Page 111 of 118 FirstFirst ... 1161101107108109110111112113114115 ... LastLast
Results 2,201 to 2,220 of 2351
    #2201
    You don't have to bleed the high pressure lines to the injectors if you are able to successfully start the engine after a fuel filter change.
    Apr 2010
    #2202
    Nag leak ang injection pump (TD27, A/T) so binaklas, palit seals and calibration
    Nung binalik na sa akin, sobrang erratic ang shifting, hirap magdrive pauwi. Pero pag nilalagay sa Hold/Snow mode, medyo nagiging ok ang shifting
    May mga nabasa ako na may relation ang isang sensor sa injection pump na nagcocontrol ng shifting, so sinabi ko yung sa mekaniko ko. Pwede yun nga daw and kinuha nya kanina at ibabalik sa calibration shop. Kasi suggestion nya una eh mag change ATF, kakapalit ko lang last change oil (5k kms) and nung iniwan ko yung sasakyan, smooth ang pag shift
    Any ideas Dieseldude? Thanks
    Last edited by ParticleX; September 2nd, 2015 at 11:21 AM. Reason: Removed double post
    Sep 2006
    #2203
    Quote Originally Posted by ParticleX View Post
    Tama ka. Posible na hindi naitama ng calibration shop yung setting ng potentiometer. Test specs ang kelangan para tama ang lahat ng adjustments.
    May 2009
    #2204
    hello dieseldude,
    electrical problem lang pala ang issue. sa starter switch. nawawalan ng supply ng kuryente ang shut off valve kapag nasa "Start" position ang susian. buti hinook up ko sa tester. 12 volts kapag nasa ON. once na ipihit sa START, zero volts na. wired up with a relay muna yung shut off valve habang wala pang makuhang replacement key cylinder
    hello dieseldude,
    #2205
    Hi, my ride is adventure 2006 diesel glx. Kanina lang, nagwild yung techometer ko (tachometer, not the engine). Taas-baba sya for a few minutes. Then nag ok na, hindi na naulit.
    May naka encounter na ba sa inyo nito? What to check?
    #2206
    doublepost
    Oct 2015
    #2207
    Hi DieselDude,
    2 Quick questions if you dont mind.
    1. Is there any adjustment to increase fuelling on a 1999 elgrand (Higher boost wanted from turbo) - I have been told I have plenty of fuel available, but the same shop also increased my boost by simply unplugging the wastegate actuator pressure hose...sigh..so my faith is a tad low atm..(Very expensive, and big name shop in Makati area that will rename nameless)
    2. My car is idling a bit low and shaking shuddering..a 100rpm increase applied at the pedal fixes it nicely.. Would the idle adjustment be on the Zexel pump? Or is this a case of TPS adjustment?
    Oct 2015
    #2208
    Hi DieselDude,
    1. Is there any adjustment to increase fuelling on a 1999 elgrand with 3.2 litre QD32ETI (Higher boost wanted from turbo) - I have been told I have plenty of fuel available, but the same shop also increased my boost by simply unplugging the wastegate actuator pressure hose...sigh..so my faith is a tad low atm..(Very expensive, and big name shop in Makati area that will rename nameless)
    Feb 2006
    #2209
    Hi Dieseldude,
    2008 model Santa Fe maingay yung engine, parang helicopter, sumasabay sa rev ng engine.
    regular oil change with a FS oil. me kinalaman ba sa injectors ang ingay? nasa passenger side yun ingay around the belt area.
    possible ba na conn rod e nasa left side lang yun malapit sa belts?pag injectors ba maingay din?me slight vibration na rin ko na fifeel during engine shut off e.
    possible ba na magpost ng audio file dito to have a better feedback from all the gurus out here?
    Sep 2006
    #2210
    Quote Originally Posted by b0y37 View Post
    Check for faulty engine speed sensor and/or harness connections.
    Sep 2006
    #2211
    Hi DieselDude,
    1. Is there any adjustment to increase fuelling on a 1999 elgrand (Higher boost wanted from turbo) - I have been told I have plenty of fuel available, but the same shop also increased my boost by simply unplugging the wastegate actuator pressure hose...sigh..so my faith is a tad low atm..(Very expensive, and big name shop in Makati area that will rename nameless) Low idle speed cannot be adjusted on this electronic engine.
    2. My car is idling a bit low and shaking shuddering..a 100rpm increase applied at the pedal fixes it nicely.. Would the idle adjustment be on the Zexel pump? Or is this a case of TPS adjustment? Idle-0n adjustment is done through the TPS. It seems that your injection pump needs to be checked.
