Page 88 of 330 FirstFirst ... 387884858687888990919298138188 ... LastLast
Results 1,741 to 1,760 of 6591
    #1741
    Quote Originally Posted by tool_46n2 View Post
    Ill try going around pero baka sa eldorado nalang muna, do they install kung bibili ako nun power antenna sa kanila? takot kasi ako mgDIY e.
    Kung sa Eldo cubao meron freelance mechanics dun.
    #1742
    PB, the bulbs inside the instrument panel, if im not mistaken, are called peanut/wedge bulbs. the connector is similar to the pics you posted earlier. however, maraming sizes ng wedge bulbs. sa instrument panel lang natin, there are at least two big ones (same size as park lights/ turn signal lights sa cheek)..... the rest are small sized. Kelan ba uuwi parents mo? I can disassemble my dash over the weekend and count how many are needed.
    Pero for dashboard purposes, kelangan natin dito yung "360 degree lighting" model, and not yung unidirectional.... one more thing... mahal din ata at USD8.00 a pop. medyo marami tayo kelangan nito... at least 8 nung small tapos 2 nung large.... actually pati yung compass lights pwede na rin palitan (sumakit ang ulo ko sa dami hehe)
    #1743
    PB, i did a bit of research... our dash lamps are sizes 74 and 158. I assume that 74 is the smaller of the two. If i remember correctly, these are the same size as the Aicon switch lights. hanap ako locally and try to install it in the AC assembly.
    #1744
    the common pajero dash lights are the size 74s indeed.
    kaya lang im not sure whether to go with the twist type
    or the wedge type
    hmmm. come to think of it, pareho lang naman ang socket for the 158 and 74 type bulbs. so going with either shouldnt be an issue.
    Sige PB, makikisuyo na lang ako sa inyo ng parents mo More or less i'll be ordering 20 pcs para meron na rin spares. kaya lang esep esep muna tayo which to order.
    #1745
    .... or better still the SMD type LED bulb (similar to the flash on camera phones)....
    all of them seem to be of the right size.
    http://www.superbrightleds.com/cgi-b....20847&next=50
    May 2007
    #1746
    need your advise.......
    Can I do a direct replacement of the headlight bulb using a 90/100W or do I need to have those relays added para kontra-sunog daw?
    TIA
    Mar 2003
    #1747
    PK diyan sa superbrightleds ako bumibili, nakabili na ako sa kanila dati, diyan ko din oorderin yung pang instrument lights, ako bahala sa pag papauwi, ikaw sa size kung kasya, what do you think? gusto ko yung smd type, $2.50 each x 8 plus 20 bucks, mga 1,600 pesos. need to know asap kasi november 2 uwi nila, plus 7 days shipping. game ba?
    boss melto, yes you need headlight wiring kit,
    #1748
    Quote Originally Posted by melto View Post
    TIA
    Relays + Ceramic H4 Mount para safe. Mura na lang ngayon yung ceramic headlight mount... kahit sa ACE meron na ata for P200+ a pair.
    #1749
    Boss PB, can i get 14 Pcs of the SMD type? in white siyempre Pati yung sa A/C papalitan ko na rin plus mag spare na tayo para safe. Sure ka 8 lang sa instrument panel?
    Pwede naman natin i-dispose ito sa mga bagets if ever hindi magkasya.... pero im sure paso ito sa dimensions ng stock bulbs.... question lang is if it will hit the "light distribution" clear plastic thingies.
    pero in any case PB GAME NA GAME AKO!!! Go Go Go!!!
    #1750
    PB, looks like extended length talaga yung mga dash LEDs, if we were to do it DIY, ganun din lalabas...
    http://www.bluepoof.com/motorcycles/...led_dashboard/
    Pero the project looks promising....
    May 2005
    #1751
    Quote Originally Posted by pajerokid View Post
    or the wedge type
    Pasali nga sa usapan nyo. Wala ba available nito locally?
    #1752
    none that i know of larshell.
    #1753
    Okay PB here we go.
    It will be a tight fit but i believe we have an extra 4mm to fit the bulb below.
