Results 1 to 10 of 2348
- Sep 2006
- 1,335
September 25th, 2006 05:20 PM #1I would like to help! Throw in your questions regarding problems with your fuel systems (injection pumps/ injectors/ turbochargers/ electronic systems/ etc.....) Then you guys take it from there...................if I can be of help, why not!
September 26th, 2006 12:17 PM #2
Dieseldude, how will I know if a Turbo is Watercooled or Oilcooled? and can one install a watercooled turbo with an oilcooler? and how?
- Sep 2006
- 1,335
September 26th, 2006 03:25 PM #3Hi Rion,
All turbos are cooled and lubricated by the engine's lube oil. Aside from oil supply and drain lines, a water cooled turbo will have coolant supply and drain lines as well. Plumbing will often be attached to the center housing, near the oil lines. On high load applications, coolant is sometimes plumbed to the turbine housing, and the turbine housing will have the necessary fittings.
You don't have to install an oil cooler.
An air intercooler may help. This is located between the turbo's air discharge duct and the engine's air intake manifold.
I hope I have been of help to you. Good luck.
September 26th, 2006 04:29 PM #4
- Sep 2006
- 1,335
September 26th, 2006 05:20 PM #5Hi Boy Torotot,
Check out my comments posted under the "Home-made Biodiesel"thread which I posted last September 24.
Your suggestions are OK, but I would like to add that when you replace your Fuel filters go for the Original (critical for this new models) not the replacement filters.. I am not selling for Nissan, but I have seen quite a number of problems when a replacement brand is used. Why scrimp on the cost when you do not spend this kind of money everyday for your vehicle!
September 26th, 2006 05:27 PM #6
Thanks sir! Will check your comments right away.
I've been using the original fuel filters, and having it replace regularly at the casa, since i got my ride. So they should be using original filters and not replacements.
September 26th, 2006 06:39 PM #7
does it mean that my turbo is both Watercooled and Aircooled. may IN-OUT kasi yung water and oil paths sa Turbo...
and does it need a turbo timer?
thanks, may spare toyota 3c-tdi engine kasi kami, baka puwede ilagay sa aming 3c-td. hehe..
September 26th, 2006 06:44 PM #8
Oil is primarily for lubrication, water is primarily for cooling.
September 27th, 2006 12:16 AM #9
- Sep 2006
- 1,335
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
