Results 1 to 20 of 2351
    Sep 2006
    Quote Originally Posted by bluetab View Post
    before kc mahina humatak kaya nag decide ak0 mg palit ng ring. Then after ma duk0t ganun pa din kea pacalibrate ak0 ,c0mpresi0n test sabi mataas dw aun calibrate linis inject0r n0ozle after nun gumanda na ung hatak ganda na umandar at lumakas hatak nya c0mpare bef0re, per0 sa c0ld starting pr0blem at us0k pg malamig makina andun padin hard start parin. Anu kaya mapapayo nyo?
    Heto payo ko:
    1) Check pump to engine timing
    2) Check glow plug system
    3) Measure engine compression while engine is cold
    4) If compression is low, perform engine overhaul.
    Pero sa palagay ko, mahina na ang compression ng engine.
    Quote Originally Posted by Dieseldude View Post
    Heto payo ko:
    sir napa overhaul ko na po eh, gumanda n ung andar at lumakas na humatak nun napa calibrate pr0blem lng tlga pag umaga starting hard starting ayaw umah0n ng diesel prang naghi2ngal0 kundi pa tatapakan ang pedal.. Tap0s maus0k hndi n0rmal. Mawawala lng us0k kpg umandar na tumakb0 ng 15 mins.
    Sep 2006
    Dalawa ang gumawa sa makina mo: yung nag overhaul ng engine chaka yung nag calibrate ng pump. Wala ba silang maipayo sayo sa next step na dapat gawin?
    1) Ginawa mo ba yung una kong mga suggestion, lalo na yung compression test sa cold engine?
    2) Kung mababa ang compression, hindi okay ang pagka overhaul.
    3) Pa recheck mo din ang calibration ng pump sa authorized service center para maka sigurado ka.
    Good luck................
Diesel Fuel Injection System Help Desk
