The 57092 is completely the wrong filter and the wrong thread pattern you need the 51067.
WIX Filters : Filter Look-Up
Part Number: 57092
UPC Number: 765809570924
Principal Application: Chrysler Sebring (01-05), Dodge Stratus (01-05), Mitsubishi (99-11)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.944
Outer Diameter Top: 3.243
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 14
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20-6/20
Burst Pressure-PSI: 330
Max Flow Rate: 9-11 GPM
Alright sir, i will tell them(superior motors) that what i need is 51067. Thanks. 51675 can also be used, does this mean 4m40 can also use 51067?
