Results 1,551 to 1,560 of 2348
- Mar 2009
- 19
January 13th, 2012 07:58 AM #1551Sa digital odo 64000 mileage. But I think na tampered na yun. Kase Late ko na nakita dun sa may cover ng timing belt may sticker na Naka indicate 86k something yung mileage that was late 2010. Baka pwede naman sir pa pm how much estimate cost sa inyo pag check ng injectors and repair. Many thanks
January 13th, 2012 12:00 PM #1552
* Boss Dieseldude: can you help me diagnose my trucks' problem? it's an isuzu giga cargo truck with a 10pe1 engine. i've been getting sh*tty fuel fc lately. i used to average 1.8 km/l (verified) before, and it's now down to 1 km/l (est). other than a sluggish engine response, i can't find anything wrong . smoke is at a minimum, engine cranks easily... help please, my job depends on it : (
- Sep 2006
- 1,335
January 13th, 2012 05:14 PM #1553
January 13th, 2012 09:19 PM #1554
Thanks for the quick reply dieseldude!
replaced already
it seems to be in timing, but i'll have it re-checked
checked as well. although i forgot to jack up the tires and check the retarder if it's really functioning properly.
5 months ago when the truck continuously ran out of fuel. at first i just thought the driver was doing "paihi"
i had the injectors sent to a local (malolos city) calibration shop. nothing changed, still the same consumption.
tri-axle
26 tons
- Sep 2006
- 1,335
January 14th, 2012 02:34 PM #1555Thanks for the quick reply dieseldude!
You don't have to check it if the injection pump has never been worked on before.
You have two stage injectors. They should be checked/serviced by an authorized diesel workshop.
January 14th, 2012 04:04 PM #1556
ok i took out the injectors today. i can drop by on monday for someone to have a look at it. thanks
- May 2011
- 4
January 14th, 2012 07:32 PM #1557sir, pwede po kita tawagan sa landline mo? may importante lang po akong tanong regarding sa sasakyan ko.
- Sep 2006
- 1,335
- Sep 2006
- 1,335
January 14th, 2012 11:50 PM #1559
- Nov 2011
- 25
January 18th, 2012 12:26 PM #1560*Boss Dieseldude
Need your expert advice po. I recently bought a Foton Blizzard pick-up with 2.8L NA 4JB1 engine.
My experience as of the moment is steering wheel, pedals & shift knob vibrations during idle. My first diagnosis is cheap engine mounts and transmission mounts. Worry ko lang po kung masosolve nito ung vibrations na na-e-experience ko ngaun kung papalitan ko ung mga mounts.
My next concern is the loud engine noise na pasok sa loob ng cabin and parang nagp-produce pa siya ng low frequency noise na in long drives eh irritating na masyado. Any advice po to reduce the engine noise? Was planning to install sound deadeners sa hood and sa loob ng cabin to reduce noises.
Any advice po regarding my concerns will be greatly appreciated po.
thanks in advance
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
