Page 110 of 118 FirstFirst ... 1060100106107108109110111112113114 ... LastLast
Results 2,181 to 2,200 of 2351
    Ni-set aside muna namin yun problem for a month kasi inayos muna namin yun power steering lines. Now that ok na yun steering ng sasakyan, ito na ang next namin na tututukan.
    As of last Tuesday, same problem pa rin. Nagdecide kami na dalhin ko yun sasakyan sa CDC once magkaroon ako ng free time. May hinala na rin kasi kami ng erpats ko na injection pump problem na ito.
    Found this bro, I think ito problem mo.
    https://www.youtube.com/watch?v=1kQSzbK95W8
    Solution is to replace the front oil seal and a gasket na din sa injection pump gear. Andyan yung zexel part number.
    GENUINE ZEXEL FUEL PUMP DRIVE SEAL PAJERO SHOGUN MITSUBISHI 2.8/2.5TD | eBay
    May 2015
    #2182
    sir dieseldude
    tanong ko lang po kung ano ang factory pressure setting ng denso 20pd32 injection nozzle.
    sir dieseldude
    Jul 2014
    #2183
    i have a 2006 bongo with J2 engine. Where in cebu City can i have the fuel pump calabration increased by 2%?
    i have gone to 3 different places, an no one seams to know what i mean ( i added a turbo so i need 2% more fuel over the complete rpm range)
    #2184
    Quote Originally Posted by txslim55 View Post
    did you go to betan in mandaue?
    Jul 2014
    #2185
    i will give them a try thanks
    Aug 2009
    #2186
    Sir Dieseldude,
    I have a 1995 A/T Pajero with 4M40 engine (Japan unit). It is about to reach 160,000 kms this year. I regularly replace my engine oil, air filter, oil filter, and fuel filter every 5000 kms. Turbo is ok, rebuilt 4 yrs ago, wala naman leaks. So far, the condition of the car is ok, one click in the morning, no idling issues, never been calibrated and replaced timing chain. Napapansin ko lang na medyo malakas na konsumo (estimate ko is 6 to 7 kms per liter) and medyo struggling on ascents and reaching 100 kph.
    Since I want to avoid future problems, I just need your professional advice regarding the ff.:
    1) Is my nozzle tips due for replacement already? Is this one of the reason for high f/c?
    2) Since my timing chain is not yet rattling, adviseable ba na palitan na to, including tensioners and sprockets?
    3) How about injection pump, would you suggest to calibrate it already kahit na wala hard starting or smoke belching (but mine emits smoke under load...3k rpms or more)? Would calibration at this mileage recommended, to improve my f/c, acceleration, etc. May isa kasing Zexel shop na nagsabi baka kinakapos ng fuel delivery yung pump kaya nahihirapan sa rekta....would you agree on this?
    4) Is it possible to test injection pump performance without taking it out of the engine?
    5) My friend said that Japan 4M40 and its rotary injection pump is slightly different from the local 4M40, ano po ba ang pagkakaiba nito? Do you have calibration data for Japan units?
    Thank you very much. Hope to visit your shop one day.
    Jul 2015
    #2187
    Hi sirs,
    Im a total newbie regarding automotives.
    My ride was a Mitsubishi Adventure 2008 GLS Sport
    About 80k yung mileage. Since my family migrated on US eh binigay na ito sa akin ng father ko. The catch is kilala ko yung father ko na hindi maalaga sa sasakyan
    Ask ko lang po if anu ang frequency ng pagchange ng fuel filter? Need po ba na dapat isabay ito sa oil change? BTW about oil change eh yung ako na humawak ng sasakyan eh semi-synthetic na lage ko pinapaoil change which is di ko alam kung ok na ba yung mineral or fully synthetic dapat so nagstick ako sa mid nung dalawa, nasales talk ata kasi ako ng Shell station sa amin na lagi ko pinagpapachangoil.
    TIA
    Sep 2006
    #2188
    Quote Originally Posted by LooserDA View Post
    sir dieseldude
    sir dieseldude
    Ano yung Denso part number ng injector?
    Sep 2006
    #2189
    Hi sirs,
    Ask ko lang po if anu ang frequency ng pagchange ng fuel filter? Replace at least once a year. Need po ba na dapat isabay ito sa oil change? Hindi. BTW about oil change eh yung ako na humawak ng sasakyan eh semi-synthetic na lage ko pinapaoil change which is di ko alam kung ok na ba yung mineral or fully synthetic dapat so nagstick ako sa mid nung dalawa, nasales talk ata kasi ako ng Shell station sa amin na lagi ko pinagpapachangoil. Sundin mo yung nakasulat sa owner's manual.
    TIA
    Sep 2006
    #2190
    Sir Dieseldude,
    1) Is my nozzle tips due for replacement already? Is this one of the reason for high f/c? It depends on the nozzles' spray pattern.
    2) Since my timing chain is not yet rattling, adviseable ba na palitan na to, including tensioners and sprockets? If I were you, I won't replace it.
