 PM #1076
- Sep 2006
- 1,335
September 3rd, 2010 08:35 AM #1077
- Jul 2006
- 78
September 15th, 2010 01:25 AM #1078Sir Dieseldude, our 2005 Starex has white smoke coming out when dipstick is removed. Pero pag hindi naman tinanggal, walang smoke. Tinry ko lang gawin kasi ganon daw pagcheck if the engine has problems. white smoke ang lumalabas. wala naman oil.
Normal ba ito? Walang traces ng oil sa coolant and hindi naman nababawasan ang langis. Very well maintained ang van. The engine is running very well and hindi pa nagoverheat. Wlang leak or traces ng leak sa block. It's crdi. Blow by ba ang tawag dito? Or is this normal? Pag tinanggal ang oil cap when engine is running may tumatalsik na oil pero walang smoke.
- Feb 2003
- 1,038
September 15th, 2010 01:47 AM #1079*Dieseldue
Sir can you pls. give us an idea how do these Engine/Car manufacturers tune or de-tune their EuroV CRDI's engine to suit the EuroII level fuel for other country such as ours. Do they reduce rail pressures or differrent bore of injectors? The only thing that I could see differrent is the power rating mas mababa ng a few horses for same displacement. Thanks.
- Sep 2006
- 1,335
VinFast VF 3
