Page 104 of 121 FirstFirst ... 45494100101102103104105106107108114 ... LastLast
Results 2,061 to 2,080 of 4331
    Feb 2018
    Quote Originally Posted by stick_man08 View Post
    Sir Paw, Pristine Acidrain watermark Remover sakin. Di ko alam magkano price nun kasi binigay lang sakin.
    Every month ako nagaapply niyan after normal carwash.
    Sige sir. Nakita ko nasa 300 din sya. Salamat sir[emoji3]
    every month all over the body? is your coated or sealed?
    Nov 2011
    Careful lang sa mga acid mark/rain remover.. it can damage your glass permanently.
    Ako gamit ko lang is Rain-X cleaner saka protectant.
    Quote Originally Posted by TheUninvited View Post
    especially the headlight coating.
    Jul 2019
    Sa windshield lang po sir StockEngine. Mga twice palang ako nakagamit nito. Mali po ba? Paki correct nalang po ako para maalagaan ko ng mabuti at maayos ang sasakyan ko. Thank you.
    Yung windshield e hindi po coated or sealed pero plan ko na po magpaceramic before the year ends.
    im guessing youre using tap water as windshield washer? if so, i suggest purified drinking water.
    I drive a lot and cleaning the windshield with the washer always leaves the ws marks free.
    ive never had any watermarks after switching to purified drinking water. and my nozzle isnt clogged too.
    Jul 2019
    Yes po tap water lang gamit ko. Thanks for the tip Sir Stock Engine.
    Btw, are you guys using yung any windshield washer concentrate on your car? If yes, anong brand. TIA
    Apr 2014
    Hanapin nyo emblem nyo dun sa mux sa baduy thread.
    Baka nandon naka kabit na.
    Aug 2013
    Quote Originally Posted by chronicle View Post
    Sir, I think you have a bad day. Your comment doesn't give any relevance to the ongoing discussion. C'mon, iligo mo muna yan
    Apr 2014
    Quote Originally Posted by Vann-O View Post
    Naligo na ako.
    Just adding humor.
    Nov 2015
    Apparently this "SOB /druggie/ piece of Sh**" was not contented on "collecting" the emblem. He /She slashed one of the tires but not deep enough to deflate it. I was travelling pa naman along SLEX on the way to work. Good thing, the tire did not shred. I just noticed when I arrived at the office.
    What tire brand / model is closest to the Civic's stock tires? The remaining tires are still makapal and it's a waste to replace all.
    Thanks for answering.
    Quote Originally Posted by mahayag View Post
    Civic stock tires are Hankook Ventus S1 Noble2. Size is 215/55R16. You can find a lot of sellers online selling their stock tires by piece - that would be your most cost effective option.
    My stock battery lasted 11 months, then the second one (Motolite) lasted 11 months again. Such a small battery so I really don't expect it to last long.
    Aug 2013
    Damn, I'm expecting mine (new batt) to last at least 20-24mos but no assurance din pala kahit Motolite?! But anyway, at least I can expect the unexpected now. Thank you..
    Aug 2008
    What's the warranty on that, bro jut?
    Hindi ba 24 months?
    Quote Originally Posted by leonleon View Post
    Hindi ba 24 months?
    mataas mileage ni jut bro
    Oct 2018
    My stock battery finally gave out last night. Buti na lang nasa parking lot ako. mileage was around 7600km and used for 10 months. Called motolite and sabi nung nag kabit, most probably daw yung stock is matagal nang na-manufacture kaya inabot ko lang is 10 months of its battery life.
    Now for my questions:
    1) So last night na install yung battery. From reading Tsikot forums, i need to have the ECU reset daw after changing the battery. How true is this? Initially nakalagay sa dash "drive carefully, systems initializing" with the "VSA OFF" icon showing. After driving around at 10-15km/h, nawala na yung warning message and all symbols on the dashboard were back to normal. Do i need to reset parin?
    2) Not sure if it was an alternator problem or battery problem. I last drove it at 12 noon. Tapos when starting it at 12mn, i could turn on all accesories but i could not start the car. Nabibitin, or may "redondo" kung tawagin. So baka daw alternator. Pero the guy who changed the batt tested the alternator while the engine was running + AC + radio +revving, okay naman daw. Although he did not test the previous battery. Magpa second opinion ba ako or ill take his word for it na battery nga daw?
    BTW, had my battery replaced with Motolite Gold. Cost me 5650 (ouch ) Medyo nakaka praning kasi this is my first care ever and wala ako first hand experience sa ganto (except kagabi).
    Quote Originally Posted by ironman06 View Post
    my brand new car had a 12 month warranty on the battery.
    Apr 2008
    When i changed my battery before, it also had that "system initializing" & VSA OFF. At first i didnt know what to do since it kept on showing on the dash. I didn't use/run the car, i just started it. Then i circled around the block and everything automatically returned to normal. It has been more than 9 months already since it was changed and so far i have not encountered any problems.
    I did the battery changing on my own and i didnt do any ECU reset.
    Oct 2018
    Quote Originally Posted by rna800 View Post
    This is noted. Still observing if there are changes sa system. So far so good 3 days after battery change.
    Nag reset lang yung fuel consumption indicator. Pero everything else is fine.
    Just did not expect the battery to go dead. Nagpa PMS pa ako nung early September sa Casa, okay pa raw charge ng battery.
    I dont know if mine came with a warranty. If ma rereimburse nila yung gastos mag file ako ng claim hahaha
All New 2016 Civic