    Sep 2006
    #2212
    Hi Dieseldude,
    Noise/vibration cannot be diagnosed online. Many things to check, mostly mechanical. Hint, remove all belts, run the engine, listen for noise. Check engine / transmission supports.
    Oct 2015
    #2213
    Quote Originally Posted by Dieseldude View Post
    Hi DieselDude,
    Hi Diesel Due, thanks for the above.
    In relation question 1, I am guessing a typo? Did you mean increasing fuelling can not be performed on an electronic Injection pump?
    could I chip this, or, perhaps increase baseline pressure using an inline fuel pump? Any other methods?
    Or am I best to convert to mechanical pump from a larger engine like a TD42?
    For question 2, I will have a look at the TPS adjustment, everything else is currently running fine, smooth through the rev range, no black smoke, great shifting / etc...just shaking due to an idle speed of around 550-600rpm I think...
    Sep 2006
    #2214
    In relation question 1, I am guessing a typo? Did you mean increasing fuelling can not be performed on an electronic Injection pump? This is possible but it could lead to unstable engine rpm. It may also log a fault.
    Or am I best to convert to mechanical pump from a larger engine like a TD42? You can consider pump calibration. This might correct your low idle problem.
    For question 2, I will have a look at the TPS adjustment, everything else is currently running fine, smooth through the rev range, no black smoke, great shifting / etc...just shaking due to an idle speed of around 550-600rpm I think... This speed is low. Your engine should normally idle at 700-750 rpm.
    May 2009
    #2215
    Good day diesel gurus, recently bought 2007 ford ranger trekker Duratorq 2.5 with 113k kms on the clock. Ive experienced hissing sound coming from injector 1 and had my washers replaced. After a week my ranger stalled with check engine. I had it scanned and it shows injector failure. I called my mechanic to check and he took all injectors out to have it checked at the calibration center. Three injectors are excellent, giving out 16 but one injector is failing giving out 6. He said he could rebuild my faulty injector and replace the nozzle. The following day he came back to assemble my injectors in place but had minor fuel leak issues, he said its because of worn out rubber gasket around the injector. We road tested the car and it was running fine last night. He promised to come back today to put tribond to solve the fuel leak issue.
    On my way to work early this morning, my ranger stalled again with check engine. What could be the problem? Is it safe to use tribond as a gasket? Is the stalling caused by the leaking fuel? Thanks!
    Sep 2006
    #2216
    Good day diesel gurus, recently bought 2007 ford ranger trekker Duratorq 2.5 with 113k kms on the clock. Ive experienced hissing sound coming from injector 1 and had my washers replaced. After a week my ranger stalled with check engine. I had it scanned and it shows injector failure. I called my mechanic to check and he took all injectors out to have it checked at the calibration center. Three injectors are excellent, giving out 16 but one injector is failing giving out 6. He said he could rebuild my faulty injector and replace the nozzle. The following day he came back to assemble my injectors in place but had minor fuel leak issues, he said its because of worn out rubber gasket around the injector. Rubber gasket will not fix the leak because you have a compression leak. The compression gasket needs to be replaced and the sealing surface of the valve cover cleaned.
    On my way to work early this morning, my ranger stalled again with check engine. What could be the problem? We don't know.
    Is it safe to use tribond as a gasket? This is not a recommended fix.
    Is the stalling caused by the leaking fuel? Thanks! No, your car has another problem. Have your car scanned so that fault can be identified/corrected.
    Feb 2006
    #2217
    Hi Sir DieselDude,
    just to ask po if how much po ba ang calibration/checking of injectors?
    ano po ba effect if one of the injectors is already dead? can it be repaired? ano po yung reliability ng recond injectors?
    Sep 2006
    #2218
    Quote Originally Posted by threx666 View Post
    Hi Sir DieselDude,
    What is engine application of your injector?
    Feb 2006
    #2219
    Sir DD,
    its a D4EB engine , Santa Fe 08 Model.
    currently on a break in after a major overhaul, resleeved/new piston/ rings mechanics advise is just to take it slowly since break in period pa. so he said just stay below the 60kph speed as much as possible.
    i noticed that now it has a very sluggish performance, before, kasi when i reached around 1.5k rpm, my speed has already reached around 40kph but now parang ambagal nya gumalaw as in parang gapang , dati kasi i seldom reached 2.5k rpm when i drive but now halos umabot ako ng 2.5k rpm before i reach a speed f 50kph. Do you think dahil the sleeve and pistons are still setting in as what my mech said?will this still improve?
    Sir DD, pls PM me na lang po if prices are not allowed in this forum.
    Feb 2006
    #2220
    Sir DD,
Diesel Fuel Injection System Help Desk
