Results 2,081 to 2,090 of 2348
- Sep 2006
- 1,335
December 28th, 2013 12:53 PM #2081
- Sep 2006
- 1,335
December 29th, 2013 01:24 AM #2082Guys I have a 2008 Isuzu Sportivo AT. The following was recently done to my ride:
1. Changed Oil.
2. Change fuel and oil filters.
3. Cleaned air filter.
4. Blanked EGR (This removed the black smoke).
On our recent trip to Naga City via south road I experienced the following:
1. Maingay na makita.
2. Very slow acceleration (Feels like stuck to the 1st gear).
3. High fuel consumption.
4. At 80-90kph it feels like from the 4th gear it automatically gears down to 3rd while accelerating.
On our way back eto naman ang nangyari:
1. Pumino tunog ng makina hindi na maingay.
2. Overtaking power was restored.
3. Fuel consumption improved. We managed to consume a little less than 1 full tank of diesel.
Question: Is it possible that a broken part was suddenly fixed? No this is not possible.
Is so ano kaya ito mga sir? I don't know. Car needs to be checked.
My concern is the downshifting na alanganin ng AT on high speeds. Is this the injection pump or the AR transmission? It could be that the throttle potentiometer needs adjustment or replacement if your car has this feature, or the transmission shift cable need adjustment.
I forgot to change the AT fluids pala.
- Sep 2006
- 1,335
December 29th, 2013 01:32 AM #2083
December 30th, 2013 12:57 AM #2084
- Dec 2013
- 14
January 7th, 2014 12:01 PM #2085Hi DieselDude, May Innova G 2006 diesel po ako na sasakyan.....gusto ko po sana humingi ng help sa inyo para maintenance na mabuti yong sasakyan ko... 75000km na po natatakbo ng sasakyan ko....2nd hand ko sya po nabili....Tuwing kilan po ako magpapa: 1. Change oil 2. Change ng Air Filter 3. Mapapalinis ng Fuel Tank 4. Change ng Fuel Filter, 5. Change Gear Oil 6. Check ng Injection Pump 7. Change ng Aircon Filter 8. Kilan po ako magpapa calibrate ng sasakayan?
Tuwing weekend ko lang naman po nagagamit sasakyan ko city drive...or uwi ng province namin sa batangas.
Sana mabigyan po ninyo ako ng tips... Salamat po..
- Dec 2013
- 14
January 7th, 2014 03:03 PM #2086Hi DieselDude, Pwede po ba lagyan ng Fuel Filter Water Separator ang sasakyan ko na Innova G D4D 2006?
- Aug 2010
- 278
January 11th, 2014 03:28 PM #2087Hi DieselDude, i have a 2013 Kia sportage crdi 2.0.
ask ko lang kasi from 5000kms - 9000kms (current) nag bawas ng oil from full( 5000kms oil change to L ( 9000kms) using Top1 SDO 15w40.
-no visible signs of leak inside and under the car
January 11th, 2014 10:29 PM #2088
Good day Diesel dude. May i ask where probably i can buy ZEXEL injector nozzles? I am based here in Paranaque-Bacoor area. TIA
- Sep 2006
- 1,335
January 16th, 2014 11:20 PM #2089Hi DieselDude, May Innova G 2006 diesel po ako na sasakyan.....gusto ko po sana humingi ng help sa inyo para maintenance na mabuti yong sasakyan ko... 75000km na po natatakbo ng sasakyan ko....2nd hand ko sya po nabili.... Nasa Owne's manual ang preventive maintenance information ng car mo.
1. Change oil: every 5000kms
2. Change ng Air Filter: depends on where you drive your car; more often in very dusty area; check your manual
3. Mapapalinis ng Fuel Tank: not necessary, fuel filter will clean your fuel
4. Change ng Fuel Filter: 1 year maximum
5. Change Gear Oil: check your manual
6. Check ng Injection Pump: as needed
7. Change ng Aircon Filter; Check your owner's manual
8. Kilan po ako magpapa calibrate ng sasakayan?: as needed
- Sep 2006
- 1,335
January 16th, 2014 11:24 PM #2090
VinFast VF 3
