Results 1,571 to 1,580 of 2348
January 24th, 2012 10:13 PM #1571
gud pm sir i have adventure 2000 diesel . Pr0blem ko is hard starting sa umaga at mausok pg umandar na per0 pg nka 15 mins. tumatakb0 nawawala na. Napa duk0t k0 na din it0 last september. Change fuel,oil,air filter. At timing belt. Napakalibrate k0 na rin ganun pa din. Nkpg change na din aq ng glow plug. . Kc sa umaga after heater k0 kundi k0 pa aapakan ang silinyador ayaw mag start prang ayaw umahon ng diesel. Then pg ng start sya tatapakan k0 pa ng 2 or 3 times tap0s ung idle nya mababa pr0 pg ng2l0y na at ung parang di na mamamatay engine ok na per0 maus0k padin blue and white smoke amuy diesel baho ng us0k. Pro kapag tumakb0 na aq nabuga parin ng us0k den after mga 10 to 15 mins driving wala na ung us0k n0rmal na. Den madali na sya iistart once na tumakb0 na kaya lang may us0k padin once inistart k0 n ult sya f0r few min. Anu kea pr0blem sumskt n ul0 k0. Ok naman sya umandar at manakb0 sa start up at us0k sa c0ld start pr0blem k0.
January 24th, 2012 10:18 PM #1572
before kc mahina humatak kaya nag decide ak0 mg palit ng ring. Then after ma duk0t ganun pa din kea pacalibrate ak0 ,c0mpresi0n test sabi mataas dw aun calibrate linis inject0r n0ozle after nun gumanda na ung hatak ganda na umandar at lumakas hatak nya c0mpare bef0re, per0 sa c0ld starting pr0blem at us0k pg malamig makina andun padin hard start parin. Anu kaya mapapayo nyo?
- Sep 2006
- 1,335
January 24th, 2012 11:16 PM #1573
January 25th, 2012 08:21 AM #1574
sir napa overhaul ko na po eh, gumanda n ung andar at lumakas na humatak nun napa calibrate pr0blem lng tlga pag umaga starting hard starting ayaw umah0n ng diesel prang naghi2ngal0 kundi pa tatapakan ang pedal.. Tap0s maus0k hndi n0rmal. Mawawala lng us0k kpg umandar na tumakb0 ng 15 mins.
January 25th, 2012 10:07 AM #1575
- Sep 2006
- 1,335
- Sep 2006
- 1,335
January 25th, 2012 02:33 PM #1577Dalawa ang gumawa sa makina mo: yung nag overhaul ng engine chaka yung nag calibrate ng pump. Wala ba silang maipayo sayo sa next step na dapat gawin?
1) Ginawa mo ba yung una kong mga suggestion, lalo na yung compression test sa cold engine?
2) Kung mababa ang compression, hindi okay ang pagka overhaul.
3) Pa recheck mo din ang calibration ng pump sa authorized service center para maka sigurado ka.
Good luck................
January 26th, 2012 09:17 AM #1578
medjo ok na po ung adventure namin, pinalinis k0 ung n0zzle P350 then inadjust ung timing ng injecti0n pump. Mdli na sya iistart at d na maxad0 mausok. Lumakas ng k0nte ung hatak nya. May epekto po ba ung advance ang timing ng pump?
- Sep 2006
- 1,335
January 27th, 2012 08:29 AM #1579
- Nov 2011
- 25
January 29th, 2012 09:06 AM #1580*Sir Dieseldude,
I have a N/A 4JB1 engine po, meron po bang engine-mods for it? Turbo kit? Any suggestions po for modding my unit and how much will it cost?
thanks!
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
