Results 1,601 to 1,610 of 2348
- Dec 2003
- 137
February 20th, 2012 10:28 AM #1601Have you sorted this out? If not, the following might help...
I too experienced stalling with my Adventure (also 4D56). I started to notice that it barely reaches 100KpH on the expressways, whereas it could reach 140KpH before. Nawalan ng rekta pero may hatak pa rin naman. DD advised checking throttle cable and changing fuel filter. Cable adjustment was fine. Changed fuel filter.
It was then that I experienced stalling. Lumala ang problema. Found out later that it was something I did earlier that caused it.
Mechanic 1 thought air was getting into the lines and suggested changing the priming pump. The solution was thankfully simpler and less expensive. Mechanic 2 suspected clogged lines. We pulled down the tank and cleaned it. Strainer had some sand (?) in it. Also removed a small strainer/filter in the injection pump located in the "in" line where fuel enters the pump. It's small and made of wire mesh. Cleaned it with thinner and compressed air. After we put everything back, she was back to her old self. Parang nagdahilan lang.
Like you, I also let the fuel level get tool low - up to the point where the warning light stays on. Maybe your pump sucked up dirt and got clogged.
- Sep 2006
- 1,335
February 20th, 2012 12:27 PM #1602I haven't seen a Foton, and have no experience on this vehicle. Things to watch out for would be the CRDI system installed.......is it a Bosch. Denso, or a China system.
I would next look at riding comfort and noise level. Without mentioning vehicle brand/s, I've seen some new China vehicles with excessive vibration and unwanted in-cab noise. Some even had poor transmission gear ratios.
Best thing is to test drive the vehicle.
- Sep 2006
- 1,335
February 20th, 2012 12:35 PM #1603
February 20th, 2012 03:58 PM #1604
The system is a Bosch branded system. Everything from the computer box to the injectors has Bosch logos on them. Are these systems reliable and easy to fix should anything go wrong?
I've test driven the unit. The extra long wheelbase (even longer than the View ambulance) really helps soak up the bumps. Vibration is a bit high. Sort of like riding a Crosswind. Shifter feel is not very sporty but tolerable.
- Sep 2006
- 1,335
February 21st, 2012 10:54 AM #1605Bosch systems are reliable. Offhand, I would say that this common rail system can be repaired. But to be sure, I need to see this car to get more info like part numbers and availability of diagnostic software.
Another important matter to consider is dealer support.......... if and when the vehicle fails.
February 21st, 2012 01:21 PM #1606
The engine is a clone of the Isuzu 4JB1-TC, btw. But the CRDi system is from Bosch.
The body of the van is a super long wheelbase, standard roof clone of an older model Toyota Hiace.
Support seems to be available so far. At least here in Metro Manila. The PCSO got 375 non-CRDi Foton Views to be given out as ambulances.
February 22nd, 2012 02:19 PM #1607
February 23rd, 2012 02:47 AM #1608
Sorry mga Bro, maybe its posted here, but sa haba na ng thread di ko na mabasa lahat.
I will try to visit a shop tom for my fuel injection. lagi kasing mainit yung l200 ko sa ASBU.
any recommended shop na hindi naman kataasan maningil.
I have it done last year but tingin ko humina yung hatak and now maitin ulit yung usok. hindi ko na maalala ano un pinalitan and ano yung hindi. worry ko kasi yung ibang shop sasabihin palitin na pero hindi pa pala. ang mahal pala ng pyesa kapag nag papa calibrate.
Can I have your no. Dieseldude. san ba yung shop nyo.
thanks.
- Sep 2006
- 1,335
- Nov 2008
- 27
February 28th, 2012 04:24 PM #1610Sir dieseldude,
good day po! Tanong lang po
ano po masasabi nyo sa 2t oil and diesel fuel combination?
Ano po ba ang magiging epekto nito sa injection pump, injectors at sa makina? PARTICULAR SA ISUZU 4JA1 ENGINE.
Kasi po they claim na naging smoother and less vibration ang engine.
Salamat po and God bless.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
