Results 1,841 to 1,850 of 2348
- Nov 2008
- 9
October 9th, 2012 08:27 PM #1841Sir Dieseldude,
What's your opinion about using diesel additives that claims that they not only prevents fungal contamination but also maintains the entire fuel injection system at the same time.
Thanks and more power.
- May 2010
- 9
October 11th, 2012 04:56 PM #1842Sir dieseldude,
Follow up lang po for my post above. Just had the injection pump of my 4d56 (L300) overhauled and calibrated. All gaskets and o-rings of the pump were replaced and the pump was calibrated.
However, naging hard starting na siya, it would take 2 to 3 tries before siya magstart whereas dati naman ay one click lang ay start na agad. Bakit kaya? Didn't notice this when i was still in the calibration shop, just though I would inquire first with you before I bring it back to the shop.
My 1993 L300 VV diesel has around 113,000km on its odo and according to the mechanic is due already for a complete overhaul because its temp rises during long climbs and when stuck in traffic and there is this weird "tak-tak-tak" like sound coming from the engine.
Any input would be greatly appreciated.
Thanks!
- Sep 2006
- 1,335
October 11th, 2012 05:27 PM #1843
- Sep 2006
- 1,335
October 11th, 2012 05:53 PM #1844Sir dieseldude,
However, naging hard starting na siya, it would take 2 to 3 tries before siya magstart whereas dati naman ay one click lang ay start na agad. Bakit kaya? Check timing, glow system, air ingress, etc. There are so many causes for a hard start problem. The workshop that serviced your IP should correct this problem.
Temp rise alone does not justify an overhaul. Check accuracy of temp gage, check thermostat, water pump, radiator, etc.
and there is this weird "tak-tak-tak" like sound coming from the engine. This could be fuel knock due to a faulty injector nozzle. Ask around for a 2nd/3rd opinion before considering an overhaul.
Thanks!
- Jul 2012
- 1
October 11th, 2012 09:45 PM #1845Sir dieseldude,
yung mercedes benz 240d AT ko po mausok na po anu po kaya kelangan gwin dun para mawala ung usok nia???
- Sep 2006
- 1,335
October 11th, 2012 11:44 PM #1846[QUOTE=macmac pogi;2022319]Sir dieseldude,
Mahirap sagutin dahil kulang sa detalye ang tanong mo.
- May 2010
- 9
October 12th, 2012 11:41 PM #1847
- Sep 2006
- 1,335
October 13th, 2012 03:01 PM #1848
- May 2010
- 9
October 13th, 2012 03:21 PM #1849
- Jul 2008
- 935
October 13th, 2012 04:50 PM #1850Hi Dieseldude,
Tanong ko lang sana kung paano ba i-adjust yung idle ng 1KZ-TE na engine bukod doon sa parang set screw na may stopper na nakakabit sa throttle body?
TIA...
