yan na nga ang pinagtataka ko eh.....what could be the cause nung pagka baliktad niya...
Mga Pards, patulong naman. Hindi kasi bumubusina yung 99 Fieldmaster ko thru my steering wheel horn pad at napilitan muna akong magpakabit ng temporay wiring at push button sa left side ng dashboard para lang may magamit ako. Medyo cautious kasing gumalaw ang mga Technicians dito sa amin sa Batangas City kasi delikado daw dahil nung airbag. They're suspecting na sira na yung lock spring inside the steering wheel and I have to replace the airbag assembly which is costly. I have yet to prove this kasi nga ay di ko pa napapabuksan yung steering wirings. I'm hoping na may na-disconnect lang or something.
I want to retain yung safety ng airbag and humanap ng possibilities na magagawa ito ng di masyadong costly. Plano kong lumuwas next week at maghanap ng pupwedeng mag-troubleshoot o mag-repair. Any idea mga Sirs kung saan ko siya pwedeng dalhin dyan sa Manila (Evanagelista or Banawe?). Maraming salamat po.
Piraeus, Nawalan din ako ng busina 6 months ago on my 99Fieldmaster. But when it happens kasabay iyon ng pag pula ng SRS indicator sa dashboard. What we found is that the electrical assembly that connect the horn and airbag was cut open. The assembly is like a wounded flexible wiring with multiple strand. The electrician can no longer repair the cut so i have to buy the assembly at El Dorado for 7K pesos. Just bring your ride to experienced electrician and they should know what to do. Yes, do not attempt to remove it yourself as the airbag might explode.
cargoboy, sayang nahuli na, thanks sa offer bro, nagpafabricate na kasi ako ng new bushing, pa PM naman saan location mo and how much mo benta?![]()
sa sticker 3.5k or 4k yata kuha ko, not sure kung tama alala ko, basta naalala ko binanggit ko si PK kaya nagless pa ng 500.
kung may family ka US meron ako nabili na LED 150 pesos each lang, 9 leds siya. ganito gamit ko, Attachment 9949
Ask ko lang, mey sira kasi un antenna ng aming Pajero 2.5nd Gen. It doesn't fully retract all the way down, which should be when you turn off the vehicle. Dun sa Paj namin, it just stops midway, but you can still hear the motor of the antenna running.
ANo kaya parts involve dito, and magkano at saan kaya ok paayos un ganitong problem? For those who had similar problems, please share naman kayo about it.. Thanks fellow tsikoteros!
CargoBoy, thank you very much for your advise. Sabi ng nakausap kong Techinican na dating taga-Mitsubishi ay clock spring nga daw iyon na parang wire coil sa loob ng steering wheel. Pag may wheel alignment daw na ginawa sa Paj natin at ini-adjust yung steering wheel, minsan eh nawawala rin sa alignment yung pagkakakasa ng steering wheel natin compared sa designed position nito versus the clock spring.
In effect daw ay magko-kontrahan sila ng pwersa hanggang sa maputol na nga yung wire coil sa loob. Di pa naman pumupula yung SRS indicator ko so susubukan kong patingnan sa kanya bukas. Baka may pag-asa pa. Salamat ulit.
P600 po per pair. kaso tight fit dun sa saksakan sa door so medjo pwersahan. At the end of the day sulit na sulit. Ang liwanag and kitang kita mo pag gabi kung basa or marumi yung aapakan mo...
Ganito yung nabili ko.... sayang meron palang 6-LED model. Pero the 4-LED beats the crap out of stock hehe... ang puti puti pa ng light.
By the way mga pards, meron na ba kayong nakitang LED na pang backlight ng dashboard?
parang ganito?
http://www.autobulbsdirect.co.uk/pro...cat=733&page=1
Gawin nating Optitron yung mga interior lights natin hehe
nagbukas akon ng ganyan dati (frontier 2.7E) na power antena... yung plastic gear will "uncoil" (parang jack-in-the-box) pag binigla mong bukasan (after i-unscrew ang mga screw bigla kong inopen).
but then again hindi naman mahirap ibalik (maraming grasa lang ang lilipat sa kamay mo kasi puno ng grasa yung plastic gear). I just powered it back (using my airsoft 7.5V battery). Reverse mo lang polarity kung baligtad ikot.
btw, afaik, nagbebenta ng antena rod lang (no need to get the whole power antena) at P900 dati sa el dorado (4 years back).
hahapero ang liit masyado ng kasyang tweets.
saw a pic of your LED mura kuha mo, kasi nakita ko rin sa online site na binilhan ko yan, mas mahal pa nga yan sa binili ko, hi power LED nakalagay sa description niyan, kahit mas konting leds, I also saw a double contact LED for tail lights, 30 bucks each, 3 watt na LED gamit kaya malakas daw, tapos naalala ko apat pala tail lights natin, anak ng tokwa 120 dollars plus tax and shipping pa, kalahating buwang sahod, di nalang,
I like your optitron idea, tapos sabayan ng dimmer, and naka on kahit umaga, kaso di ko alam exact bulb type, have you seen the actual bulb? uuwi parents ko for halloween baka pwede ko pahabol, 74 wedge base instrument lights nakalagay. yung ordinary cost $1.20 (top picture) each and high power $2.50 (bottom pic). Tingin mo kasya sa pajero natin to? if you want pasabay ko na kung gusto mo? di naman ganun kamahal. oorder rin kasi ako ng leds, I like the hi power leds,
Attachment 9964
Attachment 9965
tool_46n2, Im not so sure kung pwede siya ipasok agad yung antena mast, kasi maiiwan sa loob yung kaputol ng plastic ng antena sa loob, unless lumabas din yung kaputol. baka pag pinasok mo agad magbuhol sa loob, nung kinalas ko kasi dati yan tinanggal ko buong assemby, once nabuksan na tsaka mo makukuha yung kaputol, tama yung sinabi ni boss wildthing very messy yan, kaya kung may date ka kinabukasan wag mo gagawin yan, I'm sure puro itim kuko mo niyan,![]()
