Results 1,801 to 1,810 of 2348
- Jul 2012
- 78
August 8th, 2012 01:23 PM #1801effect yung magiging pdeng bad effect nya sa engine
pag na ka block egr ko on my patrol zd30 engine..or ano ang pros and cons??
- Nov 2006
- 55
August 8th, 2012 02:07 PM #1802
- Sep 2006
- 1,335
August 9th, 2012 02:29 AM #1803Yes there was only 1km/liter improvement after I changed my noozles. Also I let the mechanic adjust delay of the injection pump para maging matipid sya. Timing is supposed to be set to specs.
Is there an improvement in the fuel consumption sir if ma block yung EGR? Fuel consumption and smoke will improve if a malfunctioning EGR is repaired or blocked.
- Sep 2006
- 1,335
August 9th, 2012 02:36 AM #1804
- Jan 2009
- 31
August 15th, 2012 10:12 PM #1805Sir Dieseldude, may electric supply pump ba yung montero latest model feeding diesel to the mechanical high pressure pump.
- Sep 2006
- 1,335
August 16th, 2012 06:40 AM #1806
- Jan 2009
- 31
August 16th, 2012 07:14 AM #1807
- Sep 2006
- 1,335
- Mar 2010
- 1
August 20th, 2012 09:05 AM #1809Sir Dieseldude, My Toyata innova diesel 2006 model stalled 3 times when we were going up to Tagaytay yesterday. It stalled again 1 more time when we were going back home in SLEX. Napansin ko nag stall say nuong 100kph ako, pero 80kph or less ok naman. I have no black smoke or no noticeable lost of power. Im not sure it its just my fuel filter (I never remembered changing them) or is about the Suction Control Valve.Will you be able to determine if its just my file filter or SCV. If it is the SCV that causing the problem how much will it be and how long will it take to fix it? Is central diesel open today or tom? Thanks
- Sep 2006
- 1,335
August 22nd, 2012 08:09 AM #1810Sir Dieseldude, My Toyata innova diesel 2006 model stalled 3 times when we were going up to Tagaytay yesterday. It stalled again 1 more time when we were going back home in SLEX. Napansin ko nag stall say nuong 100kph ako, pero 80kph or less ok naman. I have no black smoke or no noticeable lost of power. Im not sure it its just my fuel filter (I never remembered changing them) A blocked fuel filter will show on your dashboard. The filter indicator lamp will be continuously lit. Fuel filters need replacement at the prescribed interval, 1 year max if I remember right. An old filter can disintegrate and be pulled in by your fuel pump. Damage to your fuel system can be very extensive.
or is about the Suction Control Valve.Will you be able to determine if its just my filter or SCV. If it is the SCV that causing the problem how much will it be and how long will it take to fix it? Is central diesel open today or tom? Thanks Yes, this can be checked. But as I said, your fuel filter needs immediate replacement. Repair if necessary will take a day. Yes, we're open today.
