Page 78 of 330 FirstFirst ... 286874757677787980818288128178 ... LastLast
Results 1,541 to 1,560 of 6591
    Mar 2003
    #1541
    larshell, 1,500 lang for the filter, and 9 liters for atf, I used 3 liters for flushing, may naiwan pa kasing atf sa torque converter. 140 per liter sa caltex. and sealant, wala daw kasi talagang gasket yung transmission oil pan, imho di na kailangan buy new filter (pero sabi sa casa need daw replace), screen lang kasi siya, kaya pwede linisin lang. ang talagang kailangan malinis is the pan and filter, kasi doon natining mga dumi.
    #1542
    Gurus - i drained completely my fieldmaster atf replaced it with Shell ATF, pan and filter were cleaned also. Prior to ATF replacement i'm enocuntering blinking A/T indicator on my dashboard at unknown frequency - it just blink without noticeable cause. I thought my Auto tranny just need fluid replacement to get rid the blinking A/T indicator but i was wrong. Would you know the reason of blinking A/T on dash inspite of atf fluid has been replaced? Thanks to your help.
    Mar 2003
    #1543
    di naman umilaw saakin after oil change, did you use dexron 2?
    Aug 2007
    #1544
    Hi i am a newbie here, i am purchasing a gen 2.5 pajero and i opened the oil cap and the oil was splatting out, but not strong.. is that normal for a 4m40 engine? please reply
    #1545
    Yes it can be normal for almost any engine.
    Mar 2003
    #1546
    peeps kung medyo may play na gear shift (AT) niyo, and vibrates kapag mababa ang rpm, replace niyo lang gear shift bushing, 300 each you need 2 pcs. pagkalas ko wala na yung bushing nadurog na siya, super nipis lang kasi siya na plastic ring. thanks to pajoz for this info. nabawasan na ng isang ingay cabin ko.
    #1547
    Question lang sa mga tsikoteers.
    May nakakaalam ba sa inyo kung saan ako makakabili nung sticker sa front fenders nung Pajero FM? the one that says "PAJERO" (Color Dark Brown/Gold) and also the Oblong shaped that says "Field Master"? I need a set of pairs ASAP coz im having my FM repainted next week. Eh pag tinaggal masisira yung color niya. A friend of mine tried it before, nasira lang color nung sticker. Ayoko naman ng tape tape lang.
    Can someone please help? your posts will be greatly appreciated. thanks in advance!
    #1548
    Yep. Bumili ako sa Eldorado and Mitsubishi Quezon Avenue niyan dati and pinadala ko sa U.S. Around Php777/ea yung PAJERO badge. Yung FM badge, around Php151/ea (mas mahal pa yung bentahan sa Banawe).
    #1549
    Thanks sir Otep.. Badge pala at hindi sticker hehe. San ba yung Eldorado? yun ba ung sa megamall? san po kaya mas ok Eldorado o Mitsu Q Ave.? and curious lang ako napansin ko kasi yung P-A-J-E-R-O badge per letter.. per letter ba ang bentahan nun? sana nga sir ganun lang price kasi may nakapagsabi sakin sa ang mahal daw nun.
    #1550
    Yep. Meron sa Megamall pero sa Paco ako nakakuha dati. Sa Mitsubishi Quezon Avenue, ko nakuha yung mga PAJERO badges. Yung mga Field Master ang sa Eldorado.
    The PAJERO is sold as a whole word. Pre-aligned na yung mga letters. You stick it like a sticker, tapos peel off the front part and maiiwan yung mga letters na nakadikit sa body.
    #1551
    sir otep, nagtanong po ako sa el dorado kanina.. 1200 daw isang set nung PAJERO? And ung Field Master is 300 each.. mahal pala. It'll set me back total 3K for 2 sets, just for stickers. ill try calling Mitsu Q Ave. tomorrow baka masmura.
    #1552
    Baka naman talagang nagmahal na? Sa Quezon Ave. they can sell surplus badges off wrecked units if meron sila.
    May 2005
    #1553
    Mas ok narin siguro na pinalitan mo yong filter. Pag luma na kasi mas maulwang na yong butas ng filter.
    Saan nakakabili ng bushing?
    Mar 2003
    #1554
    larshell, sa motorix yata binili, thanks to pajoz for the bushing fix. sobrang nipis lang ng bushing, its the black ring sa pic. dali lang palitan, look at my pic kulay kalawang na yung metal frame, ngayon ko lang kasi nabuksan. di ko alam saan nanggaling parang pulbos na kalawang. nilinis ko lang with oil. habang nakakalas it would be good idea na ilipat yung rear aircon switch sa tabi ng 12volt socket (in front of transfer case lever. nakatago kasi yung switch, mas madali makita kung naka on rear aircon kasi umiilaw siya kaysa nakatago sa side. extend mo lang mga wires, idea ni PK to, ginaya ko lang
    Attachment 9290
    May 2005
    #1555
    Ok yong Idea na yon ah! Thanks for sharing. Akala ko mahal yong bushing nayan kaya nung kalasin namin yong a/t shifter ko nag cut nalang ako ng plastic container pamalit sa bushing pero parang bibigay na ulit kaya pag sinipag ako this weekend papalitan ko narin ng totoong bushing.
    Aug 2007
    #1556
    Magandang Araw po mga tsikoter! bagito lang po, mawalang galang na po. Ask ko lang po mga magkano presyo ng 2000 FM 4x4 A/T & M/T ngayun? maraming salamat po
    May 2005
    #1557
    99 Pajero FieldMaster is Around 700K-780K depende sa condition. 2000 Model Pajero 4WD is rare but price is ranging 750K-830K.
    Aug 2007
    #1558
    Quote Originally Posted by larshell View Post
    sir larshell, maraming salamat po!
    oki din po ba yung mga gasoline engine (V6) na pajero/montero? what is the Fuel Consumption ng mga ito?
    saan/sino po ba ang ok na 2nd hand car dealer?
    salamat po uli
    May 2005
    #1559
    Kung kaya ng budget mo consumption ng V6 I will suggest go for Montero. For me kasi Montero is better than Pajero (IMHO) BTW Fuel consumption of V6 engine 6G72 is around 4.5km-6km/lt. depende sa mood ng driver.
    I don't know any used car dealer who is trust worthy. If you are going for Montero ingat ka lang sa mga Pajero who is labeled as Montero. Always look for the registration and see if it is registered as Montero. Speedometer of Montero is miles/hr not Km/hr. USDM or Montero has bin# plate sa dash board sa driver side just beneath the windshield. Marami sa market ngayon na China version and labeled as Montero. One more thing china version is leaf spring Orig Montero is coil spring ang rear suspension.
    Aug 2007
    #1560
    sir larshell
    maraming salamat to your enlightening tips malaking tulong ito sa mga katulad kong walang muwang sa mga ganitong sasakyan.
    more power to you & to all tsikoteers.
