Page 101 of 121 FirstFirst ... 5191979899100101102103104105111 ... LastLast
Results 2,001 to 2,020 of 4331
    Jul 2019
    *xiss - oo nga pala yung extra buttons sa infotainment system.
    *Jut - Sir, ang ganda ng set up ng interior ng civic mo. I cannot send you a PM kaya dito ko nalang itanong. Care to share yung part number ng leather shift knob? Or yung taong nakausap mo sa Honda QAve para ako maginquire personally sa item? Salamat.
    Problem lang nung nung unit ko is merong mahabang scratch sa right rear passenger side window nung nirelease siya from dealership. Naiisip ko na Baka dahil sa pagkabit ng tint kasi mukhang dahil sa cutter yung scratch. Good thing they will replace the window pagbalik ko after a month.
    Jun 2016
    Quote Originally Posted by stick_man08 View Post
    Sir san nyo nakuha unit nyo po?
    Looking for 2019 rs model pero till now wala pa daw sa sta rosa at alabang. Looking forward for your reply po. Thanks
    Jun 2016
    Any thoughts on Civic 1.8 S or E as a family car? Torn between this and the Rush, will also be driven by my wife whose height is only 5'.
    Quote Originally Posted by reiman13 View Post
    Kahit yung lowest trim model ng Civic is much better than the Rush. If you want to be practical, even the mid level trim of the City will do for a family car, assuming 5 or less lang kayo.
    Jun 2016
    Yes sir, lowest trim lang talaga yung target either S or E. We currently own 2013 Vios and 2016 Swift, gusto na namin i dispatch yung Vios and upgrade. I prefer the Civic because of the comfort, ang hirap lang iconvince ni esmi kasi low ground clearance daw and petite pa siya.
    Aug 2016
    Driver height not much of an issue. Wide range of seat and steering wheel adjustment. Ground clearance is not an issue either. Mas sayarin pa nga pag po pa-syete nyo approach ang ramps and humps. Approach with reasonable speed, of course, as the dampers are tuned for more comfortable (aka soft) damping but react well enough in high speed maneuvers to limit body roll.
    Apr 2014
    I assume your family doesn't need 7 seats since you're considering the Civic as an option. Aside from the Rush's 7-seater capacity and higher ride height, it doesn't really offer any significant advantage over the Civic. The Civic has better fit and finish, a more powerful engine, a more comfortable ride, and impeccable handling. Not sure about fuel economy, but seems like the Rush's body is too heavy for its 1.5L engine, which could mean negligible difference between the two (don't take my word for it, though!). As for reliability, Honda is at par with Toyota, and maintenance for the former is only every 6 months, which means less time spent for visits to the casa.
    Your wife should be able to drive it just fine -- my mom is the same height as her, and she doesn't have any troubles driving my Civic.
    If you could spring for the E variant, I say go for it. The additional features over the S will be worth it in the long run.
    Apr 2014
    Anyone else who's had their fender light bulb replaced already? Just discovered that the light on the driver's side is already busted. Civic's 11 months old pa lang... Is it advisable to wait for my PMS and have this done at the casa since the next maintenance is just less than a month away or is DIY better?
    Jul 2019
    Quote Originally Posted by yitori View Post
    Sa Honda Makati ko po nakuha unit ko. Yun kasi malapit sa bahay. Almost 2 weeks ako nag antay since by order siya. Mga mid June ako nagdecide sa unit na platinum white pearl.
    Siguro by order din hanap mo kasi dami parin kasi akong nakitang stock sa dealership ng 2018 RS Turbo both sa Makati at Kalookan e.
    Sir Jut - ok na po pala yung sa shift knob. Nahanap ko na yung part number. Salamat po.
    Aug 2015
    Honda Rizal/Cainta- along Ortigas Ext.
    Jun 2016
    Quote Originally Posted by xiss View Post
    Thanks a lot po. I will try to call them later po.
    Salamat ng marami po
    Jul 2019
    Guys, mag ask lang sana ako kung anong items ang meron sa PMS niyo for the first 1000km or 1month PMS. Ang alam ko kasi is more on basic checks lang siya sa auto e. like if may mga leaks or other mechanical issue. Baka kasi alukin ako ng mga kung ano ano sa casa. Currently 400+km palang ang natatakbo ng civic ko.
    TIA
    Nov 2011
    TIA
    Free lang 1st PMS. Inspection lang.
    You'll be done in less than an hour.
    Jul 2019
    Quote Originally Posted by TheUninvited View Post
    Ok po. Salamat.
    Medyo matatagalan siguro ang 1st PMS ko since they’ll be replacing the right rear window since meron siyang malalim na scratch. I guess during tint installation from the cutter na ginamit
    Napansin ko pala, hindi nagwowork yung turn by turn navigation pag apple carplay ang gamit mo
    Pero pag naka android auto, it works perfectly.
    Nov 2011
    Android Auto all the way
    Aug 2015
    Bro, did you buy a screen protector for your HU?
    Jul 2019
    May nakaexpereince na ba sa inyo na nawala yung navigation option sa display niyo? 2019 1.8E yung model nga pala nung sakin.
    Tried both apply carplay and android auto and nawala na yung option niya na ganito.
    Aug 2015
    Have not experienced that. Were you able to fix it?
    Jul 2019
    Unfortunately, ayaw na niya magwork. Nagtry narin ako ng hard reset ng HU pero wala parin.
    Tried checking other online forums and mukhang sa update na ng phone ang nagiging cause ng ganito.
    Feb 2018
    Hi mga sir. Ask ko lang if iaavail ko pa yung rust proof sa casa or no need na? Kasi diba na rust proof na sya? Tom baka makuha ko na yung unit. Thank you!!
All New 2016 Civic
