Results 1,791 to 1,800 of 2348
August 5th, 2012 10:49 AM #1791
- Sep 2006
- 1,335
August 5th, 2012 12:22 PM #1792Thanks. So it's ok to let it reach 4k rpm every now and then. 4k is ok if this is the engine's rated rpm.
I guess you can still do this safely when changing gear you let it go up before the change. This is not ok. You will burn the clutch if you race the engine before engaging the clutch. It is better to just drive the car hard intermittently for 5 minutes.
- Jul 2008
- 935
August 5th, 2012 02:30 PM #1793Sir DD,
Eh kung nakapark lang ako AT kasi yung Hi-ace ko, tapos rev ko to 4k-5k na steady for 5mins, OK kaya ito? Since parang WOT na rin on the road di ba?
August 5th, 2012 07:05 PM #1794
- Nov 2006
- 55
August 6th, 2012 02:18 AM #1795Hi sir Dieseldude, I have a 4m40 3 door Pajero and my problem before was my fuel consumption. So What I did was change the zexel noozles and had it pressure test, after that sir what i noticed is that my fuel consumption stayed the same when I rev up to 3k or above RPM experience black smoke and when I drive it full pedal it's hard to push beyond 80kms/hr. By the way sir I just changed new air filters.
Any advice sir? I'm thinking to just having it calibrated. Will it solve the problem? Thanks
- Apr 2011
- 198
August 7th, 2012 04:24 PM #1796greetings:-)
would like to ask your opinion sir if im out of thread sorry:-) by then this is my problem with regards to my tamaraw fx a 2ct engine i was stock in a long traffic for about 20mins engine running. after a while i shut it off, when the traffic starts to move i turn on the ignition but i fail for 3x until it start. any idea whats the reason behind para maipaayos ko hiya tuloy ako.thank you....:-)
- Jul 2012
- 78
August 7th, 2012 06:31 PM #1797Sir dieseldue hingi naman ako opinion bout sa pag block ng egr ko..in a long run ba ano ba pdeng maging effect?tnxs po
- Sep 2006
- 1,335
August 8th, 2012 01:20 AM #1798Hi sir Dieseldude, I have a 4m40 3 door Pajero and my problem before was my fuel consumption. So What I did was change the zexel noozles and had it pressure test, after that sir what i noticed is that my fuel consumption stayed the same when I rev up to 3k or above RPM experience black smoke and when I drive it full pedal it's hard to push beyond 80kms/hr. By the way sir I just changed new air filters. Are you saying that there was no improvement after replacing the nozzles?
Any advice sir? I'm thinking to just having it calibrated. Will it solve the problem? Thanks. Check EGR before considering calibration.
- Sep 2006
- 1,335
August 8th, 2012 01:30 AM #1799
- Sep 2006
- 1,335
August 8th, 2012 01:34 AM #1800
Dito sa pinas, daming dahilan kung bakit natetengga pero kadalasan niyan gusto lang ng pampadulas....
Makati Subway. Completion date: 2025
