Page 47 of 67 FirstFirst ... 3743444546474849505157 ... LastLast
Results 921 to 940 of 3899
    Jan 2013
    Then get Delo 400 it's TBN is 16 and with a gas engine you can easily take that to 15000klm with a Baldwin filter.
    Doc I'm not sure that Delo 400 TBN is 16. I looked it up on the website you gave me for the caltex website and the TBN there is just 12.2
    http://www.caltex.com.au/productsand...n.aspx?ID=1639
    The price of Delo Gold Ultra is less than 200 pesos while Delo 400 is around 400 pesos (and really hard to find an auto supply or caltex station that sells it). Is it more economical to go with Delo gold than Delo 400 if the TBN difference is just 2 points?
    Jan 2013
    doc after some more research i found out that the delo ultra gold they sell here in the philippines is different from the the delo gold ultra in the australian website. delo gold ultra 15w40 here in phils. is CH rated with 9.5 TBN based on the data sheet i downloaded while Delo gold ultra 15w40 from caltex australia website is CI rated with 10.2 TBN.
    Dec 2009
    Quote Originally Posted by Ammiel Barlis View Post
    delo gold "ultra" here in the Philippines is CI-4 and global DHD rated... 200 plus to per liter
    "delo gold" is the one rated CH-4.... less than 200 per liter
    check the nearest caltex stations, they have delo gold ultra which is CI-4...
    Jan 2013
    ok, i'll check for new stocks. what i got from my auto supply earlier this afternoon was just CH-4. I will have to find CI-4 Delo gold ultra from somewhere else. Thanks again
    Jan 2013
    After checking the container it was indeed delo gold and not delo gold ultra. I asked for delo gold ultra specifically but failed to notice it was just delo gold that the sales lady gave me since i was on my way to work and a little bit in a hurry. My bad... To Doc, what is the best bang for the buck oil that I can get besides Delo Gold Ultra and Top1 SDO?
    Jan 2013
    Doc Mobil Delvac MX has a high TBN of 12 and only around 210 pesos per liter in one of the distributors here in Pampanga. According to its MSDS it has 2500 ppm ZInc
    https://www.alexisoil.com/sites/defa...5w-40-msds.pdf
    Since my gas engine car does not have a cat con its not going to be a problem if i use it, but is this oil good fo 10,000 OCI on a 2012 montero sport of course with a bd28 filter partnered with it (my fathers car).
    Also why is the more expensive (by 2-3x) Mobil 1 Turbo Diesel Truck 5W-40 fully synthetic oil have a lower TBN of 10.7?
    Here is the pds of the Mobil delvac MX being sold in the philippines. Mobil Delvac MX 15W-40
    For its zinc level, the pne you posted shows less than 2.5% but in some used oil analysis (UOA) i got from the net, zinc level is around 1,700ppm so hindi puwede sa gas engines with catcon. On the other hnd, Delo Gold Ultra, Top 1 SDoand Mobil 1 TDT 5w40 is about 1200ppm ang zinc.
    Dec 2007
    Percentage does not equal ppm. No oil has 2500ppm ZDDP unless it's break in oil which is only run for a very short time and then drained. You would start to see wear in your engine with that high of zinc. Every company has there own math but I don't know what theirs is.
    Jan 2013
    Doc thanks for clearing that out. How about for my other question regarding Mobil 1 turbo diesel truck fully synthetic having lower TBN than delvac mx but 3x more expensive.
    zinc for Mobil delvac MX based on UOA (comparable with Mobil super 1300 in the US) is around 1700ppm. Not relly good for gas engines with catcon.
    Mobil 1 TDT hs lower TBN because of its CJ-4 rating which means it is for diesel engines with better diesel fuel. So they dont need much TBN. But it is 2x expensive since it is synthetic and it is more expensive to produce and there are a lot of other additives. For a gas engine with a catcon, the Mobil 1 TDT is such an excellent oil. Been using it even in a 4-stroke motorcycle and after 5,000kms oil is just about the same when you first post it. Proof of its being a synthetic making it more durable even in high temp, high-revving engines.
    Delo Gold Ultra pala dapat... aisht
    Clarification lang on this, is it really 1700ppm for mobil delvac mx? Thought it was below 1200 ppm?
    Quote Originally Posted by timykoo View Post
    this is zinc. phos yung para sa catcon na dapat below 1200ppm.
    So hindi pwede ang delvac mx for gas engines?
    Jan 2013
    Ry_Tower I appreciate the info
    Jan 2013
    Doc what is the safe OCI for a 2012 Montero Sport 10K mileage, using Mobil Delvac MX and Bosch OM 036 filter? There is currently no supply of bd28 at Volmax so the bosch filter is the only other choice better than Vic and Mitsu Oem filter. A very noticeable difference between bosch vs oem oil filter, oil warning light for bosch goes off simultaneously when engine starts; for oem mitsu filter oil warning light goes off 1 to 2 seconds after engine has started.
    Dec 2007
    The Bosch will be fine for 10k, It's also has a fairly large filter surface it is not as efficient as the BD28 but it is larger.
    - - - Updated - - -
    Jun 2005
    any comment mga sir about this oil from Caterpillar.Its CAT DEO 15w-40
    Typical Characteristics*
    SAE Viscosity Grade 15W-40 10W-30
    API Service Classification
    Diesel CI-4 PLUS, CI-4, CI-4, CH-4,
    CH-4, CG-4,CF-4/CF CG-4, CF-4/CF
    Gasoline SL SL
    OEM Performance Level:
    Caterpillar ECF-1 ECF-1
    Volvo VDS-3 VDS-2
    DDC 93K214
    Cummins CES 20071/76/78 CES 20071/76
    Mack EO-NPP ’03, EO-M Plus EO-M Plus
    Flash Point, °C (ASTM D92) 224 227
    Pour Point, °C (ASTM D97) -30 -33
    Viscosity
    cSt * 40°C (ASTM D445) 120.5 76
    cSt * 100°C (ASTM D445) 15.5 11.5
    Viscosity Index (ASTM D2270) 135 145
    Sulfated Ash, % wt. (ASTM D874) 1.3 1.3
    TBN (ASTM D2896) 11.3 11.3
    Zinc, % wt. (ASTM D4951) 0.146 0.146
    Gravity * 16°C
    API (ASTM D287) 29.3 31.8
    Specific 0.880 0.867
    http://parts.cat.com/cda/files/30561...EHJ0059-02.pdf
    Jun 2005
    sir Dalawa ba ang oil filter ng isuzu 4bc2? anong pwede na Fleetguard or Baldwin for this sir?TIA
    Doc if you where choose between caltex delo 400 and Top1 SDO, which one would you buy assuming they have the same Price and used with a baldwin BD28 filter?
Remote bypass oil filtration
