Results 1,031 to 1,040 of 2348
- Sep 2006
- 1,335
July 31st, 2010 01:20 AM #1031
- Dec 2009
- 47
- Dec 2009
- 47
July 31st, 2010 11:42 PM #1033Pleck,
Normal ang konting usok/oil sa filler cap at dipstick sa mga high mileage engines. 128k palang po tinakbo
80kph maximum speed is not normal. Baka barado lang ang air/fuel filters.... or pwede rin na calibration ang kelangan mo.
bago po fuel filter ko
air filter lininis lang binugahan ng high pressure air 115kph sagad ko pigang piga
4D56T BTW sir diesel dude magkano po aabutin sa pag papa calibrate?
- Nov 2002
- 179
August 2nd, 2010 03:30 PM #1034hd my starter checked out, so far so good. they did some repair on it.
now its starting better. i'm still going to observe the stalling.
how do u do a compression test?
- Sep 2006
- 1,335
August 2nd, 2010 04:04 PM #1035
- Sep 2006
- 1,335
August 2nd, 2010 04:13 PM #1036Compression test is performed with the engine cold and not running.
- Disconnect the wire to the shutdown solenoid so that the engine will not start.
- Remove all glow plugs in order to install the compression gauge on cylinder #1.
- Crank the engine and read maximum compression pressure.
- Repeat this procedure on cylinders 2 to 4.
- Compare your compression readings with official Mitsubishi service infotmation.
- Nov 2002
- 179
August 3rd, 2010 06:21 PM #1037any idea where i can buy a compression gauge? and how much would it cost?
thanks!
- Apr 2005
- 73
August 4th, 2010 04:17 AM #1038Sir Dieseldude,
Need your usual help here..
What would be the cause of knocking sound on my TD27 Turbo engine?(Nissan Homy)
Engine was newly overhauled,calibrated the inj pump & nozzle.My trusted mechanic told me that rocker arm was the problem due to big clearance on cam shaft.Then I replaced with surplus(sariwa) camshaft & rocker arm,unfortunately knocking sound still there.
The person who did calibration,checked also if the nozzle is the cause of knocking sound but found wasnt.
Pls advice other possible causes.
thanks,
nitram
- Sep 2006
- 1,335
August 4th, 2010 11:57 AM #1039Sir Dieseldude,
Does knock come from all cylinders or from a single cylinder only?
thanks,
nitram
- Apr 2005
- 73
August 5th, 2010 03:50 AM #1040
Ngayong summer at malakas Ang sikat Ng late afternoon sun, mas visible Ang mga kasalubong Kapag...
Daytime running lamp (DRL)
