Page 94 of 118 FirstFirst ... 4484909192939495969798104 ... LastLast
Results 1,861 to 1,880 of 2351
    #1861
    Quote Originally Posted by kompressor View Post
    Your idle settings are very very very good IMO. Kung gusto mo talaga babaan, pwede naman through ECU remapping. Kaso if the vehicle were mine, hindi ko bababaan ng 700 on aircon kasi maaapektuhan naman yung lamig ng aircon on idle tsaka hindi mo rin mararamdaman ang fuel savings kung yun ang habol mo kasi sobrang sobrang liit lang ng magiging difference kahit heavy traffic pa. Mas mataas pa nga yung idle ng mga nakita kong nissan urvans on aircon-idle. Parang nasa 900+
    Ah, ok so talagang normal lang ang ganitong settings. Yan din sana plano ko na mababa yung idle para pag trapik ay kahit paano makatipid sa diesel.
    Anyways, I'll leave it as it is. Baka may masira pa ako...hEhE
    Thanks to all of you guys...
    Apr 2009
    #1862
    Good day guys. Does anyone know the Cetane rating of our diesel in the Philippines offered by our different gas stations?
    Tnx
    Jan 2012
    #1863
    Mr. Dieseldude ,
    i am working with a 2006 MITSUBISHI TRUCK 4M50 and i am getting a code of P0251 / CAM/ROTOR /FUEL METERING /INJECTOR .
    i just want to know if you have encountered one of these already and what is the most possible cause of the trouble.
    with tthis code , the truck has no power and eventually dies and hard to start .
    if it falls into the injection pump or injectors , are you able to work on it ?
    thanks
    Sep 2006
    #1864
    Quote Originally Posted by canproauto View Post
    Mr. Dieseldude ,
    thanks
    What scan tool did you use? Does this truck have a common rail system, Bosch or Denso?
    Jan 2012
    #1865
    Quote Originally Posted by Dieseldude View Post
    Mr Dieseldude,
    i wasn't able to take a look at the IP make but be back on saturday to do further diagnostics .
    about the scanner ,we use AUTOENGINUITY WITH MITSU OEM VERSION and SOLUS BY SNAP ON obd2
    the truck is obd 2 compliant and its US version.
    thanks.
    Sep 2006
    #1866
    Mr Dieseldude,
    thanks.
    2006 truck would most probably have a Bosch or Denso CR system on it. I was asking about your scan tool because it displayed 4 areas to check for a single DTC.
    We have never worked on a 2006 US version Mits truck. But I believe this problem is within our service capability.
    Jan 2012
    #1867
    Mr Dieseldude, i was searching for parts locally but it came out negative , my only option is to take the injectors and pump out for you to test them.
    i have yet to come down to qc for follow up diagnostics but once confirmed that the problem is internal to IP or injectors , im going to ask the owner for this procedure.
    i just wonder if you can give me a rough estimate for testing and rebuilding /repairing .
    thanks for helping !
    Sep 2006
    #1868
    I can't. As earlier said, I've never worked on this truck, and don't even know the installed CR system.
    Jan 2012
    #1869
    Mr Dieseldude , ok then thanks for your time spent .
    Apr 2011
    #1870
    Sir Dieseldude, saan po banda yong Rod adjustment ng pajero 4d56 TDIC M/T para try ko po DIY na e-adjust? (Regarding sa Rough/smooth idling)
    Sep 2006
    #1871
    Quote Originally Posted by jacklord View Post
    Walang adjustment for rough/smooth idling. Meron adjustment to increase/decrease idle speed. Yan yung screw na nakabangga sa throttle lever sa taas ng injection pump. Turn in adjusting screw to increase idle, turn out screw to lower idle speed.
    Apr 2011
    #1872
    ah ok po THANKS sir dieseldude....
    #1873
    Hi dieseldude, ask ko sir. Kakapalit ko lang ng nozzle tips ng pajero 4M40 ko. Pansin ko pag umaga pag ka start ko,gryish white ang usok compared before with my old nozzle tips na hindi halata. Pero after a while of warming up humuhina naman yung grayish-white smoke nya. Is this normal? Pareho naman 129 yung nozzle tip na kinabet...
    Another is, me effect ba yung washer na kinakabit or nailalagay sa mounting hole ng nozzle tip?
    I hope you can shed light on my query. Thanks
    Sep 2006
    #1874
    Hi dieseldude, ask ko sir. Kakapalit ko lang ng nozzle tips ng pajero 4M40 ko. Pansin ko pag umaga pag ka start ko,gryish white ang usok compared before with my old nozzle tips na hindi halata. Pero after a while of warming up humuhina naman yung grayish-white smoke nya. Is this normal? Normal yan sa old engines na medyo mababa na ang compression. Nag iimprove ang compression pag uminit na ang engine.
    Pareho naman 129 yung nozzle tip na kinabet... Original Zexel nozzles ba ang nilagay mo? Tama ba ang opening pressure?
    Another is, me effect ba yung washer na kinakabit or nailalagay sa mounting hole ng nozzle tip? Meron effect kung sobra ang thickness ng compression washer.
    #1875
    Sa Bosch Malabon diesel ko pinapalitan sir yung nozzle tips ko yun kasi malapet samen. Anu effect sir ng thickness ng compression washer especially on my 4m40? Goal ko kasi maimprove yung FC ng Pajero ko...
    Sep 2006
    #1876
    May relasyon ang gasket thickness sa compression. Ano sabi ng Malabon diesel?
    #1877
    Bukas ng umaga dalhin ko sa kanila for check-up sir... Update kita...
    #1878
    Compression washer nga sir yung culprit. Replaced all four Big and all four small, plus 4 return washer. Good as new na sya... Thanks
    #1879
    Bg, fc ba problem kaya naicheck ulit?
    #1880
    White smoke from cold start CB, tpos me fuel knock pag arangkada. Di maganda yung lapat ng compression washer. Inayos naman nila under warranty. Ok naman na ngaun. Pinapalitan ko lang, gusto ko kasi tumipid nalalakas kasi ako sa fc nya. Turned out wala na sa standard values yung nozzle tips ko...
Diesel Fuel Injection System Help Desk
