Quote Originally Posted by zix888 View Post
Doc i went to superior motors today and asked for a wix oil filter for my 4d56. They crossed my oem filter and what came up is 57092, which is different from what i found out online which is 51067. I just ordered because they dont have any stocks for any of those. I just told them to carefully check which will match my oem oil filter and make that order for me. They are going to let me know if its already available. I was just curious if both are the same maybe just the length is different
The 57092 is completely the wrong filter and the wrong thread pattern you need the 51067.
WIX Filters : Filter Look-Up
Part Number: 57092
UPC Number: 765809570924
Principal Application: Chrysler Sebring (01-05), Dodge Stratus (01-05), Mitsubishi (99-11)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.944
Outer Diameter Top: 3.243
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 14
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20-6/20
Burst Pressure-PSI: 330
Max Flow Rate: 9-11 GPM
