Results 1,771 to 1,780 of 2348
- Jul 2012
- 78
July 17th, 2012 02:00 PM #1771galing ako sa malabon diesel ngyn lang sa egr ko problem madumi so blinock nila so far ngyn nawala usok =)natatakot lang
ako bka in a long run may effect ito sa engine....have any patrol owners here block der egr???
- Jul 2012
- 78
- Nov 2006
- 55
July 23rd, 2012 02:01 AM #1773Hi sir, I have a Gen 2 Pajero 3 door 4M40 and I was just wondering if 5km/liter city driving is normal consumption for this kind of engine? So far i don't experience hard starting every morning and the power of the engine is good but for me it consumes a lot of fuel given that I'm a light footed driver. Is there any way or do you have tips on what can i do to improve my fuel consumption?
By the way, I haven't had any repairs on the engine nor had it calibrated yet, and I always do 5,000 km change oil and replace fuel filter. My km reading as of now is 150,000 sir. Would really appreciate your thoughts on this.
- Sep 2006
- 1,335
July 24th, 2012 03:22 AM #1774Hi sir, I have a Gen 2 Pajero 3 door 4M40 and I was just wondering if 5km/liter city driving is normal consumption for this kind of engine? 5km/ltr could be acceptable for city driving if you often drive on high traffic areas. Hiway driving is a more accurate measure of fuel consumption.
So far i don't experience hard starting every morning and the power of the engine is good but for me it consumes a lot of fuel given that I'm a light footed driver. Is there any way or do you have tips on what can i do to improve my fuel consumption? Try these: 1) check replace air filter, 2) remove any unnecessary cargo from your car, 3) check tire type, size, and inflation pressure, 4) Use less aircon or increase your temp settings a bit.
By the way, I haven't had any repairs on the engine nor had it calibrated yet, and I always do 5,000 km change oil and replace fuel filter. My km reading as of now is 150,000 sir. Would really appreciate your thoughts on this. Your maintenance program is very good but mileage is wear. Fuel injection system may have to be checked.
- Jul 2012
- 3
July 28th, 2012 03:12 PM #1775Hi Sir Dieseldude. I've been experiencing slight vibrations/bogging during acceleration from 1k to 2k rpm in my 2005 ford everest (4x4). I regularly change oil every 5000km. My current mileage is 67000km.
Here are the things that I already did but still did not solve the problem:
- Checked wheel camber, alignment and balance
- Checked crossjoints, center bearing and prop shaft. They are all intact.
- Replaced Fuel filter (OEM). The old filter has dirt and water when removed.
- Replaced AFT filter (OEM) and ATF oil
- Replaced Oil filter (OEM) and engine oil
Any info/advice regarding this problem? - TIA!
- Sep 2006
- 1,335
July 29th, 2012 12:44 PM #1776
- Jul 2012
- 3
July 29th, 2012 03:32 PM #1777
- Jul 2012
- 3
July 29th, 2012 08:10 PM #1778
- Sep 2006
- 1,335
July 30th, 2012 11:16 PM #1779
- Jul 2012
- 78
August 1st, 2012 01:28 AM #1780Hi is it advisable to block my egr valve on nissan patrol zd30 engine.what are the pros and cons or advantage or disadvantage of blocking egr on crdi engine??tnxs
Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage Jay...
2023 Toyota GR Corolla Hatchback
