Page 49 of 67 FirstFirst ... 3945464748495051525359 ... LastLast
Results 961 to 980 of 3899
    sa volmax madaming B1402 chiks. 350 yata price
    Thanks sir.
    *bayen
    Saw your FB page na sir. Pinost mo na pala dun photo ko.
    Thanks sir.
    *bayen
    Saw your FB page na sir. Pinost mo na pala dun photo ko nung EK. Sayang gusto ko kasi talaga ng longer filter pero will settle for B1402 muna siguro.
    Dec 2007
    Looks like I got Bayen fully addicted to filters lol.
    Jan 2012
    Nice to hear from you Doc. When you heading back in the PH?
    BT223 installed on a Camry.
    * Chics
    Yup. Posted it in my FB page. Hope okay lang sayo brother.
    B199 may padating ako. sabihan kita kapag nandyan na.
    Quote Originally Posted by bayen View Post
    * Chics
    No prob bro. Credits na lang siguro.
    Tumawag rin ako kay Gigatrade, wala rin silang B199. Itim na langis nung EK namin. Lapot pa, 20W50 kasi.
    I agree. Credits nalang siguro to acknowledge the owner of the photos.
    Chiks, sayang kakagaling ko lang ng volmax last sat hehe dapat pala itinext muna kita kung may papasabay ka ba.
    Jan 2012
    Will do idol. thanks again.
    Malapot na ba idol? bigat nyan 20w50, hindi pa affected fuel efficiency mo?
    Feb 2007
    Anyone selling a BD28 & BF7534? Kindly PM the price. Thanks.
    Jul 2011
    Anyone running this here? I decided to go ahead and get this for my Elgrand for a few reasons, one being the Elgrands filter is hard to find being 1" 12unf thread and second I have tons of space after removing the stock airbox.
    People have been doing these as Do it Yourself jobs for years on diesels Amsoil is now selling them (way overprice) IMO.
    I am using this kit with a Fleetguad bypass filter with sythetic media and Fleetguard full flow filter. Which will equal the Amsiol.
    About bypass filtration.
    • What is add-on bypass oil filtration?
    It is a secondary filtration unit with the purpose of super-cleaning engine oil. It has high
    contaminant-holding capacity and filters out the smallest particles to include sludge and
    soot in special cases. It also reduces engine wear and may increase oil volume.
    • Where is bypass filtration used today?
    Bypass filtration is standard on all Cummins automotive heavy-duty and larger turbo diesel engines
    and on Mack Applications. It has been used as options and/or standard on Caterpillar, Detroit.
    Reason for doing this on a diesel.
    • Removes small particles and soot
    • Extends engine life
    • Increases oil capacity
    • Extends oil change interval
    • Reduces engine wear
    Most going with this system using the higher end filters are going on average of 50000 klm between oil chanes with using engine oil testing as there go by of how well the system is working.
    By-pass lube filters are designed to capture and hold small abrasive particles that pass through the full-flow filter. Though microscopic in size, these particles are a major contributor to faster wear of internal engine parts.
    Any type of by-pass filter of reasonable quality will effect some reduction in engine wear rates compared to that obtained with full-flow elements alone. The more efficient the by-pass filter is in reducing the total contamination level of the lubricating oil, the more effective it will be in reducing wear rates.
    Extensive testing has shown that quality element type by-pass filters in combination with full-flow filters can extend engine wear life two to three times. Further testing with the centrifugal type cleaner has shown an additional reduction in wear of 54%. It is believed that the superior performance of the centrifuge results not only from its ability to remove abrasive particles down to 1 micrometer and below but also to the extraction of carbon soot agglomerates to a far greater degree than is possible with element type filters.
    A lot of post on hear always asking about the best oil but if your still using a low quality filter like VIC, and other no name Japan or China made filters then what's the point of getting good oil if it's dirty. Many OEM filters are also junk like Toyota it's what's on the inside not the outside of a filter that matters.
    Basic set up but you can also mount it under hood which many do. I know many TD42's have dual filters and Pajeros 4D56 and 4M40's have a combo filter with 2 elements so basically a stacked bypass filter.
    The whole oil filter quality thing has not really been covered well on the forum. So I figured it's about time.
    locally available po ba ito?
    Dec 2007
    You can find some of the filters but you will not find the same adapters easy. The duals are super hard to find. This place has the single filter kit you can ask them what thread sizes they have. You really only need one filter. http://www.facebook.com/M1modifiedcarparts
    Jul 2011
    ah i see, i thought with this kit installed will ensure that my oil temp is always low ;-)
    Aug 2010
    any info if Pacer is still selling orig Fleetguard oil filters?
    Medyo OT:
    Doc, pwede po ba sa gas engine for at least 7k OCI using Baldwin yung Petron RevX All Terrain 5W40 FS oil? Medyo worried lang baka mataas ZDDP nya, for diesel engines kasi nakalagay.
    Dec 2009
    Doc, pa share naman part no. ng Baldwin, Fleetguard, Mobil and Bosch Oil Filter for Toyota Innova Vvti and 2.5 Mitsubishi Strada diesel. Thanks in advance.
    Jan 2013
    Quote Originally Posted by marz View Post
    Innova baldwin bt223; strada baldwin bd28 or bosch OM36. Backread po ng konti to get all the info you need
    Dec 2009
    Quote Originally Posted by Ammiel Barlis View Post
    Thanks for sharing.
    Got a call from our favorite autoshop. They have this oil that sells for only P1,998/18ltr pail.
    http://www.warrenoil.com/MSDS-Spec/P...-40%20CI-4.pdf
    Coastal Fleet 15w-40 - Bob Is The Oil Guy
    Does anyone here tried this already?
  18. #18
    The specs on paper are promising! 2k for an 18 liter pail? WOOOOW!
    Quote Originally Posted by kompressor View Post
    hehe, I was given the worng price and item. It was just CF-4. No thanks. I'll stick with Delo for our fleet.
    Jul 2010
    Anong oil filter masuggest niyo for 2kd-ftv vnt 2.5 fortuner?
    Anong part number? Baldwin better oversize, magkano and saan meron? Been back reading about 40+ pages wala ako nabasa about 2kd-ftv
    Thanks
Remote bypass oil filtration
