^would you happen to know the OEM/Vic part number for your oil filter? you can cross reference it here:
JS Filters :: Product Catalogue
Problem is when we had our oil change last year and they used VIC, when I asked the auto supply if its for Dmax 4jj1, he's not sure but he said that its the one they use for the older dmax 4ja1?, and said that its fine to us it on the 4jj1.
I'll try to find a oem oil filter and cross ref it on the link posted above.
^i googled it. its the element type filter? not sure if meron baldwin. if walang baldwin, try Bosch nalang.
ISUZU 8-98018858-0
Yes sir, I understand that, its just that if a store has a bad reputation of selling fakes as discussed earlier in this thread, there might be a possibility that they are also selling fakes in their other line of products. I hope somebody can chime on the issue of Donaldson filters being sold by Volmax
Doon sa binibilhan ko baldwin and fleetguard oil filter eh original kaso konti lang selection dahil hobby lang nung may-ari. Kung ano kotse nya yun din lang oil filter meron siya benta. Nagpost na siya dito pero yung kapatid ata yan. Check nyo sulit nagkalat doon advertisement nya puro baldwin.
Or ang gawin nyo magpadala kayo galing sa america. Ako may inaantay pang heavy equipment pero pwede sa honda and subaru. Below 10 microns filtration rating.![]()
lubricheck, my doctor says that my 6000kms oil is still excellent condition, btw it is matched with bd28
lubricheck - YouTube
*jaggerx3
bd28 is perfect fit
Cummins Filtration
Ipa-check mo kung saan country of origin. Kasi pag wala nakalagay eh made in indonesia.
yup! pinakita pa nga sa youtube vid ng RP na gawa siya ng Champion labs.
Kaya direcho ka na sa mismo maker para mas mura.
Parang k&n oil filter din yan na rebadge kaya mahal.
Sige sir hanap din ako ng products nila na ka spec ng RP filter baka mas mura.
Eto pala nahanap ko na specs ng OEM Hyundai Filter (26310-27420) na gamit ko ngayon.
Height [mm]: 148
Thread Size: UNF 3/4-16
Seal Diameter [mm]: 70
Outer Diameter [mm]: 90
Anyone used a Baldwin oil filter without bypass valve?
Right now, been using one, B143 sa 4AFE ko with Delo Gold, more than 3 months na, no oil starvation, pag start sa morning, one click, off kaagad sensor lamp,may konti ingay lang sa tappets pero silent na after 3 minutes.
Next oci, will use Zic A, 10w40 semi synthetic motor oil and B178, with 30 psid bpv pressure setting, tingnan ko kung mawala ang lagitik ng tappets sa morning start up.
Posted via Tsikot Mobile App