    WLED-x5 / WLED 5-LED Wide Angle LED bulb
    We need 4 of these on the instrument panel. Please get me 5pcs in para may spare. color white po (not warm white pare) This is the one which goes for P2.99 each. mas okay ito kesa ibang model coz 220 degrees yung ilaw and very bright.
    Aside from this there's also one #74 bulb for illumination, also palitan na natin yung sa Air con switch para pantay... so all in all, we need three #74 bulbs... please get me 4 in white din pare Lets go for the kill and get the SMD type para bulag tayo sa liwanag.
    I noticed the pajero's instrument lighting is sealed (talagang backlit), unlike honda lighting (sa eg civic for example) na splash lighting... tipong from the sides ng meter lumalabas yung ilaw. I think getting the SMD will pay off.
    So in summary 5 na White WLED-5 and 4 74WHP. Later ko na tirahin yung brake lights.... interior muna. Thanks PB!!! sana umabot tayo
    Mar 2003
    #1754
    copy that PK, congrats super mod kana pala, ginabi kana sa pagbaklas, sana nga umabot, may wildfire pa naman sa california, dun sila based. hindi nagonline cousin ko, but i left her a message of our orders.
    nagorder din ako ng leds for the compass.
    medyo magkaiba ng color yung wled5 7500k sa 74whp 5500k.
    iniimagine ko nga kakalabasan, sana maging puting puti yung numbers natin, and yung needle glowing bright red. pag makita mo yung gen 4 na dash ang ganda ng kulay ng needle buhay na buhay pati shadow meron.
    May 2005
    #1755
    Another question mga Masters. May dimmer yong instrument lights diba? Gana parin kaya ito kung palitan ng hindi orig ng bulb or led light?
    #1756
    ask ko lang po.. mga pajero experts..
    diba.. ang ordinary bulb... 50/55 watts?
    and ang hid is just 35 watts lang?..
    nag diy ako ng install ng hid.. ayaw gumana..
    tapos... dinala ko nalang sa shop...
    sabi nila... kelangan daw ng.. relays... since nakabaklas kotse ko pinagawa ko nalang..
    totoo po ba? hindi kaya ng stock wirings ng mitsubishis, toyotas and nissans mag hid? hondas lang daw pwede ganun?
    ang tanong ko sakanya.. diba mas mahina kumain ng kuryente niya? ang sabi niya naman is.. kumakain din daw ng kuryente ballast..
    so.. pinagawa ko nalang without research.. inabot 900 pesos.. mahal pala.. ganun po ba taaga presyo ng.. relay and rewire? nagsesearch kasi ako sa internet.. nagtataka ako kung bakit. wala ako nakikitang nagkakaproblema ng ganun...
    btw.. my hid is.. 35watts.. na hi-halogen low-hid
    tnx po for reading
    Mar 2003
    #1757
    AC naka Hid ako dati, dapat kasama na yung relay sa wiring harnness ng binili mong HID, dapat di mo na kailangan kasi plug and play na yan, saksak lang yan sa socket ng H4 mo. unless nalang na walang kasamang harness/relay yung hid mo.
    larshell, I'm using Led sa gen 4, gumagana parin dimmer sa LED,
    #1758
    Quote Originally Posted by larshell View Post
    depends on the LED model if flexible yung voltage.
    #1759
    hehe tagal na akong super mod PB, pero i noticed naging red nga yung handle ko Thanks so much for accommodating me in the order pare! Ano ba gamit sa compass? wedge bulb din ata right? pero yung compass itself alam ko special na bulb kelangan.
    OT Pare, may bowling lanes ba sa subic? baka magbakasyon uli ako dun this long weekend.
    Oct 2007
    #1760
    HI! I'm just new here, yeah, registered a few minutes ago. Anyway, I have the same problem as phildg2000. Only mine is Pajero 2001. And, yeah, Aguila is, indeed, having that problem. Can anyone be of help, please? Been driving around with a shattered glass for almost three weeks now! Will appreciate any info.
    Oh, this site is great! Andami kong natutunan.
