Page 159 of 235 FirstFirst ... 59109149155156157158159160161162163169209 ... LastLast
Results 1,581 to 1,590 of 2348
    May 2009
    #1581
    Sir Dieseldude,
    is it safe to jump 12V direct from the battery to the fuel cut solenoid valve of the injection pump? just askin in case an electrical gremlin happens to occur with the pump wiring....TIA
    Sep 2006
    #1582
    Quote Originally Posted by kramterrag View Post
    *Sir Dieseldude,
    I have a N/A 4JB1 engine po, meron po bang engine-mods for it? Turbo kit? Any suggestions po for modding my unit and how much will it cost?
    thanks!
    We don't do mods for this engine. And I suggest that you keep it stock.
    Sep 2006
    #1583
    Quote Originally Posted by miked View Post
    Sir Dieseldude,
    Yes it is safe. Jump +12V to the solenoid terminal. Solenoid housing is grounded to -12V.
    Jan 2012
    #1584
    HI po mga master,
    Di ko po alam kung tama itong pag post ko pero I really wish that you geniuses could advise me what to do.
    My ride is an import Pajero, boxtype, 4d56 engine.
    Newly overhauled po so within breakin period pa.
    My problems are:
    1) im hearing a knocking sound coming from the engine compartment;
    2) i know its just the break in period, but when I took the SCTEX going to manila from zambales... my ride was having a hard time climbing the not so steep inclines thereat;
    My dad (which has a bit more experience with diesel engines than me) said that it is fuel knock.
    My ride already has this problem before it was overhauled. I just want to fix the problems of my ride 1 by 1 so that it would eventually be fantastic.
    PS: I read in one of the threads that "petron power booster" is good in reducing if not totally eliminating the knocking sound... so please can anyone advice me on all of the above.
    Thanks in advance
    Sep 2006
    #1585
    My ride is an import Pajero, boxtype, 4d56 engine. Newly overhauled po so within breakin period pa. My problems are:
    What did your mechanic have to say about this? He will be in the best position to advise you as he overhauled your engine.
    2) i know its just the break in period, but when I took the SCTEX going to manila from zambales... my ride was having a hard time climbing the not so steep inclines thereat.
    Did you have your fuel injection system serviced while the engine was being overhauled?
    He could be right.
    My ride already has this problem before it was overhauled. I just want to fix the problems of my ride 1 by 1 so that it would eTentually be fantastic.
    There was no improvement after the overhaul?
    Petron power booster can help. But this is masking the problem, not fixing the problem. A good engine should run well without aid from any additives.
    Thanks in advance
    You're welcome....
    Jan 2012
    #1586
    Gud am again sensei dieseldude,
    (He said that my engine sounds fine... If i want to eliminate the knocking sound, I should have my injection system serviced.)
    (Not yet... I would if it is already needed.)
    He could be right.
    (There was. The black smoke was reduced but not eliminated there's still heavy black smoke when im climbing inclines and when im about to accelerate from a full stop... but the torque did not improve, in fact i think it lost a little.)
    (As of now... I dont have the funding yet for servicing my injection system... is "petron power booster" a good bandaid solution... and can I use it even if my ride is still in the break-in period?)
    Thanks in advance
    You're welcome.... (you are really GOD SENT master diesel dude) tnx again
    Sep 2006
    #1587
    BEFORE DOING THIS, CHECK PUMP TO ENGINE TIMING.
    He could be right.
    FUEL KNOCK IS OFTEN DUE TO WRONG TIMING OR FAULTY INJECTOR/S.
    CHECK AIR FILTER AND PUMP TIMING.
    YES, AS LONG AS YOU FOLLOW THE RECOMMENDED MIX/CONCENTRATION.
    Thanks in advance
    GOOD LUCK!!!
    Dec 2011
    #1588
    Hi,
    2.8 Pajero 98, JDM, 4m40 automatic with 180,000 mileage.
    Sirs, May humahalong oil sa fuel kaya ang itim ng crudo sa fuel tank, mahina rin ang power.
    Ano kaya problem ? thanks...
    Ollopasagla
    Sep 2006
    #1589
    Hi,
    Hard starting din ba sa umaga?
    Ano kaya problem ?
    Malamang injection pump ang problem...
    thanks...
    Ollopasagla
  10. #1590
    guys meron ba kayong ma ssuggest na shop for cleaning injector nozzles sa south?
    *dieseldude
    sir mag kano mag pa linis ng nozzles sa central diesel?
Diesel Fuel Injection System Help Desk