    3) How about injection pump, would you suggest to calibrate it already kahit na wala hard starting or smoke belching (but mine emits smoke under load...3k rpms or more)? Would calibration at this mileage recommended, to improve my f/c, acceleration, etc. May isa kasing Zexel shop na nagsabi baka kinakapos ng fuel delivery yung pump kaya nahihirapan sa rekta....would you agree on this? Your engine may be starved of air. Check your air filter and turbo boost pressure first,
    4) Is it possible to test injection pump performance without taking it out of the engine? No way..
    5) My friend said that Japan 4M40 and its rotary injection pump is slightly different from the local 4M40, ano po ba ang pagkakaiba nito? Do you have calibration data for Japan units? Yes we have it, we have a complete set of Zexel calibration info.
    May 2009
    #2191
    magandang araw sir Dieseldude,
    advisable ba na via relay yung 12 volt feed papuntang fuel cut solenoid? plano ko lang naman lagyan ng "kill switch" ika nga nila yung circuit neto. pero kung ano abiso mo e susundin ko. salamat.....
    Aug 2015
    #2192
    good day mga sir, ano kaya problema ng engine na 4dr7 bagong palit na piston ring pero bumubuga pa rin ng langis sa dip stick?
    Aug 2015
    #2193
    good day mga sir, ano kaya problema ng engine na 4dr7 bagong palit na piston ring bumubuga pa din langis sa dip stick
    Sep 2006
    #2194
    Quote Originally Posted by kotsebong View Post
    Meron leak ang oil.
    Baka maluwag na ang cylinder sleeves or tapered na ang bore ng sleeves. Nagpalit ka ba nito?
    Baka maluwag din ang piston rings sa ring grooves ng piston.
    Sep 2006
    #2195
    Quote Originally Posted by miked View Post
    Hindi naman makakasama sa makina ang binabalak mo.
    Pero bakit mo gustong lagyan ng kill switch? Meron ka naman ignition/start switch.
    Aug 2013
    #2196
    Sir Dieseldude,
    1997 Hilux 2L engine. 347xxx kms. 5k kms oil change interval. laging bosch oil at fuel filter. every 5k kms linis ng air filter, every 30k kms naman ang palit (replacement)
    napapansin ko sir kapag under load or kapag mag aaccelerate ako, may buga ng black smoke, kapag Euro4 diesel ang gamit ko, less smoke lang pero meron pa din.
    kunyari sir, sa highway, constant 90kph walang black smoke, kapag mag oovertake ako from 90kph to 100kph, may buga na, pero kapag nag constant 90kph or 100 kph or any speed, wala naman usok.
    ano po kaya kailangang i-check? matipid naman sa diesel, wala din oil consumption.
    kailangan ko na kayang magpa check ng injectors? ok naman sir yung acceleration at idling niya, may konting usok lang kapag aarangkada.
    Salamat Sir
    Sep 2006
    #2197
    Quote Originally Posted by innova2013 View Post
    Sir Dieseldude,
    Salamat Sir
    Sa palagay ko normal lang yung konting smoke during acceleration dahil Euro 2 ang engine mo. Mas malinis talaga ang emissions ng mga modelong engines.
    Pwede mabawasan ng smoke yung 2L engine mo through pump calibration. Magkakaroon ng slight improvement ang fuel consumption mo, pero mababawasan ka ng konting torque.
    Aug 2013
    #2198
    Quote Originally Posted by Dieseldude View Post
    Noted Sir.
    Maraming salamat sa dagdag na kaalaman
    May 2009
    #2199
    Magandang araw uli Dieseldude,
    L300 mitsu diesel. hard starting mga isang buwan na (daw). tapos pinacalibrate ang pump. oras pa lamang ang tinatakbo, biglang ayaw na umandar.
    eto mga chineck ko:
    timing check: on the spot lahat ng sprocket. hindi tumalon ni kahit isang ngipin lang.
    leak check: relatively new pa ang mga hoses, clamps at fuel filter/primer (6 months old na siguro)
    may 12 volts na pumapasok sa shut off valve. nagcclick din ito. yung pagclick ba nito ay sapat nang indikasyon na bumubukas nga ba?
    ayaw talaga umandar hanggang sa nalow-batt na. binuksan ko rin injection pipe #1 bago niredondo. walang lumalabas na fuel.
    mayron kayang palpak na ginawa sa calibration o sadyang magreretiro na injection pump neto? estimate ko more than 200k km na tinakbo ng sasakyan. putol kasi odometer/speedo cable. 160 k km ang nasa odometer.
    salamat
    eto mga chineck ko:
    salamat
    Sep 2006
    #2200
    Mag claim ka ng warranty sa nagcalibrate ng pump mo dahil oras lang ang tinakbo ng L300.
    eto mga chineck ko:
    Baka meron vacuum leak sa suction hoses, o sirang sealing washers sa banjo connections.
    Tanggalin mo yung valve & spring sa SOV para makasigurado ka.
    Malalaman mo ito kung mag claim ka ng warranty.
    salamat
Diesel Fuel Injection System Help Desk
