Results 2,271 to 2,280 of 2348
- Nov 2016
- 2
November 14th, 2016 12:56 PM #2271sir try mo mag pa enine decarbonize.
• Increase Engine Efficiency
• Reduce Harmful Smoke Emissions by up to 70% (Significant reduction in toxic emission)
• Increase Fuel economy by up to 27% (Saves on fuel / Improve gas mileage)
• Restore Output Horsepower by up to 45% (Restore lost engine power / Faster acceleration)
• Reduce Catalytic Converter Odors
• Prolongs Engine Life
- Aug 2016
- 1
November 15th, 2016 12:58 PM #2272hello to every one, i was back reading this thread mula ng makabili ako ng 2nd hand fuego, may tanong lang po ako bakit kaya hindi stable ang idling ng makina? mapapansin ito sa tunog. kahit patay o bukas ang AC. normal po ba ito? fuego 1998 4x2 po ito. nabili ko nitong june. salamat po
- Mar 2013
- 139
November 15th, 2016 01:16 PM #2273
- Sep 2008
- 587
November 15th, 2016 01:36 PM #2274
- May 2015
- 7
November 23rd, 2016 05:58 PM #2275Sir Dieseldude (or kung sino man makakatulong)
Drive a Gen 1 Montero Sport ('99) with a 2.8L 4m40. Ngayon, bigla na lang siya namamatayan pag umaga (or pag mga 1 day na naka parada), hindi naman siya hard starting 1 - click pa din siya, wala din usok white or black, wala talaga. Normal ang tunog, ang difference lang talaga grabe yung vibration pag umaga, tsaka yun nga namamatayan minsan (mas namamatayan pag hindi pa half yung temp. tapos binuksan ko yung aircon) . Last na calibration ko was mga 2011, namamatay matay din siya dati, pero maitim yung usok tsaka hard starting na siya nun. Ngayon hindi, kaya medyo nalalabuan ako.
Thanks in advance!
November 25th, 2016 06:59 AM #2276
Check your coolant temperature sensor reading when you think it will have the symptom. It might be indicating a lower resistance than normal when the engine is cold, or, try disconnecting your CTS and attempt to start. If the engine starts and runs at high idle, the PCM and the ISC ( idle speed control) are both working normally and that ECT needs to be replaced
- Apr 2009
- 544
November 26th, 2016 09:41 AM #2277Feedback po kayo kung paano naayos. Ginawa namin dinala sa calibration shop, may spring sa injection pump that holds fuel parang pondo yung spring 'flat' na ginawa lang stretch lang spring. sorry hindi ko alam anong tawag doon pinadala ko lang sa driver yun ang pag explain sa akin. it took only a few minutes. simula nun normal na yung sasakyan. thank you
- 52,731
November 26th, 2016 09:45 AM #2278
- Dec 2016
- 39
- Jan 2017
- 1
January 9th, 2017 08:11 AM #2280hi sir. Ano po kaya problem if biglang bumagal or ayaw bumatak ng makina pero di nman namamatay engine?isuzu alterra po sir.thanks
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Đ¡asual Dating - Verified Damsels
