Results 931 to 940 of 2348
- Sep 2006
- 1,335
April 5th, 2010 01:33 AM #931
- May 2006
- 138
April 5th, 2010 09:44 AM #932
- Apr 2005
- 73
April 7th, 2010 07:02 AM #933sir dieseldude,
puede ko ba mapa diagnose my kia carnival a/t 2001 model 2.9 tdic
the problem was mausok and mahina ang humatak,nagbabawas ng oil
we did engine overhaul 4 months ago and took good break-in.
during that ok naman humatak and hindi mausok
then we changed oil recently then problem comes mausok na sya and medyo humina ang hatak
my trusted mechanic told me that turbo is the culprit.
thanks
- Sep 2006
- 1,335
April 7th, 2010 09:22 AM #934sir dieseldude,
Of course.
then we changed oil recently then problem comes mausok na sya and medyo humina ang hatak my trusted mechanic told me that turbo is the culprit.
thanks
Your mechanic is probably right.
- Apr 2005
- 73
April 9th, 2010 01:27 PM #935sir dieseldude,
fyi.we decided to brought down the turbo assembly. we found out that the spacer inside the turbo(washer) had sign of wear.
loose spacer enabled the oil passed thru the turbo system.
what we did was we fabricated spacer(machine shop) slightly bigger than the
old(micro mm difference).
right now my carnival runs well.
- Mar 2010
- 21
April 9th, 2010 04:16 PM #936Sir dieseldude
we've noticed na umingay tunog nang makina(alterra 2005 37k ODO) after i switched to 5w-40 fully synthetic castrol edge plus from using 15w-40 mineral oil.So far maganda naman sir performance sa highway kaya lang umingay pag rev ko pag city driving.is there something i should worry about 5w-40 synthetic in our tropical climate? masyado pu bang malabnaw ito when advised sa manual ay 15W-40.Need help na pa praning lang sa tunog ng makina maingay pu kc.Wala kc fully synthetic 15w-40 except royal purple.Do you advise me to try royal purple or shift to 15w-40 synthetic blend like caltex delo sports?Thanks in advance.
- Sep 2006
- 1,335
April 9th, 2010 09:41 PM #937
- Sep 2006
- 1,335
April 9th, 2010 09:52 PM #938
- Mar 2010
- 21
April 9th, 2010 10:27 PM #939
- Jan 2010
- 8
April 12th, 2010 03:50 PM #940Hi Sir Dieseldude. Itanong ko lang yhe easiest way to tell if the turbo of a 4d56 engine is functioning. kasi parang hindi hindi sya gumagana especially kapg na hit nya 2000 rpm. I have a montero kasi. when i accelerate and the rpm touches the 2000 mark, madidinig mo and feel the response of the engine.
Hope you can help. Thanks in advance.
PS.
May alam po ba kayo tungkol sa rotrex supercharger?
TIA
pakbet na lang yata ang hindi made in china... pati bamboo sticks, fabrique au chin na rin. heh...
2024 Manila International Auto Show APRIL 4-7,...
