Results 2,101 to 2,110 of 2348
- Sep 2006
- 1,335
February 23rd, 2014 11:16 PM #2101
- Sep 2006
- 1,335
February 23rd, 2014 11:24 PM #2102Hi all,
I need help on my '98 Mitsubishi Adventure, 4D56 Engine.
1st During cold start po, mausok siya, white smoke coming out continuously, pero mag mainit na, wala naman na, at parang sinisinok yung makina, lakas din ng vibration. I have 4 glowplugs replaced less than 3 months ago. normal ba to sa lumang diesel engine? This could be an engine and/or injection pump problem.
2nd is Black smoke coming out kapag pa-ahon or arangkada.
Replace air filter and/or calibrate injection pump if black smoke is still present after replacing air filter.
hindi ko na alam saan ako magsisimula, kasi po this past few years madami nadin akong pinagawa dito sa truck ko, since I'm kinda restoring it and doing preventive maintenance. eto po mga pinagawa ko;
Engine calibrated back in December of 2011.
Nozzle tips replaced around July 2012.
Last change oil Sept. of 2013.
My aim now is to eliminate if not reduce this black smoke coming out. nakakahiya minsan nag i-slow down mga nasa likod ko pag umaarangkada, tapos minsan nag ba-bright pa ng ilaw. heheh Nakakahiya talaga, nag aaksaya ka pa ng diesel, at kulang power mo.
- Sep 2006
- 1,335
February 23rd, 2014 11:37 PM #2103Sir regarding injector nozzle :, due to a bad experienced about clogged or bad spray pattern, would you recommend to check first the cleaning of an injector fluid preferably before a long provincial sunday trip in order to avoid unnecessary problem and just how much is the prevailing nozzle cleaning service fee and do i have to watch out for the technician as the tip might be replaced? TIA
If you are you thinking of using an injector cleaning fluid, I don't know if it really works.
Dirty nozzles can sometimes be cleaned; faulty nozzles cannot be cleaned.
- Dec 2013
- 6
February 25th, 2014 04:19 PM #2104Ty sa reply sir dd, yeah nauubos. Ang nangyari, pinalitan na head gasket, pinarepace syempre sa machine shop ok na. Me problema na naman na nakita, yung puller ng turbo, me play daw. Umaalog sa madaling salita. Pina recondition yung turbo pero me konting usok pa rin, sa egr daw me leak. me butas sa madaling salita. Ang ginawa ng mekaniko sir, bypass ng egr. Ngayun wala ng usok, pero duda ako kase kasama ng design ng sasakyan yung egr dba? Ano kaya pwede gawin sir, hayaan ko naka block yung egr o kailangan ko bumili nito. Thanks again sir dd..
- Sep 2006
- 1,335
February 28th, 2014 11:25 AM #2105Ty sa reply sir dd, yeah nauubos. Ang nangyari, pinalitan na head gasket, pinarepace syempre sa machine shop ok na. Me problema na naman na nakita, yung puller ng turbo, me play daw. Umaalog sa madaling salita. Pina recondition yung turbo pero me konting usok pa rin, sa egr daw me leak. me butas sa madaling salita. Ang ginawa ng mekaniko sir, bypass ng egr. Ngayun wala ng usok, pero duda ako kase kasama ng design ng sasakyan yung egr dba? Ano kaya pwede gawin sir, hayaan ko naka block yung egr o kailangan ko bumili nito. Hayaan mo naka block.
- Dec 2013
- 6
March 1st, 2014 07:06 PM #2106Thanks you sa reply sir DD. May isa pa ko tanong, sabi ng bayaw ko yung thermostat ng ck ko tinanggal yung valve, ibig sabihin free flowing na yung coolant na sabi nung mekaniko ok lng daw kase di na mag ooverheat. Napansin nya na hindi talaga tumataas temperature sa normal level. Question ko sir, ok lng ba yun ginawa ng mechanic? anung pros and cons kung sakali? Thanks again sir DD.
Btw, uuwi ako ng june para personal ko macheck yung pajero, dalhin ko jan sa inyo sa central diesel para through check and professional advice galing sa iyo.
March 2nd, 2014 02:38 PM #2107
Hindi okay tanggalin ang thermostat. Kung maayos ang thermostat at nagooverheat, may problema somewhere. Hindi tamang solusyon ito. Ang thermostat ay importante para mabilis na ma attain at mapanatili ang optimum operating temperature ng makina.
Sent from my GT-N7100 using TapatalkLast edited by timo07; March 2nd, 2014 at 03:19 PM.
- Dec 2013
- 6
March 3rd, 2014 02:23 AM #2108
Ty sa reply sir. Hindi naman daw nag ooverheat, ayun sa mechanic para daw maiwasan overheat> Hindi rin pala tinanggal yung mismong thermostat, binutasan lng daw yung valve. Pansin ko nga puro remedyo ginawa ng mechanis sa ck ko, mahirap din kase wala ako sa pinas bayaw ko lng nag aasikaso. Ty sa info sir, first time ko kase mag diesel na sasakyan kaya nangangapa.
- Sep 2006
- 1,335
March 8th, 2014 10:05 AM #2109
- Sep 2011
- 626
March 20th, 2014 07:40 PM #2110Sir dieseldude goodevening po.
Our car is a 2005 hyundai tucson crdi now at 70k kms. Last friday naputulan po kami ng timing belt. Pinalitan na po yung mga nasirang pyesa (4 intake cam followers at yung mga belt tsaka yung injector seals. Pinaltan narin yung air filter).
Today nagstart na po siya pero there is white smoke even at operating temp. Sabi po ng mechanic baka daw tinamaan din injectors. Ano po marerecommend niyo?
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
